Positive control check complete:
http://www.justsoar.com/ For $20/year you get current Tim Newport-Peace (*.sua), OpenAir (*.txt) and Google Earth (*.kml) files for your desired region, based on the latest FAA National Flight Database (NFD), which is updated every 28 days. When I get the secret decoder ring for the SN-10 format, I'll endeavor to add that too. I will also try to work with 2KA to integrate anything he comes up with for airspace from another source -- alternatives are always good. More info at the main page and the FAQ linked therein. ~ted/2NO |
On Dec 21, 12:48*pm, Tuno wrote:
Positive control check complete: http://www.justsoar.com/ For $20/year you get current Tim Newport-Peace (*.sua), OpenAir (*.txt) and Google Earth (*.kml) files for your desired region, based on the latest FAA National Flight Database (NFD), which is updated every 28 days. When I get the secret decoder ring for the SN-10 format, I'll endeavor to add that too. I will also try to work with 2KA to integrate anything he comes up with for airspace from another source -- alternatives are always good. More info at the main page and the FAQ linked therein. ~ted/2NO Nice job on this Ted but I ran into a problem. I'm using GNII with a Compaq Aero 2100. The appearance on the downloaded file differs from the normal SUA file when viewed using notepad. When I open the new one with notepad everything is displayed as a continuous line of text as opposed to the old one, which has separate lines of text for each coordinate. When I loaded the new file into my Compaq Aero it locks up when trying to open the files. I had to reboot to exit the program. Wecome to the wonderful world of software programs. |
Gary,
What you're seeing is the difference between Windows/DOS text files and Linux/Unix text files. They use different end-of-line characters. My two test platforms are SeeYou (for .sua and .txt) and WinPilot (as an actual PDA platform, using .txt) and neither of those cared, but since your applications had trouble, we can make the software explicitly use the Windows/DOS format. Stay tuned. ~ted/2NO |
On Dec 21, 3:35*pm, Tuno wrote:
Gary, What you're seeing is the difference between Windows/DOS text files and Linux/Unix text files. They use different end-of-line characters. My two test platforms are SeeYou (for .sua and .txt) and WinPilot (as an actual PDA platform, using .txt) and neither of those cared, but since your applications had trouble, we can make the software explicitly use the Windows/DOS format. Stay tuned. ~ted/2NO Thanks for the quick fix on this! |
Gary,
I sent you an e-mail, the problem is now fixed, please re-run your query and let me know how it goes on your Compaq Aero. 2NO |
Tuno wrote:
Positive control check complete: http://www.justsoar.com/ For $20/year you get current Tim Newport-Peace (*.sua), OpenAir (*.txt) and Google Earth (*.kml) files for your desired region, based on the latest FAA National Flight Database (NFD), which is updated every 28 days. Can my desired region be the USA? Or do I have download a bunch of smaller areas? I'm using a full USA file now with SeeYou, which is convenient. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Your desired region can be as big as you want. To get everything,
specify top = 89, left = -175, bottom = 0, right = 0. Just don't open the .kml file with Google Earth -- it will gag on it. (At least mine does, and I have a googleplex of RAM.) 2NO |
Tuno wrote:
Your desired region can be as big as you want. To get everything, specify top = 89, left = -175, bottom = 0, right = 0. Just don't open the .kml file with Google Earth -- it will gag on it. (At least mine does, and I have a googleplex of RAM.) 2NO OK, signed up, paid my money, got my airspace - good website! One good featu the MOA's are named the same as the names on the chart, and are the names used by the "controlling agency". The SeeYou airspace files use numeric names that weren't recognized by anybody. If/when we get the radio frequencies for the MOAs in the files, I will be one happy camper! Let the whining begin... 1) In my area (Washington and Oregon States) there are two "For reasons of national security, pilots are requested to avoid flight at and below 1800' (or 5000'- Oregon) MSL in this area". These are displayed as Prohibited areas, instead of something like a "warning area". Don't know what the official designation is, but it's definitely not Prohibited. 2) The coordinates in the FAQ for pilots wanting the entire USA caused the website to issue an error when I tried to use them. The ones I used instead are Top: 50 Bottom: 24 Right: -130 Left: -65 and they seemed to get the entire continental USA. I didn't try for Alaska! Been there, done that, wouldn't mind doing it again, but not in 2008. 3) Adding small note that the numbers are Latitude and Longitude in degrees, and W longitudes are negative (-) numbers will speed things up for the initially clueless like me. Or let people put in N and W, in addition. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Eric-San,
Thanks for signing up! I'll fix the coordinates in the FAQ -- thanks for the heads up. For the places in the northwest that you mention, when you say 'These are displayed as Prohibited areas, instead of something like a "warning area"', I assume you're referring to the airspace file and not to the chart? The nfd2sua tool (the software behind the web page) does not translate airspace items that are in the NFD as "Prohibited" -- they will go into the output files as Prohibited (always forever and ever). (See the caveats on the front page -- the NFD airspaces are tranposed to the output files "as is"; if the NFD is wrong, your airspace file will be wrong.) The only translation done in the nfd2sua tool is Restrictive types for OpenAir files. NFD restrictive types Alert, Caution, MOA, Training, Warning and Danger areas are written as "AC Q" (for "danger"). (Restricted and Prohibited use R and P, as per the OpenAir description at winpilot.com.) Good suggestion on the lat/lon help -- will do. 2NO |
Eric,
A good example of where charts differ from (alternate) reality exists in the area around the Grand Canyon. If you look at a chart, it says "The airspace overlying the Grand Canyon National Park below 18,000 feet MSL is subject to special air traffic rules." That's *all* it says. The National Flight Database does *not* have any restrictive or controlled airspaces above the Big Ditch. But if you dig deep in the FARs, section 93.305 subpart U describes 4 named areas officially designated as Class E in which you cannot fly below 14,500 feet MSL. I've looked at the digital charts for OR/WA and I see the areas you're referring to. I don't know why the charts don't say "Prohibited", but they are most definitely that subtype in the NFD. -ted |
Successful conversion of .cai files to .igc files for OLC | danlj | Soaring | 2 | August 5th 07 02:45 PM |
Wichita Airspace Question and overlapping airspace | Owen[_4_] | Piloting | 1 | February 14th 07 09:35 PM |
Load airspace files into emap | Jon Marshall | Soaring | 0 | August 14th 05 08:56 AM |
Two airspace classes for one airspace? (KOQU) | John R | Piloting | 8 | June 30th 04 04:46 AM |
Soaring Server/Worldwide Soaring Turnpoint Exchange back online | John Leibacher | Soaring | 0 | June 21st 04 05:25 PM |
