I have some questions for Rotax users of 503, and 582 (583?) engines
who do their own maintenance. 1) How many special tools do you need to tear down these engines? 2) What are common problems encountered with the 2 stroke series? 3) Do they require consistent tinkering or are they pretty much good for the duration of the 300 hour TBO? Thanks |
![]() I have some questions for Rotax users of 503, and 582 (583?) engines who do their own maintenance. 1) How many special tools do you need to tear down these engines? Only a couple, wrist pin bearings are cageless. There is a tool to retain pins. Nothing like wondering if you got them all after you dump them down the case. And a gear puller. 2) What are common problems encountered with the 2 stroke series? The User is the biggest problem. Don't modify in anyway. Just use the recommended Stock jetting and carb settings, Use only the Manufactured recommend Pre-mix and Gearbox oils. Its when people think they know better and go outside extacly what the manufacture recommends is when they run into problems and start complaining about 2 strokes. 3) Do they require consistent tinkering or are they pretty much good for the duration of the 300 hour TBO? No there are very dependable and consistant. If you follow #2 and follow the manufactures inspect schedule, the bottom end has no problems going 400 hrs Thanks |
![]() "ULWA" wrote Use only the Manufactured recommend Pre-mix and Gearbox oils. By ALL MEANS, for goodness sake, LISTEN to this bit of advice, if you ignore EVERYTHING else. (not that you should ignore everything else; just pay attention to this one-don't use something else "close" to the right oil) I know for a fact that failure to use the __exact__ Rotax gearbox oil can cause you to ruin the bottom end of your engine. BTDT. -- Jim in NC |
By ALL MEANS, for *goodness sake, LISTEN to this bit of advice, if you
ignore EVERYTHING else. (not that you should ignore everything else; just pay attention to this one-don't use something else "close" to the right oil) I know for a fact that failure to use the __exact__ Rotax gearbox oil can cause you to ruin the bottom end of your engine. *BTDT. -- Jim in NC Thanks guys. Responses on matrox list say this is very important. Will do. |
On Mar 9, 12:33*am, wrote:
By ALL MEANS, for *goodness sake, LISTEN to this bit of advice, if you ignore EVERYTHING else. (not that you should ignore everything else; just pay attention to this one-don't use something else "close" to the right oil) I know for a fact that failure to use the __exact__ Rotax gearbox oil can cause you to ruin the bottom end of your engine. *BTDT. -- Jim in NC Thanks guys. Responses on matrox list say this is very important. Will do. er ... matronics (matrox == rotax + matronics) ![]() |
Rotax 912 questions | RPar | Home Built | 13 | February 12th 09 03:12 PM |
ROTAX 275 questions | Eric Greenwell | Soaring | 0 | January 6th 05 02:43 AM |
Questions Rotax Engines | Mark Smith | Home Built | 2 | August 13th 04 11:01 PM |
Kitfox 7/Rotax 914 Performance Questions | Jim Carriere | Home Built | 2 | January 22nd 04 04:55 PM |
Rotax 912 Questions | Steve Robertson | Home Built | 1 | November 14th 03 09:01 PM |
