Silent Super Efficient Propeller!
Old September 5th 08, 06:10 AM
Leviterande Leviterande is offline
Junior Member
First recorded activity by AviationBanter: Sep 2008
Default Silent Super Efficient Propeller!
Hi all!
Volf propeller he
http://www.rexresearch.com/volfprop/volfprop.htm
I have been thinking alot about how this propeller would do, I wish I had a workshop, CNC, and tools to build one.. this amazing prop is claimed to be super quiet and efficient.. so any more info from the article on it or any word of experience in propellers are very appreciated
what about this propeller
( hit CTRl-F and type "An Air Screw That Ridicules Propeller" )
http://www.rexresearch.com/aero/1aero.htm
regards
kalle
Old September 5th 08, 02:12 PM posted to rec.aviation.piloting
Kingfish
On Sep 5, 1:10*am, Leviterande Leviterande.
Hi all!
Volf propeller hehttp://www.rexresearch.com/volfprop/volfprop.htm
claimed to be *super quiet and efficient.. so any more info from the
article on it or any *word of experience in propellers are very
appreciated
Looks like a ducted fan to me. Judging from the pictures, it's
doubtful CFD existed when the patent was approved and modern rotor
design would probably be more efficient. Technology progresses, ya
know?
Old September 5th 08, 02:26 PM posted to rec.aviation.piloting
a[_3_]
Hi all!
appreciated
( hit CTRl-F *and type "An Air Screw That Ridicules Propeller" )http://www.rexresearch.com/aero/1aero.htm
regards
kalle
Leviterande
That's a very old patent! If you think about a propeller for low speed
flight, think about it as a rotating wing. You'll notice high
perfornance gliders have long slender wings, and the best props look a
lot like that, with an additional twist. Ducting helps, as do Q tips
on propeller edges, but I did read somewhere you gain as much
efficiency by increasing the propeller diameter as the q tip length.
Makes me wonder if the vortex decreasing terminations on wings might
be as well used just by increasing the wingspan by that amount.
Old September 5th 08, 05:02 PM
Junior Member
Quote:
Originally Posted by a[_3_] View Post
On Sep 5, 1:10 am, Leviterande Leviterande.
Hi all!
appreciated
( hit CTRl-F and type "An Air Screw That Ridicules Propeller" )http://www.rexresearch.com/aero/1aero.htm
regards
kalle
Leviterande
so your guess is that none of the props are more efficient then todays propellers? the todays propellers didnt differ from the ones used 100 years ago btw...
Kalle
Old September 5th 08, 09:59 PM posted to rec.aviation.piloting
a[_3_]
On Sep 5, 12:02*pm, Leviterande Leviterande.
'a[_3_ Wrote:
;659074']On Sep 5, 1:10 am, Leviterande Leviterande.
wrote:-
Hi all!
appreciated
regards
kalle
Leviterande-
so *your guess is that none of the props are more efficient then todays
propellers? the todays propellers didnt differ *from the ones used 100
years ago btw...
Kalle
Leviterande
Oh? Constant speed props are that old? On a more serious note, today's
props are part of an aerodynamic systems and better engineered. Would
you care to cite a reference supporting your claim tha efficiencies
have not improved? Other than one you write yourself, of course.
Old September 5th 08, 10:44 PM posted to rec.aviation.piloting
Jim Logajan
years ago btw...
Would you care to cite a reference supporting your claim tha efficiencies
have not improved?
Barging in...
I don't know about 100 years ago, but many airship propeller efficiencies
were measured at over 65% efficient in 1920s. The reference I have is Table
13 from "Airship Design" by Charles P. Burgess (1927) [Still in print,
btw.] While there are some low "outliers" under 50% efficient, the bulk of
the 26 table entries show propeller efficiences between 55% and 65%. These
were prop efficiences at maximum speed and horsepower.
The airships LZ-120, LZ-121, Bodensee, and Nordstern appear to have had the
highest efficient props at 66%.
For more recent props, according to these sources:
http://en.wikipedia.org/wiki/Propeller
http://www.epi-eng.com/propeller_tec..._propeller.htm
current props peak around 87% efficient under optimum conditions.
If the average efficiency in the 1920s was ~60% and now is ~85% then that
is a an improvement of ~45%. On the other hand, no one will ever be able to
double on the efficiencies they were already getting over 80 years ago. ;-)
Old September 5th 08, 11:10 PM posted to rec.aviation.piloting
a[_3_]
years ago btw...
have not improved?
Barging in...
http://en.wikipedia.org/wiki/Propell..._propeller.htm
Yeah, it'll take some magic to convert rotary power into throwing air
backwards hard enough to improve efficiency very much, at least for ga
airplanes. A big fluted duct to take advantage of ram air induction
might help, but any back of the envelope sketches doesn't show much
room for other things, like pilots, and hauling around ducts adds
weight too. I'm not expecting to see many breakthroughs, but if they
are coming we'll probably see it in a home built at Oshkosh one of
these years.
Old September 6th 08, 06:21 AM
Junior Member
here you go , old propellers were more efficent then peoble think , more then 65%
http://www.memagazine.org/flight03/propwr/propwr.html
propellers didnt advance much in 100 years
read in the links in the first post about the dihedral propeller for example
Old September 5th 08, 03:55 PM posted to rec.aviation.piloting
That's exactly what Steve Wittman found 25(?) years ago on his Buick-
powered tailwind. He stuck some winglets on it, got some improvement,
then laid them down horizontally and found that they worked just as
well that way.
Dan
The birth of a quieter, greener plane: 35% more fuel-efficient; Cambridge-MIT Institute's 'Silent' Aircraft Initiative Larry Dighera Piloting 24 November 9th 06 11:05 PM
The "Whirl": More Efficient Rotary Craft? sanman Home Built 5 September 10th 04 04:11 PM
The "Whirl": More Efficient Rotary Craft? sanman Rotorcraft 5 September 10th 04 04:11 PM
Fuel efficient freight planes Jonas Heisenberg General Aviation 6 November 17th 03 02:24 AM
How efficient are our tailplanes? Kevin Neave Soaring 12 October 24th 03 06:22 PM
