Quonset State (RI) airport (OQU) has class D airspace and is just
south of Providence (PVD), which has class C airspace. The northern arc of the Class D airspace isn't charted with a dashed blue line, so the best I can do is assume that this boundary is coexistent with the Class C surface area. Some of the class D airspace is under Class C with a floor of 1700 feet, some under Class C with a floor of 1300 feet, and some is outside the Class C airspace. To make things confusing on the chart, the dividing line between the 1700' floor and 1300' floor is beneath the [25] Class D ceiling symbol. So according to the chart, the Class D airspace extends to 2500 feet. However, Quonset tower was sternly warning pilots the other day that their Class D only went to 1300 feet and not to exceed that without the blessing of Providence. So why does the chart say 2500 feet for the Class D inside the Class C ring? This airspace looks pretty confusing. For good measure there is a class E surface area for a PVD approach under the Class C ceiling inside the Class D ring, although we can assume that the E is only in affect inside the D circle when Quonset tower is closed. To be sure, the tower at Quonset keeps funny hours somewhat (e.g. closed Mondays). |
"John R" wrote in message ...
Quonset State (RI) airport (OQU) has class D airspace and is just south of Providence (PVD), which has class C airspace. The northern arc of the Class D airspace isn't charted with a dashed blue line, so the best I can do is assume that this boundary is coexistent with the Class C surface area. Some of the class D airspace is under Class C with a floor of 1700 feet, some under Class C with a floor of 1300 feet, and some is outside the Class C airspace. To make things confusing on the chart, the dividing line between the 1700' floor and 1300' floor is beneath the [25] Class D ceiling symbol. I may be wrong, but looking at the sectional at http://map.aeroplanner.com/mapping/c...yp=APT&txt=OQU I think the (small) area outside the Class C ring that's Class D has the ceiling of 2500. The Class C floor starts at 1700 over the airport. This looks similar to Wiley Post airport (PWA) near OKC (Class C) which has [38] listed as the Class D ceiling outside of the Class C ring and the floor of Class C above the airport is 2500. When I did my training at PWA, we were told to stay below 2500 when coming into PWA from the North or West to avoid the Class C. Check with the locals, especially ATC for both and they will know and give you the answers to their airspaces. |
[...] So according to the chart, the Class D airspace extends to 2500 feet. However, Quonset tower was sternly warning pilots the other day that their Class D only went to 1300 feet and not to exceed that without the blessing of Providence. So why does the chart say 2500 feet for the Class D inside the Class C ring? Because that's what they write at all the Class D airports, as near as I can tell. They just look at the airport elevation, add 500', and put that on the chart. We have several Class D airports in our region that underlie the SeaTac Class B airspace. All have letters of agreement with the SEA approach facility reducing their Class D ceiling. In one case, the Class D ceiling is the Class B floor (BFI), and in the other cases, the reduced ceiling of the Class D either creates or expands a charted Class E area between the Class D and Class B airspace. The situation around BFI sounds most similar to yours, where the charted Class D overlaps with the Class C airspace. Frankly, I find the whole thing very confusing. In the case of BFI, it's (almost) clear, because the floor of the Class B is clearly marked as being below the marked ceiling of the Class D. You know (that is, you can assume) you're either in Class D or Class B, and it's very clear where the Class B ends. But in the other cases, it's not clear at all if what's really going on is that the airspace ceded to the SEA approach facility winds up being Class E, or if it's Class D or Class B (and controlled by SEA App/Dep either way). I have always treated the ceded airspace as Class E and no one has ever taken me to task, even when I was on a tower frequency. So I presume that's fine to do. But the whole situation highlights the incredibly poor degree to which these letters of agreement and related arrangements are communicated to the pilots that they affect. Pete |
"Peter Duniho" wrote in message ... Because that's what they write at all the Class D airports, as near as I can tell. They just look at the airport elevation, add 500', and put that on the chart. So where are some of these airports where the Class D airspace reaches only 500' AGL? The standard ceiling for Class D airspace is 2500 AGL, but they are charted in MSL values. Since field elevation at OQU is only 18 MSL and airspace is shown in hundreds of feet 2500 AGL becomes 25 on the chart. We have several Class D airports in our region that underlie the SeaTac Class B airspace. All have letters of agreement with the SEA approach facility reducing their Class D ceiling. In one case, the Class D ceiling is the Class B floor (BFI), and in the other cases, the reduced ceiling of the Class D either creates or expands a charted Class E area between the Class D and Class B airspace. The situation around BFI sounds most similar to yours, where the charted Class D overlaps with the Class C airspace. Controlled airspace is established by legislation and is not altered by letters of agreement between ATC facilities. Frankly, I find the whole thing very confusing. In the case of BFI, it's (almost) clear, because the floor of the Class B is clearly marked as being below the marked ceiling of the Class D. You know (that is, you can assume) you're either in Class D or Class B, and it's very clear where the Class B ends. But in the other cases, it's not clear at all if what's really going on is that the airspace ceded to the SEA approach facility winds up being Class E, or if it's Class D or Class B (and controlled by SEA App/Dep either way). I have always treated the ceded airspace as Class E and no one has ever taken me to task, even when I was on a tower frequency. So I presume that's fine to do. But the whole situation highlights the incredibly poor degree to which these letters of agreement and related arrangements are communicated to the pilots that they affect. When classes of airspace overlap, the operating rules associated with the more restrictive airspace class are applied. Class B airspace is more restrictive than Class C, Class C more restrictive than Class D, etc. Note that it is the rules of the more restrictive airspace that apply, not the more restrictive rule. So for all practical purposes, there is no overlap of airspace classes, the less restrictive class ends where the more restrictive class begins. |
ink.net... So where are some of these airports where the Class D airspace reaches only 500' AGL? It's called a typo. I know it's difficult to see where the "2" should have gone, so I'll give you a hint: put it right before the "5" in "500". Controlled airspace is established by legislation and is not altered by letters of agreement between ATC facilities. Fine. When classes of airspace overlap, the operating rules associated with the more restrictive airspace class are applied. As I assumed. That doesn't answer the question I asked though. When a tower controller tells me that I am no longer their problem but the chart tells me I'm still in their Class D airspace, does that mean I have to switch over to the approach facility and talk to them? Note that I'm not talking about a situation in which Class D overlaps with some other more restrictive airspace. I'm talking about the situation in which the ceiling of the Class D controlled by the tower has been lowered by some letter of agreement, but where there was already an area of Class E between the Class B and Class D. For example, a TIW I recently learned that the tower controller there only is responsible for traffic up to 2000' MSL, but the Class B doesn't start until 6000' MSL (3000' MSL north of the airport, but within the lateral limits of the Class D). The Class D as charted goes up to 2800' MSL. Since you say that controlled airspace is not altered by LOA, that implies that the airspace up to 2800' MSL is still Class D. But the TIW control tower has said they don't have responsibility for that portion of the Class D. On the other hand, I was not given a handoff as I climbed through the top, and by the time I managed to actually get Seattle Approach on the radio with my particulars, I'd have flown out the side of the airspace. Am I really legally required to contact the approach facility given responsibility for that portion of the Class D airspace? I have never done so, I have never had ATC complain about it, and given the usual busy-ness of the approach frequencies, it would be impractical to have to deal with them for the brief period of time one would spend in "their" portion of the Class D. Pete |
"Peter Duniho" wrote in message ... It's called a typo. I know it's difficult to see where the "2" should have gone, so I'll give you a hint: put it right before the "5" in "500". Consider proofreading. As I assumed. That doesn't answer the question I asked though. You hadn't asked a question. When a tower controller tells me that I am no longer their problem but the chart tells me I'm still in their Class D airspace, does that mean I have to switch over to the approach facility and talk to them? What problem is there to be solved? What's the situation? Note that I'm not talking about a situation in which Class D overlaps with some other more restrictive airspace. I'm talking about the situation in which the ceiling of the Class D controlled by the tower has been lowered by some letter of agreement, but where there was already an area of Class E between the Class B and Class D. For example, a TIW I recently learned that the tower controller there only is responsible for traffic up to 2000' MSL, but the Class B doesn't start until 6000' MSL (3000' MSL north of the airport, but within the lateral limits of the Class D). The Class D as charted goes up to 2800' MSL. Since you say that controlled airspace is not altered by LOA, that implies that the airspace up to 2800' MSL is still Class D. But the TIW control tower has said they don't have responsibility for that portion of the Class D. Non-approach control towers don't have any actual control over the Class D airspace unless it is delegated to them by the overlying approach control or center. A letter of agreement may give them responsibility and authority for SVFR operations, or for silent departures of IFR aircraft, as examples. For VFR operations there's not much for them to be responsible for, as no separation is provided to VFR aircraft in Class D airspace. They may specify runway, direction of traffic, aircraft to follow, etc., for the purpose of providing runway separation. That and traffic advisories are about it for VFR operations. On the other hand, I was not given a handoff as I climbed through the top, and by the time I managed to actually get Seattle Approach on the radio with my particulars, I'd have flown out the side of the airspace. A handoff is a radar function, I believe you mean you were not directed to contact Seattle approach. Sounds like you were departing VFR, so there'd be no reason for tower to tell you to contact them. If you want radar services, you call them. If you don't want radar services, you don't call them. Am I really legally required to contact the approach facility given responsibility for that portion of the Class D airspace? No. If you're IFR you'll be told to contact them, if you're VFR there is nothing they are responsible for. |
"Peter Duniho" wrote in message When a tower controller tells me that I am no longer their problem but the chart tells me I'm still in their Class D airspace, does that mean I have to switch over to the approach facility and talk to them? No. We will often terminate aircraft before they reach the boundary of class C airspace because the pilot asks to be terminated. If there's no traffic for you we'll let you go. |
"John R" wrote in message ... Quonset State (RI) airport (OQU) has class D airspace and is just south of Providence (PVD), which has class C airspace. The northern arc of the Class D airspace isn't charted with a dashed blue line, so the best I can do is assume that this boundary is coexistent with the Class C surface area. The "northern arc" isn't charted because that area which would otherwise be Class D if the PVD Class C airspace was not there is always Class C when the OQU Class D airspace is in effect. Some of the class D airspace is under Class C with a floor of 1700 feet, some under Class C with a floor of 1300 feet, and some is outside the Class C airspace. To make things confusing on the chart, the dividing line between the 1700' floor and 1300' floor is beneath the [25] Class D ceiling symbol. Yeah, one would think they could have done a better job of symbol placement. So according to the chart, the Class D airspace extends to 2500 feet. However, Quonset tower was sternly warning pilots the other day that their Class D only went to 1300 feet and not to exceed that without the blessing of Providence. So why does the chart say 2500 feet for the Class D inside the Class C ring? The standard ceiling for Class D airspace is 2500 AGL, but it's charted in MSL values. Since field elevation at OQU is just 18 MSL they're the same. Due to the hierarchy of airspace, the OQU Class D airspace reaches 2500 MSL only outside the ten mile PVD Class C ring. Inside the ring the Class D ceiling is the floor of the overlying Class C airspace. |
Recently, John R posted:
Quonset State (RI) airport (OQU) has class D airspace and is just south of Providence (PVD), which has class C airspace. The northern arc of the Class D airspace isn't charted with a dashed blue line, so the best I can do is assume that this boundary is coexistent with the Class C surface area. Some of the class D airspace is under Class C with a floor of 1700 feet, some under Class C with a floor of 1300 feet, and some is outside the Class C airspace. To make things confusing on the chart, the dividing line between the 1700' floor and 1300' floor is beneath the [25] Class D ceiling symbol. So according to the chart, the Class D airspace extends to 2500 feet. However, Quonset tower was sternly warning pilots the other day that their Class D only went to 1300 feet and not to exceed that without the blessing of Providence. So why does the chart say 2500 feet for the Class D inside the Class C ring? This airspace looks pretty confusing. For good measure there is a class E surface area for a PVD approach under the Class C ceiling inside the Class D ring, although we can assume that the E is only in affect inside the D circle when Quonset tower is closed. To be sure, the tower at Quonset keeps funny hours somewhat (e.g. closed Mondays). Some of the charts can be confusing, but as a matter of practicality, if you're flying in that area, you'd best be talking to ATC anyway. When I flew to Martha's Vineyard, my planned course was to go south of PVD and over Newport. Due to a lot of traffic and meat bombs at Newport, I was vectored north, then around quite a bit. That neck of the woods can get pretty busy! Neil |
| Thread Tools | |
| Display Modes | |
| NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 06:12 AM |
| AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 07:12 PM |
| AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Piloting | 12 | April 26th 04 07:12 PM |
| Violating Airspace with GPS | John Bell | Piloting | 57 | November 5th 03 09:25 PM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
