How did KPHX Class B get so screwed up?
Old January 31st 08, 09:28 AM posted to rec.aviation.piloting
Larry Dighera
Default How did KPHX Class B get so screwed up?
On Thu, 31 Jan 2008 05:35:40 +0100, Mxsmanic
wrote in :
The new Class B airspace at KPHX
http://skyvector.com/#32-25-3-3647-2226
It's a pistol.
But I think KSAN is even more difficult to visualize:
http://skyvector.com/#32-25-3-3647-2226 . It has VFR tunnels through
various Class B sectors.
Old January 31st 08, 01:47 PM posted to rec.aviation.piloting
Mxsmanic
Larry Dighera writes:
The VFR corridor at least follows the shoreline; conceivably one could
navigate through it just by looking at the ground.
There aren't any VFR corridors at all in Phoenix that I've noticed.
Old January 31st 08, 01:49 PM posted to rec.aviation.piloting,alt.usenet.kooks
Bertie the Bunyip[_25_]
Default How did Mxsmanic get so screwed up?
Mxsmanic wrote in
So what, fjukktard?
You don't fly.
Bertie
Old January 31st 08, 05:57 PM posted to rec.aviation.piloting
Larry Dighera
On Thu, 31 Jan 2008 13:47:23 +0100, Mxsmanic
wrote in :
I should have said Class E tunnels instead of VFR tunnels. Take a
look at the four sectors with DOUBLE floors and ceilings enclosed in
blue boxes he http://skyvector.com/#32-24-2-4904-4560
Old February 1st 08, 04:48 AM posted to rec.aviation.piloting
A Guy Called Tyketto
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Idiot. But then again, I wouldn't trust any children to learn
English from you, let alone French.
The answer is on the same site you glorify and probably smoke
choads from. I quote from the Phoenix TAC:
The *VFR TRANSITION ROUTE* over Phoenix Sky Harbor Int'l Airport is
based on Runway in use. 7s/8: use the West route. 25s/26, use the East
route.
Next to it? details on the transition routes. On top of that,
the Canal Transition route.
Anthony, shut up. You obviously have no idea what you're
talking about.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.wizard.com/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.8 (GNU/Linux)
iD8DBQFHopZ5yBkZmuMZ8L8RAlkvAJwMy7ZXtV0jchMsN/9EMi/VHHXYqgCeLI6f
C1LP88eu+9NZlhC4nf10GdA=
=DKEm
-----END PGP SIGNATURE-----
Old February 1st 08, 04:50 PM posted to rec.aviation.piloting
Mxsmanic
A Guy Called Tyketto writes:
route.
A transition route isn't a corridor. A corridor is outside the Class B; a
transition route goes through it. Look at KSAN to see a true VFR corridor.
Old February 1st 08, 05:16 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Mxsmanic wrote in
East route.
B; a transition route goes through it. Look at KSAN to see a true VFR
corridor.
Why?
You don't fly...
Bertie
Old February 1st 08, 09:31 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 01 Feb 2008 16:50:12 +0100, Mxsmanic
wrote in :
route.
As long as we're on the subject, let's mention the LAX Special Flight
Rules Area directly over the airport between 3,500' and 4,500':
http://skyvector.com/perl/code?id=KLAX&scale=3 . It is a VFR route
through KLAX Class B surface area that doesn't require ATC
authorization nor communication with ATC!
There's an explanation of how to use it on the lower left hand corner
of the KLAX Terminal Control Area chart.
Old February 2nd 08, 04:12 AM posted to rec.aviation.piloting
Hash: SHA1
route.
Wrong. SFRA at LAX is a corridor and *IN THE CLASS B*.
Either get your facts straight, or plan to have a size 15 boot
shoved up your ass every time you open your moouth.
BL.
iD8DBQFHo9+AyBkZmuMZ8L8RAnjsAKCENgvaAGBgPskC7ZUh8r 4gYU5oEgCg5IpI
DWaoyhSFTQaQIJUJY4OEYjc=
=qV4d
Old February 2nd 08, 04:41 AM posted to rec.aviation.piloting
Mxsmanic
The SFRA at LAX is a SFRA, and so it is neither a corridor nor a transition
route.
Controller screwed up? Paul Tomblin Piloting 51 September 14th 07 10:59 PM
PSS 747 Depature Route from KPHX Thomas Simulators 0 July 19th 04 12:52 PM
Don't Want to be Screwed [email protected] Home Built 5 May 22nd 04 07:58 AM
Screwed by Helicopter Support Inc. Becky DeWind Owning 3 May 18th 04 02:14 PM
Changes At KPHX Jay Beckman Piloting 5 April 6th 04 04:31 PM
