On Sun, 27 Apr 2008 16:01:31 GMT, "Vaughn Simon"
wrote in : "Larry Dighera" wrote in message .. . If this is implemented, will it affect powered aircraft without electrical systems too? Almost certainly That's the way I saw it also. Here are a few pertinent questions: What are the full implications of installing an electrical system in a glider? If implemented, will the requirement for an electrical system kill low-cost glider training operations? Would the CAP glider training operations, which typically provide winch launch and pattern work, be impacted? What are the full implications of installing an electrical system in a Champ or Cub? Isn't their performance so marginal already, that they will become impractical due to increased empty weight and drag, and power reduction with the addition of an alternator, battery, communications radio, transponder, antennas, wiring, switches, etc? Would the work have to be done by an A&P and approved by the FAA for each aircraft/glider modified? Will aircraft/glider useful load be affected? How much does the gliders right-of-way over powered aircraft affect this issue? Not at all. So you don't believe there is any possibility that Part 121 or 135 operator advocate organizations have been lobbying the government to increase the conspicuity of gliders or to enable their TCAS systems to warn operators of glider proximity? What is the possibility of NextGen ATC accommodating non-metallic aircraft without electrical systems? Without transponders? Without radio communications? Any glider pilots who depends on powered aircraft to see them and to automatically get out of their way has a death wish. It's difficult to deny that. But it doesn't address the issue of liability. Right-of-way rules have two uses: 1) Provides a framework of preplanned manuvers for aircraft to use to avoid each other (but only if they both see each other, know the regulations, and are inclined to follow them). Actually, that is true if only one pilot makes visual contact too. And now the big one: (2) It provides lawers and bureaucrats with a methodology for assigning blame after an accident. So Right-of-way regulations provide a basis for aggrieved parties to seek compensation from regulation violators, and assign responsibility too. Is ATC going to take legal and financial responsibility for separation if gliders are mandated to be so equipped and operated? No more than they do now. I would find ATC's responsibility for separating NORDO gliders that paint no primary target to be nonexistent presently. If this proposal is enacted, the situation will change. Is the big-sky-theory a myth? It always has been a myth. At the risk of tangential drift, isn't the BST currently employed by the FAA to separate high-speed military aircraft on VFR low-level Military Training Routs from civil flights? In light of the mythical status of the BST, shouldn't that flaw in the NAS be corrected also? Vaughn Thank you for your insightful comments. |
![]() "Larry Dighera" wrote in message ... 1) Provides a framework of preplanned manuvers for aircraft to use to avoid each other (but only if they both see each other, know the regulations, and are inclined to follow them). Actually, that is true if only one pilot makes visual contact too. Not so. If the other plane does not see you, it can't be expected/trusted to behave according to the ROW regulations, so you can't know what it is going to do. There is usually little that you can do to get the other pilot's attention (you have no horn in an aircraft). So it is up to the pilot that DOES see the other to do whatever it takes to avoid a collision...regulations be dammed. In that situation, I usually manuver in such a way that I never lose sight of the other aircraft. If I happen to be driving a glider, my manuvering options are limited to left, right, and down. I probably can't climb, and I certainly can't outrun an oncoming airplane. Vaughn |
On Sun, 27 Apr 2008 18:55:53 GMT, "Vaughn Simon"
wrote in : "Larry Dighera" wrote in message .. . 1) Provides a framework of preplanned manuvers for aircraft to use to avoid each other (but only if they both see each other, know the regulations, and are inclined to follow them). Actually, that is true if only one pilot makes visual contact too. Not so. So if you see a glider in you path while piloting a powered aircraft, but its pilot doesn't see you, you don't give it the right of way? |
![]() "Larry Dighera" wrote in message ... On Sun, 27 Apr 2008 18:55:53 GMT, "Vaughn Simon" wrote in : "Larry Dighera" wrote in message . .. 1) Provides a framework of preplanned manuvers for aircraft to use to avoid each other (but only if they both see each other, know the regulations, and are inclined to follow them). Actually, that is true if only one pilot makes visual contact too. Not so. So if you see a glider in you path while piloting a powered aircraft, but its pilot doesn't see you, you don't give it the right of way? I said no such thing. Kindly go back and read what I wrote. Sorry, but I think you and I are done with this conversation. Vaughn |
In rec.aviation.soaring Larry Dighera wrote:
So if you see a glider in you path while piloting a powered aircraft, but its pilot doesn't see you, you don't give it the right of way? In my opinion, right of way is essentially useless when flying. There are three relevant situations: - You are on a collision course with another aircraft. You have the ROW. - You are on a collision course with another aircraft. He has the ROW. - You are on a collision course with another aircraft. Neither has the ROW. In all three situations the only reasonable thing to is the same: maneuver to avoid by any means necessary. Thus your inference is essentially backwards. Not only should the power plane get out of the way of the glider, but the glider should get out of the way of the power plane. -- Michael Ash Rogue Amoeba Software |
![]() "Larry Dighera" wrote in message ... So if you see a glider in you path while piloting a powered aircraft, but its pilot doesn't see you, you don't give it the right of way? So if you see a powered aircraft in you path while piloting a glider, but its pilot doesn't see you, do you expect it to yield the right-of-way? |
On Apr 28, 6:55*am, "Vaughn Simon"
wrote: "Larry Dighera" wrote in message ... 1) Provides a framework of preplanned manuvers for aircraft to use to avoid each other (but only if they both see each other, know the regulations, and are inclined to follow them). Actually, that is true if only one pilot makes visual contact too. * *Not so. * *If the other plane does not see you, it can't be expected/trusted to behave according to the ROW regulations, so you can't know what it is going to do.. There is usually little that you can do to get the other pilot's attention (you have no horn in an aircraft). *So it is up to the pilot that DOES see the other to do whatever it takes to avoid a collision...regulations be dammed. In that situation, I usually manuver in such a way that I never lose sight of the other aircraft. *If I happen to be driving a glider, my manuvering options are limited to left, right, and down. *I probably can't climb, and I certainly can't outrun an oncoming airplane. To give way you must turn to the right. You can certainly dive fast and turn as well if you really wan't to generate a big separation. But remember he won't see you as easily if you go below him.. Radio calls? Cheers |
Larry.. DO you fly gliders?
From these statements it would appear that you do not. Gliders may or may not have electrical systems, they do not "generate power", but stored battery power of a limited life span. Gliders are small, batteries are small, everything needs to be small. NTSB "recommends", FAA cannot mandate without a comment period and a change to many CFRs. Technology is coming for the small transponder, along with ATS-B. Why would I put a 50# $15K ATS-B system in a $15K glider. Small transponders now are about $1300 plus antenna and installation. It can be done. My issue is not with TCAS equipped aircraft, but with smaller GA aircraft that do not have TCAS, do not have a Garmin 430 with TIS (or equivalent) and are not talking to ATC. It does no good to have a transponder, when the aircraft causing the traffic conflict is not talking to anyone. Just sitting there FDH and not even paying attention in the traffic pattern. Last Saturday we had at least 4 transient aircraft attempt to land at the airport with 15 to 20 knot tail winds, and against the flow of traffic. They could not even listen up to the radio to figure out the runway in use, or even look at a wind sock or a huge flag and see the 15knt winds and make up their own mind about the landing runway. What makes you think a transponder in a glider would make any difference. And local ATC can see my non-transponder equipped glider just fine, when I am high enough for radar coverage. It's called raw radar skin paint. And yes, I am looking at the requirements (Not Govt' requirement but electical and space in the aircraft requirements) and feasibility for installing transponders in our gliders. B "Larry Dighera" wrote in message ... On Sun, 27 Apr 2008 16:01:31 GMT, "Vaughn Simon" wrote in : "Larry Dighera" wrote in message . .. If this is implemented, will it affect powered aircraft without electrical systems too? Almost certainly That's the way I saw it also. Here are a few pertinent questions: What are the full implications of installing an electrical system in a glider? If implemented, will the requirement for an electrical system kill low-cost glider training operations? Would the CAP glider training operations, which typically provide winch launch and pattern work, be impacted? What are the full implications of installing an electrical system in a Champ or Cub? Isn't their performance so marginal already, that they will become impractical due to increased empty weight and drag, and power reduction with the addition of an alternator, battery, communications radio, transponder, antennas, wiring, switches, etc? Would the work have to be done by an A&P and approved by the FAA for each aircraft/glider modified? Will aircraft/glider useful load be affected? How much does the gliders right-of-way over powered aircraft affect this issue? Not at all. So you don't believe there is any possibility that Part 121 or 135 operator advocate organizations have been lobbying the government to increase the conspicuity of gliders or to enable their TCAS systems to warn operators of glider proximity? What is the possibility of NextGen ATC accommodating non-metallic aircraft without electrical systems? Without transponders? Without radio communications? Any glider pilots who depends on powered aircraft to see them and to automatically get out of their way has a death wish. It's difficult to deny that. But it doesn't address the issue of liability. Right-of-way rules have two uses: 1) Provides a framework of preplanned manuvers for aircraft to use to avoid each other (but only if they both see each other, know the regulations, and are inclined to follow them). Actually, that is true if only one pilot makes visual contact too. And now the big one: (2) It provides lawers and bureaucrats with a methodology for assigning blame after an accident. So Right-of-way regulations provide a basis for aggrieved parties to seek compensation from regulation violators, and assign responsibility too. Is ATC going to take legal and financial responsibility for separation if gliders are mandated to be so equipped and operated? No more than they do now. I would find ATC's responsibility for separating NORDO gliders that paint no primary target to be nonexistent presently. If this proposal is enacted, the situation will change. Is the big-sky-theory a myth? It always has been a myth. At the risk of tangential drift, isn't the BST currently employed by the FAA to separate high-speed military aircraft on VFR low-level Military Training Routs from civil flights? In light of the mythical status of the BST, shouldn't that flaw in the NAS be corrected also? Vaughn Thank you for your insightful comments. |
BT wrote:
Small transponders now are about $1300 plus antenna and installation. It can be done. That's a great price! Where do you get these? What brand? The ones I know about (Becker, Microair) are $1900 plus $200 for the encoder. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Thanx Eric.. it's been a while since I checked.. I remember 13 but that may
have been the crappy Becker Radio. Had two.. both went back for repairs.. and I know at least one Becker Transponder had to go back too. BT "Eric Greenwell" wrote in message news:RIdRj.174$1m3.73@trndny02... BT wrote: Small transponders now are about $1300 plus antenna and installation. It can be done. That's a great price! Where do you get these? What brand? The ones I know about (Becker, Microair) are $1900 plus $200 for the encoder. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Feds Want to Equipe Gliders With Transponders and Radios | Larry Dighera | Piloting | 155 | May 10th 08 02:45 PM |
Gliders, transponders, and MOAs | Greg Arnold | Soaring | 2 | May 26th 06 05:13 PM |
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* | JStONGE123 | Military Aviation | 1 | May 11th 04 06:22 AM |
Transponders and Radios - USA | Ray Lovinggood | Soaring | 1 | February 27th 04 06:10 PM |
Transponders, Radios and other avionics procurement questions | Corky Scott | Home Built | 5 | July 2nd 03 11:27 PM |
