Rotax 912 Questions
Old November 14th 03, 08:01 PM
Steve Robertson
Default Rotax 912 Questions
I'm a longtime pilot who is getting interested in building a plane. I've
got lots of experience flying (and paying for maintenance) behind
LyContisuarus engines, so that's all I understand.
Some of the designs I'm interested in recommend the Rotax 912 engine.
These seem to come equipped with twin Bing carbs. As far as I can tell,
these carbs don't have a mixture control for leaning the engine at
altitude. Am I correct? If so, has this been an operational problem with
these engines? Has this proved to be a reliable engine?
TIA,
Steve Robertson
N4732J 1967 Beechcraft A23-24 Musketeer
Old November 14th 03, 09:01 PM
Bart D. Hull
The Bing carbs your referring to are auto-leaning as the slide and needle
move up and down based on air velocity (Constant Velocity carbs.)
They use a butterfly before the slide to limit air intake to control engine
power.
They worked very well on the R75/5 and newer BMW R motorcycles here in Arizona
where we have pressure altitudes from 1000' to 9000' foot on the ground!
Let me know if you have any other questions on the Rotax. I flew quite a bit
behind on in a Dimona Katana. NICE engine and plane.
Bart D. Hull
Tempe, Arizona
Check
http://www.inficad.com/~bdhull/engine.html
for my Subaru Engine Conversion
Check http://www.inficad.com/~bdhull/fuselage.html
for Tango II I'm building.
TIA,
Steve Robertson
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
Rotax maintenance seminar Julien Mauroy Home Built 0 September 26th 03 03:23 AM
Jabiru V Rotax reliability? Joe Home Built 11 September 5th 03 11:09 AM
