If this is implemented, will it affect powered aircraft without electrical systems too? How much does the gliders right-of-way over powered aircraft affect this issue? Is ATC going to take legal and financial responsibility for separation if gliders are mandated to be so equipped and operated? Is the big-sky-theory a myth? ---------------------------------------- http://www.examiner.com/a-1314730~Fe...Gliders.ht ml Feds Call for Alerts on All Air Gliders Apr 1, 2008 5:28 PM (25 days ago) By SCOTT SONNER, AP RENO, Nev. (Map, News) - All gliders should be required to operate with devices that alert air traffic controllers and other aircraft to their presence, federal regulators recommended Tuesday, citing 60 near-collisions over the past two decades. Gliders and other aircraft without engine-driven electrical systems are exempt from a rule the Federal Aviation Administration imposed in 1988 requiring transponders for aircraft that operate near primary airports and in airspace above 10,000 feet. NTSB Chairman Mark Rosenker recommended in a March 31 letter to the board that the glider exemption be eliminated in part because of an NTSB investigation into a collision between a glider and a private jet about 40 miles southeast of Reno in August 2006. In that case, the glider pilot - who parachuted to safety - had a transponder on his aircraft but had turned it off to conserve battery power. The Hawker 800XP airplane he collided with was significantly damaged but was able to land safely at Reno-Tahoe International Airport. "As evidenced by this accident, aircraft that are not using or not equipped with transponders and are operating in areas transited by air carrier traffic represent a collision hazard," Rosenker wrote in the letter first made public on Tuesday. "This hazard has persisted more than 20 years since the Safety Board initially expressed concern," he said. Many gliders object to required use of transponders, saying they are expensive and energy-consuming. Of the 60 near mid-air collisions from 1988 to 2007, nine occurred in northern Nevada. That's due primarily to the large number of gliders that fly along the Sierra's eastern front where thermal air flows create what enthusiasts describe as "world-class" gliding conditions. Other frequent sites of near-collisions were Chicago and Washington, D.C., with four each. Colorado Springs, Colo., had three. More than 10 years before the latest incident, the FAA's Reno Flight Standards District Office... The FAA has 90 days to respond to the NTSB's recommendations, FAA spokesman Ian Gregor said. "We take NTSB recommendations very seriously," he said from Los Angeles. Leaders of the Soaring Society of America, based in Hobbs, N.M., and other gliding enthusiasts oppose the NTSB's move. They advocate alternatives including increasing awareness among pilots of areas where gliders are often in use and implementing technology already used in some parts of Europe that provides low-cost, real-time information to pilots.... Most modern gliders have solar-powered batteries that help conserve power, but even those don't help on longer flights, which can stretch eight hours and cover 500 miles, he said. "Having a transponder on all the time becomes a real problem with energy conservation on your glider," he said. Fred La Sor, an owner of Soaring NV in Minden who helped develop new safety plans for the Reno area after the last accident, said it costs $2,200 to $3,000 to put transponders on most gliders. Besides, he said, most collisions or close calls involve not a glider and a jet, but two gliders - something he said transponders would not affect. |
"Larry Dighera" wrote in message ... If this is implemented, will it affect powered aircraft without electrical systems too? Almost certainly How much does the gliders right-of-way over powered aircraft affect this issue? Not at all. Any glider pilots who depends on powered aircraft to see them and to automatically get out of their way has a death wish. Right-of-way rules have two uses: 1) Provides a framework of preplanned manuvers for aircraft to use to avoid each other (but only if they both see each other, know the regulations, and are inclined to follow them). And now the big one: (2) It provides lawers and bureaucrats with a methodology for assigning blame after an accident. Is ATC going to take legal and financial responsibility for separation if gliders are mandated to be so equipped and operated? No more than they do now. Is the big-sky-theory a myth? It always has been a myth. Vaughn |
On Apr 27, 12:01 pm, "Vaughn Simon"
wrote: "Larry Dighera" wrote in message ... If this is implemented, will it affect powered aircraft without electrical systems too? Almost certainly How much does the gliders right-of-way over powered aircraft affect this issue? Not at all. Any glider pilots who depends on powered aircraft to see them and to automatically get out of their way has a death wish. Right-of-way rules have two uses: 1) Provides a framework of preplanned manuvers for aircraft to use to avoid each other (but only if they both see each other, know the regulations, and are inclined to follow them). And now the big one: (2) It provides lawers and bureaucrats with a methodology for assigning blame after an accident. Is ATC going to take legal and financial responsibility for separation if gliders are mandated to be so equipped and operated? No more than they do now. Is the big-sky-theory a myth? It always has been a myth. No it is not a myth. If you evenly spread the number of GA aircraft below 12,000 ft across the U.S all traveling at random directions, the probability of collision will be extremely low enough to be considered zero. The problem is that the big sky theory does not apply near terminal airspace where the airplanes are not traveling in random directions and altitudes. The spirit of the original transponder exemption was to allow for older airplanes that were manufactured before the days electrical avionics became commonplace. So I can see the justification for this proposal. However, a full blown mode C transponder may not be necessary. A radar reflector like they use on weather balloon ought be sufficient. It is just a piece of foil with a large cross section. |
On Sun, 27 Apr 2008 10:09:57 -0700 (PDT), Andrew Sarangan
wrote in : On Apr 27, 12:01 pm, "Vaughn Simon" wrote: "Larry Dighera" wrote in message ... Is the big-sky-theory a myth? It always has been a myth. No it is not a myth. If you evenly spread the number of GA aircraft below 12,000 ft across the U.S all traveling at random directions, the probability of collision will be extremely low enough to be considered zero. The problem is that the big sky theory does not apply near terminal airspace where the airplanes are not traveling in random directions and altitudes. It also doesn't apply within 150 miles of Los Angeles, and I'd venture, to other areas of large population concentrations, nor near navaids, nor airports (controlled or not), nor islands, ... In fact, in today's aerial environment, the Big-Sky-Theory is not only a myth, but a recipe for disaster, IMO. The spirit of the original transponder exemption was to allow for older airplanes that were manufactured before the days electrical avionics became commonplace. So I can see the justification for this proposal. What is it that you see? Is it the necessity to outlaw all aircraft that were certified without electrical systems from operation within the NAS? However, a full blown mode C transponder may not be necessary. A radar reflector like they use on weather balloon ought be sufficient. It is just a piece of foil with a large cross section. That's a constructive suggestion. How large must such a radar reflector be? Will it activate TCAS? Does ATC normally enable the display of primary targets? |
On Apr 28, 6:02*am, Larry Dighera wrote:
On Sun, 27 Apr 2008 10:09:57 -0700 (PDT), Andrew Sarangan wrote in : On Apr 27, 12:01 pm, "Vaughn Simon" wrote: "Larry Dighera" wrote in message . .. Is the big-sky-theory a myth? * *It always has been a myth. No it is not a myth. If you evenly spread the number of GA aircraft below 12,000 ft across the U.S all traveling at random directions, the probability of collision will be extremely low enough to be considered zero. The problem is that the big sky theory does not apply near terminal airspace where the airplanes are not traveling in random directions and altitudes. It also doesn't apply within 150 miles of Los Angeles, and I'd venture, to other areas of large population concentrations, nor near navaids, nor airports (controlled or not), nor islands, ... *In fact, in today's aerial environment, the Big-Sky-Theory is not only a myth, but a recipe for disaster, IMO. The spirit of the original transponder exemption was to allow for older airplanes that were manufactured before the days electrical avionics became commonplace. So I can see the justification for this proposal. What is it that you see? *Is it the necessity to outlaw all aircraft that were certified without electrical systems from operation within the NAS? * However, a full blown mode C transponder may not be necessary. A radar reflector like they use on weather balloon ought be sufficient. It is just a piece of foil with a large cross section. That's a constructive suggestion. * How large must such a radar reflector be? * It's a retroreflector, I have one in the form of a tube about 3 inches in diameter and 2 feet long. The corner cubes are inside that. I have no idea how effective it is compared to a classic reflector which occupies a cube about 1 foot across and retroreflects the radar equally in all directions. ... Will it activate TCAS? * Don't see how it could, TCAS uses the information in the active return from the transponder. Does ATC normally enable the display of primary targets? As fas as I know ATC radar picks up as many moving targets as it cam "see". Not sure what you mean by primary tho'. Cheers |
WingFlaps wrote ...
As fas as I know ATC radar picks up as many moving targets as it can "see". Not sure what you mean by primary tho'. OK then, time to pick up the AIM and look at Chapter 4, Section 5.1, or look here (courtousy of the gov't nobody wants to pay for) in 4.5.1: http://www.faa.gov/airports_airtraff...ns/atpubs/aim/ Check for the diff between Primary and Secondary radar. FYI: Before 1998 the controllers in NY Center would routinely keep the primary intensity dialed way down on their scopes, to a point where primary targets could not be seen unless you were really looking for one. The reason was too many the false reflections (heck, trucks on the bridges and interstate overpasses would show up). I don't know much after they moved onto the new scopes, and I can guess that after 9/11 it's all different now (maybe). |
On Sun, 27 Apr 2008 12:34:55 -0700 (PDT), WingFlaps
wrote in : A radar reflector like they use on weather balloon ought be sufficient. It is just a piece of foil with a large cross section. That's a constructive suggestion. * How large must such a radar reflector be? * It's a retroreflector, I have one in the form of a tube about 3 inches in diameter and 2 feet long. The corner cubes are inside that. I have no idea how effective it is compared to a classic reflector which occupies a cube about 1 foot across and retroreflects the radar equally in all directions. ... Interesting. Thanks for the information. How do you think it might affect a sailplane's L/D? More information: Marine passive radar reflectors: http://www.sailgb.com/c/radar_reflectors/ Modulating retro-reflector as a passive radar transponder http://ieeexplore.ieee.org/xpl/freea...isnumber=15618 Will it activate TCAS? * Don't see how it could, TCAS uses the information in the active return from the transponder. Yep. Does ATC normally enable the display of primary targets? As fas as I know ATC radar picks up as many moving targets as it cam "see". Not sure what you mean by primary tho'. By 'primary' I mean the radio energy passively reflected by the target, as opposed to a target generated as a result of a transponder interrogation. I know ATC can 'see' primary targets, but I am under the impression that controllers normally configure their 'scopes to see only transponder targets to reduce screen clutter. In any event, a passive radar reflector (or two) might be made part of a system to address this issue, but I'm guessing the FAA would prefer something capable of alerting TCAS systems. |
On Apr 27, 2:02 pm, Larry Dighera wrote:
On Sun, 27 Apr 2008 10:09:57 -0700 (PDT), Andrew Sarangan wrote in : On Apr 27, 12:01 pm, "Vaughn Simon" wrote: "Larry Dighera" wrote in message . .. Is the big-sky-theory a myth? It always has been a myth. No it is not a myth. If you evenly spread the number of GA aircraft below 12,000 ft across the U.S all traveling at random directions, the probability of collision will be extremely low enough to be considered zero. The problem is that the big sky theory does not apply near terminal airspace where the airplanes are not traveling in random directions and altitudes. It also doesn't apply within 150 miles of Los Angeles, and I'd venture, to other areas of large population concentrations, nor near navaids, nor airports (controlled or not), nor islands, ... In fact, in today's aerial environment, the Big-Sky-Theory is not only a myth, but a recipe for disaster, IMO. The spirit of the original transponder exemption was to allow for older airplanes that were manufactured before the days electrical avionics became commonplace. So I can see the justification for this proposal. What is it that you see? Is it the necessity to outlaw all aircraft that were certified without electrical systems from operation within the NAS? I think the FAR can be justifiably modified to only exempt airplanes originally manufactured with no electrical system, but all airplanes manufactured since 2008 (or whenever) operating in airspace where a transponder is required should be equipped with one. |
"Andrew Sarangan" wrote in message ... On Apr 27, 2:02 pm, Larry Dighera wrote: I think the FAR can be justifiably modified to only exempt airplanes originally manufactured with no electrical system, but all airplanes manufactured since 2008 (or whenever) operating in airspace where a transponder is required should be equipped with one. But not all aircraft are required to have a transponder in all categories of airspace... Sure.. all AIRPLANES with electrical generating systems should have a transponder, but not all AIRCRAFT have electrical generating systems. Even ones built today, sort of a Catch-22. B |
"Larry Dighera" wrote in message ... However, a full blown mode C transponder may not be necessary. A radar reflector like they use on weather balloon ought be sufficient. It is just a piece of foil with a large cross section. That's a constructive suggestion. How large must such a radar reflector be? Will it activate TCAS? No. Does ATC normally enable the display of primary targets? Outside of Class A airspace, yes. |
| Thread Tools | |
| Display Modes | |
| Gliders, transponders, and MOAs | Greg Arnold | Soaring | 2 | May 26th 06 06:13 PM |
| Cessna forced down by the Feds | C J Campbell | Piloting | 51 | February 8th 05 02:29 PM |
| U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* | JStONGE123 | Military Aviation | 1 | May 11th 04 07:22 AM |
| Transponders and Radios - USA | Ray Lovinggood | Soaring | 1 | February 27th 04 07:10 PM |
| Transponders, Radios and other avionics procurement questions | Corky Scott | Home Built | 5 | July 3rd 03 12:27 AM |
