Heater Smell
Old May 1st 05, 03:16 AM
O. Sami Saydjari
Default Heater Smell
When I use my (cabin air) heater, it starts to smoke a bit and smell if
I turn it more than half way up. I suspect that this is coming from a
build up of material in the heat conduits over the years. Does anyone
else experience this? Should I have my heating hoses removed and
cleaned (seems expensive if I have my mechanic do it)? Could there be
something more significant going on (by the way, I have a CO detector, I
have not significant CO, so I know that I do not have exhaust fumes
leaking into the cabin air heating system)? Suggestions?
-Sami
N2057M, Piper Turbo Arrow III
Old May 1st 05, 03:22 AM
Dan Thompson
If your CO detector is the type that is a little plastic square with the dot
that turns black in the presence of CO, that kind has a service life that is
rather short. Then it stops working. Is yours fresh?
"O. Sami Saydjari" wrote in message
When I use my (cabin air) heater, it starts to smoke a bit and smell if I
turn it more than half way up. I suspect that this is coming from a build
up of material in the heat conduits over the years. Does anyone else
experience this? Should I have my heating hoses removed and cleaned
(seems expensive if I have my mechanic do it)? Could there be something
more significant going on (by the way, I have a CO detector, I have not
significant CO, so I know that I do not have exhaust fumes leaking into
-Sami
Old May 1st 05, 03:24 AM
O. Sami Saydjari
Yes, actually, I have a pretty sophisticated battery operated one that
detects down to less than 10ppm. i am certain that there is no leak.
And I had my mechanic double check to make sure. that is defintely not
the problem. -Sami
-Sami
Old May 1st 05, 03:42 AM
This may be a shot in the dark, but we had exactly the same problem on our
Arrow. Turned out to be a leaking hand brake master cylinder. The leaking
brake fluid dripped onto the cabin heat conduit and would smoke (and stink)
whenever the heater was turned on more than a little bit. Easy to check,
and fairly easy to fix if that's the problem.
-Elliott Drucker
Old May 1st 05, 05:21 AM
And it might be engine oil dripping onto the muffler and
smoking, though this would happen anytime the heat was on, not just
when it was turned more than halfway up. Perhaps there's a dead mouse
or something in the scat hose from the heat muff?
Dan
Home Brew Pre Heater? Errol Groff Home Built 0 March 6th 05 03:20 AM
Heater problem fixed! Jim Burns Owning 14 December 17th 04 11:38 PM
Aztec heater update Jim Burns Owning 0 November 27th 04 04:28 PM
Looking for user comment : Oil Sump Heater Javier Gorordo Owning 8 December 2nd 03 02:33 PM
