control cable protection question
Old March 12th 08, 01:22 AM posted to rec.aviation.homebuilt
Dick[_1_]
Default control cable protection question
Wanting to use a nylon sleeve over a 1/8" elevator cable to avoid rubbing on
another crossing in mid-fuselage, what do you think about the following
methods of securing the sleeve/tube so it doesn't slip out of position:
slip sleeve over RTV'd cable section; clamp sleeve ends with safety wire;
suggestion...
Old March 12th 08, 02:33 PM posted to rec.aviation.homebuilt
Peter Dohm
"Dick" wrote in message
news:cfGBj.17591$er2.16977@trnddc08...
on another crossing in mid-fuselage, what do you think about the following
suggestion...
Beyond the obvious, that this should have been addressed in the plans, my
first suggestion is to ask one of your chapter's technical advisors.
There is much more to the EAA than Sport Aviation, although this issue may
well have been addressed in a back issue of one of their magazines, and the
chapter system may well be the true backbone of the organization and the
entire movement. They also operate a bookstore, and it is very likely that
this issue was addressed in one of Tony Bingelis' (sp?) books.
Going back to your original question, although I am not a mechanic, I have
normally seem this roblem addressed by the use of "fair leads" attached to
the structure. The issue is certainly addressed in Part 43, so that any
mechanic will have a reference source, and may be in "AC 43.13.2A" which can
be obtaied from:
http://rgl.faa.gov/Regulatory_and_Gu...2?OpenDocument
and you can just past the AC number into Google if the link is too long.
BTW, your proposed method looks like a dangerous source of both binding and
corrosion--at least to me.
Peter
Old March 12th 08, 02:37 PM posted to rec.aviation.homebuilt
jerry wass
suggestion...
Use heat shrink electrical tube to secure sleeve----Some RTV sealants
are corrosive--especially if they smell like vinegar!
I've seen teflon tubing for sale somewhere---maybe electrical suppliers?
Old March 12th 08, 05:42 PM posted to rec.aviation.homebuilt
Dick[_1_]
thanks, I just forgot about heat shrink tubing and didn't know about vingery
smelling RTV..
"Jerry Wass" wrote in message
. net...
following methods of securing the sleeve/tube so it doesn't slip out of
position:
wire; suggestion...
Use heat shrink electrical tube to secure sleeve----Some RTV sealants are
Old March 12th 08, 11:18 PM posted to rec.aviation.homebuilt
Peter
And an uninspectable spot. It's unorthodox, at least, and should
be avoided. The cables need to be rerouted via fairleads or rubbing
blocks to separate them, not sleeved.
Dan
Old March 13th 08, 12:37 PM posted to rec.aviation.homebuilt
Dick[_1_]
actually fuselage belly has an inspection/access cover. Thanks though.
and
Peter
Dan
Old March 13th 08, 03:02 PM posted to rec.aviation.homebuilt
On Mar 13, 6:37 am, "Dick" wrote:
actually fuselage belly has an inspection/access cover. Thanks wrote in message
and
Peter
Dan
I meant that the cable itself, with a sleeve over it, would
not be inspectable through that area. Any corrosion or fraying would
go unnoticed.
Dan
Old March 13th 08, 03:58 PM posted to rec.aviation.homebuilt
Bob Kuykendall
On Mar 12, 7:33*am, "Peter Dohm" wrote:
...Going back to your original question, although I am not a mechanic, I have
the structure...
That's the way I'd approach it as well. The sleeve thing sounds sort
of hokey, and I'm sure it'd look sort of hokey, and it has the
inspection issue against it. I take primary flight control systems
fairly seriously, and I consider pitch to be the most important of the
primaries.
My preference would be to attach fairlead thingies like these to the
structure to guide both cables where they threaten to rub:
http://www.aircraftspruce.com/catalo.../fairleads.php
I remember replacing them on gliders such as Schweizer 2-33, except
that back in the day they were some sort of dense, oil-impregnated
wood. The nylon will last longer and probably cause less cable wear.
AC43.13 para 7-149-n suggests that the cable angle change at a
fairlead be no greater than 3 degrees, and that's probably a good
guideline for a tensioned cable. Much more than that, and the fairlead
wears through rather quickly. Better to use a pulley then.
Thanks, Bob K.
Old March 13th 08, 09:03 PM posted to rec.aviation.homebuilt
Highflyer
news:Ud9Cj.19481$er2.14960@trnddc08...
and
Peter
Dan
An access cover in the belly does NOT make the cables inspectable when they
are covered by a sleeve. Can you detect broken strands?
Separate them positively with a pulley or fairleads please. It doesn't add
much weight and will prevent all kinds of wear and corrosion problems while
remaining inspectable.
Highflyer
EAA Technical Counselor
FAA Technical Safety Counselor
Old March 13th 08, 10:40 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
and
Peter
Dan
Highflyer
I know that everyone wants to think that homebuilts are built better
than anything else, but I've seen this kind of thing too often to
accept that wisdom.
To the OP, a teflon or delrin (high density plastic fairlead would be
the proper way to protect a cable from chaffing.
Saturday 072807 in Oshkosh Pt 5 - the US Customs and Border Protection Blackhawk [4/5] - "04 Blackhawk--rapelling in front of what won't be the World's Busiest Control Tower much longer .jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 07:31 PM
Control surface design question Chris W Home Built 16 July 30th 07 04:17 AM
Question on Baron 58 prop control Mxsmanic Piloting 62 December 3rd 06 05:26 AM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 05:11 PM
rudder cable question Bob Loer Home Built 7 November 26th 03 08:34 AM
