Faulty Becker AR-3201
Old February 18th 04, 02:23 AM
Pepin Andr? R.
Default Faulty Becker AR-3201
Good day all,I am looking for a microprocessor to repair my ar-3201.If
anybody can point out a source it would be appreciated.
Part Number Manufacturer
CDP1802ACE RCA/Harris/Intersil
Also am looking for written off by accident or by battery corrosion
any Becker ar-3201 so I could salvage this part.Many thanks and fly
safely. André
Old February 18th 04, 02:46 AM
David Kinsell
If's a fairly common (but quite old) part. Places like www.findchips.com show
them as being available from a number of sources.
"Pepin Andr? R." wrote in message om...
safely. André
Old May 18th 09, 05:23 PM
Smota Smota is offline
Junior Member
First recorded activity by AviationBanter: May 2009
I have a Becker AR 3201 and it don't turns on. I know the radio has an internal fuse but i don't know where. In the Installation Manual i only found the wiring connection diagram. Anybody knows where can i found maintenance and repair manual, so i can see the several components of the radio? Thank you. Best regards from Portugal.
Old March 7th 10, 02:22 PM
ChrisPA17 ChrisPA17 is offline
Junior Member
First recorded activity by AviationBanter: Mar 2010
Quote:
The internal fuse in the AR3201 is located next to the big coil on the board near to where the power comes into the radio. The fuse is rated at 5 Amps, and my fuse has the lettering 5A on the side. The fuse is mounted horizontally and spaced a little above the board (all other components are mounted vertically).
The fuse is a PICO and you can buy them on eBay for about 0.4 Euro. You do not have to dismantle the board from the radio to replace the fuse, but you can just solder the new fuse to the legs of the old fuse. This is easier for you and less danger to the board.
Last edited by ChrisPA17 : March 10th 10 at 03:27 PM. Reason: Previous posting was not correct.
VHF Becker AR4201 Philippe Home Built 2 July 9th 04 08:30 PM
WANTED: Becker AR 3201 VHF radio Ole Refsgaard Aviation Marketplace 0 January 24th 04 10:20 PM
Microair vs Becker Ian McPhee Soaring 0 August 30th 03 09:45 PM
SOLD Becker ATC-4401-175 and SigmaTek ARC EA-401A Servoed Encoding Alt Juan E Jimenez Home Built 0 August 11th 03 05:03 AM
FS: Becker ATC-4401-175 and SigmaTek ARC EA-401A Servoed Encoding Alt Juan E Jimenez Aviation Marketplace 0 August 4th 03 08:48 PM
