Flexible exhaust tubing
Old July 9th 08, 02:21 AM posted to rec.aviation.homebuilt
Stuart & Kathryn Fields
Default Flexible exhaust tubing
I'm looking for a source of 1 1/2" flexible exhaust tubing. Mild steel is
acceptable. I want to use it for a model of the headers of a tuned exhaust
for my 0320 Lycoming engine that I have mounted in my Baby Belle helicopter.
The idea is to have 4 equal length pieces attached to exhaust flanges bolted
to the cylinders, arrange the 4 pieces to intercept the 4-into-1 collector,
coat the tubing with epoxy resin so that the shape is maintained and then
present these pieces to be copied by the exhaust bender.
Stu
Old July 9th 08, 03:10 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Stu
I did one a long time ago using elbows and pieces.
(Couldn't spend money on it, so)
To "measure" the pipes, I filled the sample pipe with water
and measured the volumn of water for each pipe.
Lengthen the short ones, shorten the long ones.
It was a bit of a hassle, but it did work ok.
For what it's worth...
Richard
Old July 9th 08, 04:09 PM posted to rec.aviation.homebuilt
"cavelamb himself" wrote in message
news
is acceptable. I want to use it for a model of the headers of a tuned
exhaust for my 0320 Lycoming engine that I have mounted in my Baby Belle
helicopter. The idea is to have 4 equal length pieces attached to exhaust
flanges bolted to the cylinders, arrange the 4 pieces to intercept the
4-into-1 collector, coat the tubing with epoxy resin so that the shape is
maintained and then present these pieces to be copied by the exhaust
bender.
Stu
Richard
Thanks for the tip on measuring the pipe length using water. Neat.
Stu
Old July 9th 08, 11:14 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Tue, 8 Jul 2008 18:21:43 -0700, "Stuart & Kathryn Fields"
Stu
hey stewie go down to the local electrical place and buy yourself 4
vacuum cleaners, or find a 'vacuums are us' and buy 4 replacement
flexible wands. they are plastic, are flexible and are the diameter
you need.
good luck on the chopper.
btw I have seen an RV6 that used 4 pipes into one with no muffler at
all. it was the quietest aeroplane engine I've ever heard. I dont know
what the trick was in the geometry but it used the same engine as you
are using. some amazing stuff is possible there.
Stealth Pilot
Old July 9th 08, 04:12 PM posted to rec.aviation.homebuilt
"Stealth Pilot" wrote in message
exhaust
helicopter.
bolted
collector,
Stu
you need.
Stealth Pilot
Interesting idea If the flexible wands hold their shape to a reasonable
degree we may have a solution.
Stu
Old July 10th 08, 02:49 PM posted to rec.aviation.homebuilt
Ernest Christley
you need.
Stealth Pilot
Stu
Stiffen the hose with a piece of 14-3 house wiring running through the center. Or encapsulate the shaped tube in about
3 layers of cheap duct tape.
Old July 9th 08, 01:51 PM posted to rec.aviation.homebuilt
Ernest Christley
Stu
Nylon hose is cheaper. Shape it to where you want it, drill a 1/4" hole every few inches and pump it full of
Great-Stuff spray foam.
PVC tubing will also form fairly well if you warm it up good with a heat gun.
Old July 9th 08, 03:49 PM posted to rec.aviation.homebuilt
RST Engineering
Clothes dryer ducting.
"It is the mark of an educated mind to be able to entertain a thought
without accepting it."
--Aristotle
"Stuart & Kathryn Fields" wrote in message
bender.
Stu
Old July 9th 08, 04:07 PM posted to rec.aviation.homebuilt
"RST Engineering" wrote in message
m...
--Aristotle
bender.
Stu
To date I've tried flex conduit, both steel and aluminum and both sag like
crazy and change lengths easily and don't hold their shape. Heating and
bending PVC pipe is such a cut-and-try process which also produces some
fumes off the PVC that is not supposed to be nice and the use of elbows and
saw cuts is kind of workable and I have a set of 4 equal length pieces that
have been shaped to do the job but the thing looks like crap and the exhaust
is really open for view on this helicopter. Hopefully the flex exhaust
tubing will hold its shape when bent by hand long enough for me to coat it
with epoxy to lock in the shape and hold it for a trip to the exhaust tube
bender guy.
The trick that I'm counting on, and it looked possible when I was using
conduit, is to connect the tubing to exhaust flanges bolted to the cylinders
and position all 4 pieces to intercept the 4-into-1 collector at
approximately the same time and counting on the flex tubing to hold its
shape and length, long enough for some epoxy to sieze the flexables even
further. The idea then is to remove each piece and have it matched.
I've tried AutoZone, Pep Boys, Napa, and JC Whitney. McMaster-Carr, Toys 4
Trucks, Whitney does have some SS flex but at $30 each 5' piece. This would
run the cost up a bit. I hope to finde some galvanized steel flex somewhere
at a lower price.
Stu
Old July 10th 08, 12:25 AM posted to rec.aviation.homebuilt
To model the exhaust pipes for a 985 or 1340?
Flexible air intake hose abripl Home Built 10 July 21st 06 04:11 AM
flexible wing human powered flight patrick timony Home Built 3 January 15th 04 12:21 AM
Thin flexible solar panels Eric Greenwell Soaring 11 November 28th 03 04:35 PM
human powered flight - vertical take off, flexible wing patrick timony Rotorcraft 2 September 17th 03 11:39 PM
Flexible Wing Flight patrick timony Military Aviation 6 September 16th 03 03:28 PM
