On Sep 5, 1:10*am, Leviterande Leviterande.
wrote: Hi all! Volf propeller hehttp://www.rexresearch.com/volfprop/volfprop.htm I have been thinking alot about how this propeller would do, I wish I had a workshop, CNC, and tools to build one.. this amazing prop is claimed to be *super quiet and efficient.. so any more info from the article on it or any *word of experience in propellers are very appreciated what about this propeller ( hit CTRl-F *and type "An Air Screw That Ridicules Propeller" )http://www.rexresearch.com/aero/1aero.htm regards kalle -- Leviterande That's a very old patent! If you think about a propeller for low speed flight, think about it as a rotating wing. You'll notice high perfornance gliders have long slender wings, and the best props look a lot like that, with an additional twist. Ducting helps, as do Q tips on propeller edges, but I did read somewhere you gain as much efficiency by increasing the propeller diameter as the q tip length. Makes me wonder if the vortex decreasing terminations on wings might be as well used just by increasing the wingspan by that amount. |
![]() Quote:
Kalle |
On Sep 5, 12:02*pm, Leviterande Leviterande.
wrote: 'a[_3_ Wrote: ;659074']On Sep 5, 1:10 am, Leviterande Leviterande. wrote:- Hi all! Volf propeller hehttp://www.rexresearch.com/volfprop/volfprop.htm I have been thinking alot about how this propeller would do, I wish I had a workshop, CNC, and tools to build one.. this amazing prop is claimed to be *super quiet and efficient.. so any more info from the article on it or any *word of experience in propellers are very appreciated what about this propeller ( hit CTRl-F *and type "An Air Screw That Ridicules Propeller" )http://www.rexresearch.com/aero/1aero.htm regards kalle -- Leviterande- That's a very old patent! If you think about a propeller for low speed flight, think about it as a rotating wing. You'll notice high perfornance gliders have long slender wings, and the best props look a lot like that, with an additional twist. Ducting helps, as do Q tips on propeller edges, but I did read somewhere you gain as much efficiency by increasing the propeller diameter as the q tip length. Makes me wonder if the vortex decreasing terminations on wings might be as well used just by increasing the wingspan by that amount. so *your guess is that none of the props are more efficient then todays propellers? the todays propellers didnt differ *from the ones used 100 years ago btw... Kalle -- Leviterande Oh? Constant speed props are that old? On a more serious note, today's props are part of an aerodynamic systems and better engineered. Would you care to cite a reference supporting your claim tha efficiencies have not improved? Other than one you write yourself, of course. |
a wrote:
On Sep 5, 12:02*pm, Leviterande Leviterande. wrote: the todays propellers didnt differ *from the ones used 100 years ago btw... [...] Would you care to cite a reference supporting your claim tha efficiencies have not improved? Barging in... I don't know about 100 years ago, but many airship propeller efficiencies were measured at over 65% efficient in 1920s. The reference I have is Table 13 from "Airship Design" by Charles P. Burgess (1927) [Still in print, btw.] While there are some low "outliers" under 50% efficient, the bulk of the 26 table entries show propeller efficiences between 55% and 65%. These were prop efficiences at maximum speed and horsepower. The airships LZ-120, LZ-121, Bodensee, and Nordstern appear to have had the highest efficient props at 66%. For more recent props, according to these sources: http://en.wikipedia.org/wiki/Propeller http://www.epi-eng.com/propeller_tec..._propeller.htm current props peak around 87% efficient under optimum conditions. If the average efficiency in the 1920s was ~60% and now is ~85% then that is a an improvement of ~45%. On the other hand, no one will ever be able to double on the efficiencies they were already getting over 80 years ago. ;-) |
On Sep 5, 5:44*pm, Jim Logajan wrote:
a wrote: On Sep 5, 12:02*pm, Leviterande Leviterande. wrote: the todays propellers didnt differ *from the ones used 100 years ago btw... [...] Would you care to cite a reference supporting your claim tha efficiencies have not improved? Barging in... I don't know about 100 years ago, but many airship propeller efficiencies were measured at over 65% efficient in 1920s. The reference I have is Table 13 from "Airship Design" by Charles P. Burgess (1927) [Still in print, btw.] While there are some low "outliers" under 50% efficient, the bulk of the 26 table entries show propeller efficiences between 55% and 65%. These were prop efficiences at maximum speed and horsepower. The airships LZ-120, LZ-121, Bodensee, and Nordstern appear to have had the highest efficient props at 66%. For more recent props, according to these sources: http://en.wikipedia.org/wiki/Propell..._propeller.htm current props peak around 87% efficient under optimum conditions. If the average efficiency in the 1920s was ~60% and now is ~85% then that is a an improvement of ~45%. On the other hand, no one will ever be able to double on the efficiencies they were already getting over 80 years ago. ;-) Yeah, it'll take some magic to convert rotary power into throwing air backwards hard enough to improve efficiency very much, at least for ga airplanes. A big fluted duct to take advantage of ram air induction might help, but any back of the envelope sketches doesn't show much room for other things, like pilots, and hauling around ducts adds weight too. I'm not expecting to see many breakthroughs, but if they are coming we'll probably see it in a home built at Oshkosh one of these years. |
here you go , old propellers were more efficent then peoble think , more then 65%
http://www.memagazine.org/flight03/propwr/propwr.html propellers didnt advance much in 100 years read in the links in the first post about the dihedral propeller for example |
On Sat, 6 Sep 2008 05:33:08 +0100, Leviterande wrote in
: does anybody have a good pic of a Q-tip propeller? This might be one: http://www.princeaircraft.com/PhotoGallery.aspx?id=83 it seems hard to find any... Agreed! Here's a good one. You can zoom in on the picture and see the Q-tips quite clearly: http://www.controller.com/listings/aircraft-for-sale/PIPER-NAVAJO-CHIEFTAIN-PANTHER/1979-PIPER-NAVAJO-CHIEFTAIN-PANTHER/1141689.htm?guid=69E298042EB54588BA0A2765C1D8FC02& dlr=1 Marty -- Big-8 newsgroups: humanities.*, misc.*, news.*, rec.*, sci.*, soc.*, talk.* See http://www.big-8.org for info on how to add or remove newsgroups. |
On Sep 5, 7:26*am, a wrote:
That's a very old patent! If you think about a propeller for low speed flight, think about it as a rotating wing. You'll notice high perfornance gliders have long slender wings, and the best props look a lot like that, with an additional twist. Ducting helps, as do Q tips on propeller edges, but I did read somewhere you gain as much efficiency by increasing the propeller diameter as the q tip length. Makes me wonder if the vortex decreasing terminations on wings might be as well used just by increasing the wingspan by that amount. That's exactly what Steve Wittman found 25(?) years ago on his Buick- powered tailwind. He stuck some winglets on it, got some improvement, then laid them down horizontally and found that they worked just as well that way. Dan |
On Fri, 5 Sep 2008 12:42:38 -0400, Gezellig wrote in :
So is the vertical winglet 1) To increase wing length while 2) Looking cute .... and to make it easier to clear obstacles when taxiing in crowded airports? Marty -- Big-8 newsgroups: humanities.*, misc.*, news.*, rec.*, sci.*, soc.*, talk.* See http://www.big-8.org for info on how to add or remove newsgroups. |
The birth of a quieter, greener plane: 35% more fuel-efficient; Cambridge-MIT Institute's 'Silent' Aircraft Initiative | Larry Dighera | Piloting | 24 | November 9th 06 11:05 PM |
The "Whirl": More Efficient Rotary Craft? | sanman | Home Built | 5 | September 10th 04 04:11 PM |
The "Whirl": More Efficient Rotary Craft? | sanman | Rotorcraft | 5 | September 10th 04 04:11 PM |
Fuel efficient freight planes | Jonas Heisenberg | General Aviation | 6 | November 17th 03 02:24 AM |
How efficient are our tailplanes? | Kevin Neave | Soaring | 12 | October 24th 03 06:22 PM |
