With 100LL now creeping toward the $5 mark (or more), it's time to
take advantage of the Peterson autogas STC in our 172E. What are the tips and tricks for operating with mogas. Different run-up techniques? Taxiing, hi temperatures, vapor lock avoidance, winter ops. You name it. Inquiring minds want to know. Thanks in advance. Al 1964 172E KSFF |
Al wrote:
With 100LL now creeping toward the $5 mark (or more), it's time to take advantage of the Peterson autogas STC in our 172E. What are the tips and tricks for operating with mogas. Different run-up techniques? Taxiing, hi temperatures, vapor lock avoidance, winter ops. You name it. Inquiring minds want to know. Thanks in advance. Trick number 1, find autogas without alcohol in it these days. -- Jim Pennino Remove .spam.sux to reply. |
You operate exactly the same way.
Al wrote: With 100LL now creeping toward the $5 mark (or more), it's time to take advantage of the Peterson autogas STC in our 172E. What are the tips and tricks for operating with mogas. Different run-up techniques? Taxiing, hi temperatures, vapor lock avoidance, winter ops. You name it. Inquiring minds want to know. Thanks in advance. Al 1964 172E KSFF |
As mentioned, the ethanol thing is a problem. Cessna Pilot's
Association recommends using a 50/50 mixture of 100LL and auto fuel in your O300. It more closely matches the 80 your O300 was designed for than anything else out there. I did until I moved to an ethanol state. After moving and having to burn state 100LL I discovered the joy of stuck valves. Now I add MMO or TCP to the expense of 100LL. There is an advisory for the O300 about vapor lock and the CPA recommends flying only on one tank anytime above 5000' so you can easily clear the lock. I got the EAA STC. It was $145 for my O300 C172F. No work to it other than the paperwork and sticker application. You'll find a lot more advice on this on the CPA forum: www.cessna.org Calling the CPA tech guys is also a good thing. Oh yeah, MoGas also voids the warranties on cylinder overhauls and such. Of course the MMO alternative voids that and potentially your insurance as well. You just have to decide if you'd rather have a warranty or a working engine. Helen PS. There's good reading about MoGas STCs on the EAA page. Al wrote: With 100LL now creeping toward the $5 mark (or more), it's time to take advantage of the Peterson autogas STC in our 172E. What are the tips and tricks for operating with mogas. Different run-up techniques? Taxiing, hi temperatures, vapor lock avoidance, winter ops. You name it. Inquiring minds want to know. Thanks in advance. Al 1964 172E KSFF |
Al wrote: With 100LL now creeping toward the $5 mark (or more), it's time to take advantage of the Peterson autogas STC in our 172E. What are the tips and tricks for operating with mogas. Different run-up techniques? Taxiing, hi temperatures, vapor lock avoidance, winter ops. You name it. Inquiring minds want to know. Thanks in advance. Al 1964 172E KSFF In my plane, if I have been flying, then let it sit on a hot ramp, I have to apply the boost pump to get the overcome vapor pressure. Everything is fine for flight -- as long as there is air flowing through the engine compartment. |
![]() Al wrote: With 100LL now creeping toward the $5 mark (or more), it's time to take advantage of the Peterson autogas STC in our 172E. What are the tips and tricks for operating with mogas. Different run-up techniques? Taxiing, hi temperatures, vapor lock avoidance, winter ops. You name it. Inquiring minds want to know. Thanks in advance. Al 1964 172E KSFF Find someplace where the autogas mixture is not prohibited by the FAA. -robert |
Jim Stewart wrote: wrote: Al wrote: With 100LL now creeping toward the $5 mark (or more), it's time to take advantage of the Peterson autogas STC in our 172E. What are the tips and tricks for operating with mogas. Different run-up techniques? Taxiing, hi temperatures, vapor lock avoidance, winter ops. You name it. Inquiring minds want to know. Thanks in advance. Trick number 1, find autogas without alcohol in it these days. All the folks driving the Rotax 100hp engine are using 91 octane mogas with about 5% alcohol with no issues. I have no idea whether or not that would be acceptable in a Lycoming or Continental. Watch out if you have fibreglass tanks! Boaters are finding out (the hard way) that the alcohol decomposes the resins into goo that gums up carburetors, filters and lines. |
"Jim Stewart" wrote...
wrote: Trick number 1, find autogas without alcohol in it these days. All the folks driving the Rotax 100hp engine are using 91 octane mogas with about 5% alcohol with no issues. I have no idea whether or not that would be acceptable in a Lycoming or Continental. I was talking to the Rotax guys (Lockwood or similar) and they mentioned the same "ethanol up to 5% is OK" number. I got distracted and never asked the followed up question re the problem that most east coast states typically blend at 10%. Anyone heard or has any actual experience of running 10%. |
Jim Stewart wrote:
wrote: Al wrote: With 100LL now creeping toward the $5 mark (or more), it's time to take advantage of the Peterson autogas STC in our 172E. What are the tips and tricks for operating with mogas. Different run-up techniques? Taxiing, hi temperatures, vapor lock avoidance, winter ops. You name it. Inquiring minds want to know. Thanks in advance. Trick number 1, find autogas without alcohol in it these days. All the folks driving the Rotax 100hp engine are using 91 octane mogas with about 5% alcohol with no issues. I have no idea whether or not that would be acceptable in a Lycoming or Continental. Depends on whether you're talking "acceptable" from a practical or legal position. From a practical standpoint, alcohol has a number of bad effects on things not designed to be exposed to it, and unless you know the effects of alcohol on every little piece in your engine, you just became a test pilot. From a legal standpoint, probably not a snowball's chance in hell. -- Jim Pennino Remove .spam.sux to reply. |
MoGas Tips, Tricks, Concerns, How To | Al Gilson | Owning | 129 | May 17th 06 08:20 PM |
A List to add to your bag of tricks... | jsmith | Instrument Flight Rules | 1 | April 8th 05 07:13 PM |
Pocket PC Tips & Glide Navigator II Tips | Paul Remde | Soaring | 0 | December 14th 04 08:21 PM |
"Dirty Tricks" and "Both Sides Do It" | Leslie Swartz | Military Aviation | 19 | March 29th 04 06:11 PM |
Stupid Pilot Tricks | David Dyer-Bennet | Piloting | 3 | October 19th 03 12:22 AM |
