On Jan 31, 5:35*am, Mxsmanic wrote:
What is happening to the FAA? *The new Class B airspace at KPHX drives another few nails into the GA coffin. Huh? Why, explain. |
Mxsmanic wrote in
: writes: On Jan 31, 5:35*am, Mxsmanic wrote: What is happening to the FAA? *The new Class B airspace at KPHX drives another few nails into the GA coffin. Huh? Why, explain. Because it depends so much on moving-map navigation systems, How would you know fjukkwit? you don't fly. Bertie |
On Jan 31, 1:49*pm, Mxsmanic wrote:
writes: On Jan 31, 5:35*am, Mxsmanic wrote: What is happening to the FAA? *The new Class B airspace at KPHX drives another few nails into the GA coffin. Huh? Why, explain. Because it depends so much on moving-map navigation systems, rather than just VORs and radials or landmarks. *If you don't have a fancy glass display that shows exactly where you are, you can easily bust the Class B without realizing it. *In previous configurations, you could use PXR to keep you out of trouble through a large part of the airspace as long as you had a VOR receiver and DME. *Now you can't. *Given the cost of advanced moving-map systems, many GA aircraft aren't going to have them, and this new configuration seems to be a deliberate attempt to keep GA aircraft in this category out of the airspace. I think you are right if all above's 'you' will be replaced by 'Mxsmanic' -Kees |
Mxsmanic wrote:
writes: On Jan 31, 5:35?am, Mxsmanic wrote: What is happening to the FAA? ?The new Class B airspace at KPHX drives another few nails into the GA coffin. Huh? Why, explain. Because it depends so much on moving-map navigation systems, rather than just VORs and radials or landmarks. There isn't a class B in existance that depends on "just VORs and radials or landmarks". There is nothing special in the layout of that class B. There is some that feel the layout isn't optimal for the traffic in the area, but since you don't fly, what would you know about that? -- Jim Pennino Remove .spam.sux to reply. |
Mxsmanic wrote:
Because it depends so much on moving-map navigation systems, rather than just VORs and radials or landmarks. If you don't have a fancy glass display that shows exactly where you are, you can easily bust the Class B without realizing it. I have successfully navigated around the new curved portions of the PHX class B without a GPS, or a DME (hahaha!). Those of us that actually fly were taught how to navigate using a chart. It's no different from navigating around the class B before they changed it. You are a such a tool. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200801/1 |
* *I have successfully navigated around the new curved portions of the PHX
class B without a GPS, or a DME (hahaha!). * Those of us that actually fly were taught how to navigate using a chart. *It's no different from navigating around the class B before they changed it. Exactly. Being able to tell where you are with basic pilotage skills and a chart is an essential part of being a pilot, it's part of the PTS, and it's tested during the checkride. Well, you don't NEED a checkride for MSFS. |
How did KPHX Class B get so screwed up? | Larry Dighera | Piloting | 19 | February 2nd 08 09:49 AM |
Controller screwed up? | Paul Tomblin | Piloting | 51 | September 14th 07 09:59 PM |
PSS 747 Depature Route from KPHX | Thomas | Simulators | 0 | July 19th 04 11:52 AM |
Don't Want to be Screwed | [email protected] | Home Built | 5 | May 22nd 04 06:58 AM |
Changes At KPHX | Jay Beckman | Piloting | 5 | April 6th 04 03:31 PM |
