AutoGas fueling tips and tricks
Old November 26th 07, 04:21 AM posted to rec.aviation.owning
Al[_2_]
Default AutoGas fueling tips and tricks
We have an autogas STC for our Cessna 172. Other than building another
"mighty Grape" like Jay Honeck's, what tips are there for fueling? Type
of fuel cans, funnels, bonding, do you bond a plastic can, funnel type, etc.
Al
1964 Cessna 172
Old November 26th 07, 08:20 PM posted to rec.aviation.owning
Jim Stewart
etc.
Al
1964 Cessna 172
I use a pair of 5 gallon red plastic jugs
with the new no-emissions normally sealed
nozzles. The jugs are the short, squat
shape and can be lifted up and emptied into
the tank without too much strain.
I try to use the jugs only to transfer fuel
and never store it longer than 24 hours.
Old November 26th 07, 08:51 PM posted to rec.aviation.owning
Robert M. Gary
etc.
Al
1964 Cessna 172
I used to carry 5 gal jugs in the car and then used a pump to transfer
to the plane. However, that was back when I could buy FAA legal mogas.
Today the cans sit in my garage.
-Robert
Old November 27th 07, 01:27 AM posted to rec.aviation.owning
Blueskies
-Robert
Ditto here...an old section of carpet as a pad over the wing, and squareish gas cans, allowed me to put the can on the
pad, put my thumb over the spigot, and then tip the can over and place the spigot in the fuel neck, then pull my thumb
away. Pop the air vent plug and let the can drain. Never any problem, until all the so-called gasoline around here
turned out to be contaminated with alcohol...
Old November 27th 07, 03:53 AM posted to rec.aviation.owning
I've seen a couple of hangar fires caused by de-fueling.
The common denominator was plastic funnels and cans.
Metal woudl be strongly advised.
Bill Hale A&P
On Nov 26, 6:27 pm, "Blueskies" wrote:
"Robert M. Gary" wrote in ...
-Robert
Old November 27th 07, 08:13 PM posted to rec.aviation.owning
Matt W. Barrow
" wrote in message
I though metal containers contribute to static discharge hazards.
Matt Barrow
Performance Homes, LLC.
Cheyenne, WY
Old November 27th 07, 05:00 AM posted to rec.aviation.owning
Mike Noel
Have you found a source for unoxygenated (alcohol free) unleaded gasoline?
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
If any question why we died, tell them, "Because our fathers lied."
- Rudyard Kipling.
"Al" wrote in message
etc.
Al
1964 Cessna 172
Old November 27th 07, 05:12 AM posted to rec.aviation.owning
Al[_2_]
Yes. While our area was on the EPA's hit list for a number of years
with forced "oxygenation" that was lifted about 4 years ago after a
decade of air quality compliance. We have plain old gas available. I
buy direct from a jobber/fuel distributor at their pump.
Al
Old November 27th 07, 10:14 PM posted to rec.aviation.owning
Jay Honeck
Fueling without a fuel truck/pump/hose is a dangerous pain in the
ass. The cans are really heavy and awkward, spills occur all-to
often, it's easy to dent/scratch your wing, and there is the ever-
present thought that you might burst into flames at any moment.
Building a fuel truck is not an insurmountable feat. Every farmer in
the Midwest has a similar rig, and you can build the whole thing for
less than 3 AMUs. The payback time, with a $1 per gallon price
differential, is very, very quick. (And it's pushing $2 per gallon
right now...)
If anyone needs advice, just drop me an email or post here. I'll be
glad to point you in the right direction(s).
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 27th 07, 11:46 PM posted to rec.aviation.owning
right now...)
Jay Honeck
Iowa City, IA
Pathfinder N56993www.AlexisParkInn.com
The "mighty grape had spoken... :)))
Anyone have Tips, tricks & notes on a C-170B Al G[_2_] Piloting 7 June 4th 07 06:47 PM
Autogas Tips and Tricks Al[_2_] Piloting 46 May 4th 07 11:54 AM
MoGas Tips, Tricks, Concerns, How To Al Gilson Owning 129 May 17th 06 08:20 PM
Pocket PC Tips & Glide Navigator II Tips Paul Remde Soaring 0 December 14th 04 08:21 PM
FAR Reference - Self Fueling Ben Smith Owning 8 April 8th 04 11:07 PM
