Having to reject the last nicropress
on the rudder, two strands were cut when the nircopress was cut off with a drmel tool. The question is whether we can reinstall a nicropress in the original position and then add one an 1/8" further?? or, Make splice two lengths of control cable with double nicropresses?? or, Is there any reason why a turnbuckle couldn't be used ouitside the fuselage at the rudder?? Thanks |
![]() "Dick" wrote in message news:g06Uj.5548$0L.5089@trnddc07... Having to reject the last nicropress on the rudder, two strands were cut when the nircopress was cut off with a drmel tool. The question is whether we can reinstall a nicropress in the original position and then add one an 1/8" further?? or, Make splice two lengths of control cable with double nicropresses?? or, Is there any reason why a turnbuckle couldn't be used ouitside the fuselage at the rudder?? Thanks A big pair of end nippers is a very useful tool when you need to remove nicopress sleeves. Too late now, of course. Tim Ward |
we were able to dremel down the center between the two cable segments but
removing the halfs apparently caused the damage. Hope someone has some advise as the Bingelis books don't address repairs... thanks "Tim Ward" wrote in message ... "Dick" wrote in message news:g06Uj.5548$0L.5089@trnddc07... Having to reject the last nicropress on the rudder, two strands were cut when the nircopress was cut off with a drmel tool. The question is whether we can reinstall a nicropress in the original position and then add one an 1/8" further?? or, Make splice two lengths of control cable with double nicropresses?? or, Is there any reason why a turnbuckle couldn't be used ouitside the fuselage at the rudder?? Thanks A big pair of end nippers is a very useful tool when you need to remove nicopress sleeves. Too late now, of course. Tim Ward |
On Wed, 07 May 2008 10:47:59 GMT, "Dick" wrote:
we were able to dremel down the center between the two cable segments but removing the halfs apparently caused the damage. Hope someone has some advise as the Bingelis books don't address repairs... thanks "Tim Ward" wrote in message ... "Dick" wrote in message news:g06Uj.5548$0L.5089@trnddc07... Having to reject the last nicropress on the rudder, two strands were cut when the nircopress was cut off with a drmel tool. The question is whether we can reinstall a nicropress in the original position and then add one an 1/8" further?? or, Make splice two lengths of control cable with double nicropresses?? or, Is there any reason why a turnbuckle couldn't be used ouitside the fuselage at the rudder?? Thanks A big pair of end nippers is a very useful tool when you need to remove nicopress sleeves. Too late now, of course. Tim Ward there are swaged ends available that would correct your problem. they require a swaging machine to fit them though. they are about 3 inches long look for ms20667 fork end, or ms20668 eye end, or ms21259 stud end. or even an ms21260 turnbuckle end. they are in the aircraft spruce cattledog. Stealth Pilot |
If it was my plane I'd throw the cable away and start over. Hiding the
2 broken strands under a new nico is a bad idea but adding a splice or turnbuckle would work. Cable is cheap though so why not just change the whole thing. As screw ups go that's only a little one. On Wed, 07 May 2008 10:47:59 GMT, "Dick" wrote: we were able to dremel down the center between the two cable segments but removing the halfs apparently caused the damage. Hope someone has some advise as the Bingelis books don't address repairs... thanks "Tim Ward" wrote in message ... "Dick" wrote in message news:g06Uj.5548$0L.5089@trnddc07... Having to reject the last nicropress on the rudder, two strands were cut when the nircopress was cut off with a drmel tool. The question is whether we can reinstall a nicropress in the original position and then add one an 1/8" further?? or, Make splice two lengths of control cable with double nicropresses?? or, Is there any reason why a turnbuckle couldn't be used ouitside the fuselage at the rudder?? Thanks A big pair of end nippers is a very useful tool when you need to remove nicopress sleeves. Too late now, of course. Tim Ward |
agreed, no hiding strands. however with all three of us big, heavy, stiff
guys, we can't get inside the fuselage G "Drew Dalgleish" wrote in message ... If it was my plane I'd throw the cable away and start over. Hiding the 2 broken strands under a new nico is a bad idea but adding a splice or turnbuckle would work. Cable is cheap though so why not just change the whole thing. As screw ups go that's only a little one. On Wed, 07 May 2008 10:47:59 GMT, "Dick" wrote: we were able to dremel down the center between the two cable segments but removing the halfs apparently caused the damage. Hope someone has some advise as the Bingelis books don't address repairs... thanks "Tim Ward" wrote in message ... "Dick" wrote in message news:g06Uj.5548$0L.5089@trnddc07... Having to reject the last nicropress on the rudder, two strands were cut when the nircopress was cut off with a drmel tool. The question is whether we can reinstall a nicropress in the original position and then add one an 1/8" further?? or, Make splice two lengths of control cable with double nicropresses?? or, Is there any reason why a turnbuckle couldn't be used ouitside the fuselage at the rudder?? Thanks A big pair of end nippers is a very useful tool when you need to remove nicopress sleeves. Too late now, of course. Tim Ward |
On 2008-05-07, Dick wrote:
agreed, no hiding strands. however with all three of us big, heavy, stiff guys, we can't get inside the fuselage G Can you use the old cable as a fish tape to pull the new cable through? -- Jay Maynard, K5ZC http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (FRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June) |
Dick wrote:
Having to reject the last nicropress on the rudder, two strands were cut when the nircopress was cut off with a drmel tool. The question is whether we can reinstall a nicropress in the original position and then add one an 1/8" further?? or, Make splice two lengths of control cable with double nicropresses?? or, Is there any reason why a turnbuckle couldn't be used ouitside the fuselage at the rudder?? Thanks A turnbuckle is outside the fuselage at the rudder horn is in the design of the Zenith 601XL so if it doesn't get binded in anyway you should be OK. |
now there's the answer I wanted. Just out of curiosity, what connection
method is used at the rudder pedals. thanks "Gig 601Xl Builder" wrote in message m... Dick wrote: Having to reject the last nicropress on the rudder, two strands were cut when the nircopress was cut off with a drmel tool. The question is whether we can reinstall a nicropress in the original position and then add one an 1/8" further?? or, Make splice two lengths of control cable with double nicropresses?? or, Is there any reason why a turnbuckle couldn't be used ouitside the fuselage at the rudder?? Thanks A turnbuckle is outside the fuselage at the rudder horn is in the design of the Zenith 601XL so if it doesn't get binded in anyway you should be OK. |
Dick wrote:
now there's the answer I wanted. Just out of curiosity, what connection method is used at the rudder pedals. thanks I don't have my plans here at the office they are at the airport but I THINK. It is an AN115-21 cable shackle. If someone else doesn't pop up with the answer shortly I can find out for you. |
control cable protection question | Dick[_1_] | Home Built | 11 | March 13th 08 11:31 PM |
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | Home Built | 6 | October 15th 04 08:51 PM |
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | General Aviation | 0 | October 12th 04 05:11 PM |
You Want Control? You Can't Handle Control! -- Was 140 dead | ArtKramr | Military Aviation | 0 | March 2nd 04 08:48 PM |
Mig-29 questions & general aviation questions 2003 | Steven | Military Aviation | 1 | October 20th 03 06:06 AM |
