(From: www.navytimes.com)
Navy grounds 39 P-3s over faulty wings By Chris Amos - Staff writer Posted : Monday Dec 17, 2007 13:54:07 EST The Navy on Monday grounded 39 P-3 Orion anti-submarine patrol planes - nearly one in four of its inventory - because of concerns that a structural defect could cause either of the aircraft's wings to break off in flight. The grounding was the result of engineering analysis and computer modeling and was not caused by any actual structural failures, said John Milliman, spokesman for Naval Air Systems Command. Navy engineers looked at several factors, Milliman said, including the number of hours a particular aircraft has flown, the maneuvers it performed while in flight, the altitude the aircraft have operated at and the climate in areas where it has been based in determining which aircraft should be grounded and which should be kept flying. Milliman said each grounded aircraft will be flown to a repair depot in Jacksonville, Fla. Those that can be repaired will be out of service for between 18 and 24 months. Those that can't will be retired. Navy officials have not determined how much the repairs will cost or whether retired aircraft will be replaced, he said. Navy officials will rotate P-3s from other parts of the fleet to replace the 10 grounded aircraft that are currently deployed, and commanders plan to ensure that each squadron can meet all of its operational requirements. The Navy has 161 P-3s. Their average age is 28 years old; the oldest aircraft is 44 and the youngest 18. Milliman was unable to say whether the age or flight time of the grounded planes was greater than that of the P-3 fleet as a whole. |
On Mon, 17 Dec 2007 23:03:53 +0100, "Marco P.J. Borst"
wrote: The Navy on Monday grounded 39 P-3 Orion anti-submarine patrol planes - nearly one in four of its inventory - because of concerns that a structural defect could cause either of the aircraft's wings to break off in flight. yep daar hadden die oude L-188's in de jaren 60 ook al last van. haarscheurtjes in de vleugels. toen ontstond danook het grapje dat de oplossing zou bestaan uit het boren van een reeks gaatjes in de haarscheuren. De diepere filosofie was dat pleepapier ook nooit scheurde bij de gaatjes. Cheers, Pieter -- Vernuft is een sublimatie van domheid.© |
On Dec 17, 3:03*pm, "Marco P.J. Borst" wrote:
(From:www.navytimes.com) Navy grounds 39 P-3s over faulty wings By Chris Amos - Staff writer Posted : Monday Dec 17, 2007 13:54:07 EST The Navy on Monday grounded 39 P-3 Orion anti-submarine patrol planes - nearly one in four of its inventory - because of concerns that a structural defect could cause either of the aircraft's wings to break off in flight. The grounding was the result of engineering analysis and computer modeling and was not caused by any actual structural failures, said John Milliman, spokesman for Naval Air Systems Command. Navy engineers looked at several factors, Milliman said, including the number of hours a particular aircraft has flown, the maneuvers it performed while in flight, the altitude the aircraft have operated at and the climate in areas where it has been based in determining which aircraft should be grounded and which should be kept flying. Milliman said each grounded aircraft will be flown to a repair depot in Jacksonville, Fla. Those that can be repaired will be out of service for between 18 and 24 months. Those that can't will be retired. Navy officials have not determined how much the repairs will cost or whether retired aircraft will be replaced, he said. Navy officials will rotate P-3s from other parts of the fleet to replace the 10 grounded aircraft that are currently deployed, and commanders plan to ensure that each squadron can meet all of its operational requirements. The Navy has 161 P-3s. Their average age is 28 years old; the oldest aircraft is 44 and the youngest 18. Milliman was unable to say whether the age or flight time of the grounded planes was greater than that of the P-3 fleet as a whole. Gee, all America's flying stuff is suddenly being grounded. However will y'all start new wars? |
I see you are from canada smarty pants?
This "redstripe" doesn't include the CP-140 aurora dip**** do you even know what that is? Because you guys hardly fly i like we fly ours? Although your crews are great. How about all the "wars we started" you guys always manage to limp in with minimal support, which however weak is appreciated. (except for WW2, you guys certainly went above and beyond) Which brings up the point, who is in charge in Canada, the world as a whole has no clue? Does anyone really care? On Fri, 21 Dec 2007 19:39:29 -0800 (PST), "Mr.Smartypants" wrote: On Dec 17, 3:03*pm, "Marco P.J. Borst" wrote: (From:www.navytimes.com) Navy grounds 39 P-3s over faulty wings By Chris Amos - Staff writer Posted : Monday Dec 17, 2007 13:54:07 EST The Navy on Monday grounded 39 P-3 Orion anti-submarine patrol planes - nearly one in four of its inventory - because of concerns that a structural defect could cause either of the aircraft's wings to break off in flight. The grounding was the result of engineering analysis and computer modeling and was not caused by any actual structural failures, said John Milliman, spokesman for Naval Air Systems Command. Navy engineers looked at several factors, Milliman said, including the number of hours a particular aircraft has flown, the maneuvers it performed while in flight, the altitude the aircraft have operated at and the climate in areas where it has been based in determining which aircraft should be grounded and which should be kept flying. Milliman said each grounded aircraft will be flown to a repair depot in Jacksonville, Fla. Those that can be repaired will be out of service for between 18 and 24 months. Those that can't will be retired. Navy officials have not determined how much the repairs will cost or whether retired aircraft will be replaced, he said. Navy officials will rotate P-3s from other parts of the fleet to replace the 10 grounded aircraft that are currently deployed, and commanders plan to ensure that each squadron can meet all of its operational requirements. The Navy has 161 P-3s. Their average age is 28 years old; the oldest aircraft is 44 and the youngest 18. Milliman was unable to say whether the age or flight time of the grounded planes as greater than that of the P-3 fleet as a whole. Gee, all America's flying stuff is suddenly being grounded. However will y'all start new wars? |
Faulty Becker AR-3201 | Pepin Andr? R. | Soaring | 3 | March 7th 10 02:22 PM |
Emergency AD Grounds 172s and 182s | C J Campbell | Owning | 4 | March 10th 05 03:41 AM |
MX 20 -another faulty display | [email protected] | Instrument Flight Rules | 14 | January 29th 05 05:54 PM |
Radio outage at ZLA grounds flights | A Guy Called Tyketto | Piloting | 0 | September 15th 04 05:56 AM |
Flying w/faulty gas gauge | Yossarian | Piloting | 48 | November 18th 03 03:18 PM |
