Grob 103 Twin II Brake Master Cylinder
Old October 22nd 08, 12:30 PM posted to rec.aviation.soaring
Mike McCarron
Default Grob 103 Twin II Brake Master Cylinder
My club has a 1983 Grob 103 Twin II that needs a new master cylinder. Over
the years the Grob factory has made changes to the system without full
documentation and as a result the US distributor can not be sure of how I
go about purchasing the proper master cylinder for this glider.
If you or anyone you know has replaced the master cylinder on a vintage
Grob 103 Twin II recently I would appreciate your input on where I might
purchase the correct system.
Thank you,
Mike
Old October 22nd 08, 02:41 PM posted to rec.aviation.soaring
JJ Sinclair
If memory serves me, its a motorcycle master cylinder BMW? I believe
they cut it down from the original, good luck getting your inspector
to sign off on installing it!
JJ
Thank you,
Mike
Old October 22nd 08, 03:00 PM posted to rec.aviation.soaring
Mike McCarron[_2_]
JJ,
I did purchase a master cylinder from a BMW motorcycle dealer that did fit
in place. Unfortunately it did not function properly. It was properly
bled and all but it did not work. I don't know what to do next. There
must be at least 100 of these gliders in the US that will need a master
cylinder replacement in the future. I don't see how we can junk a $30K
glider for lack of a functioning master cylinder.
Thanks for your comment,
MC
JJ
Over
how
I
vintage
might
Thank you,
Mike
Old October 22nd 08, 03:22 PM posted to rec.aviation.soaring
JJ Sinclair
Why didn't it work, Mike? Hydraulics are hydraulics, the Clevland
brake slave cylinder doesn't know (or care) where that pressure is
coming from? Make sure you have compatible seals. What type fluid does
BMW use? Can't mix the red stuff with the clear stuff.
JJ
JJ,
MC
JJ
Over
how
I
vintage
might
Thank you,
Mike
Old October 22nd 08, 03:45 PM posted to rec.aviation.soaring
Mike McCarron[_2_]
JJ,
I used Dot 3 fluid with compatible O ring on the slave cylinder. The cap
on the BMW master cylinder said to use DOT 3/4 brake fluid only.
MC
JJ
JJ,
fit
properly
There
master
$30K
MC
JJ
cylinder.
Over
full
how
I
vintage
might
Thank you,
Mike
Old October 22nd 08, 07:02 PM posted to rec.aviation.soaring
JJ Sinclair
The only way I ever got a Grob brake to bleed properly was to use a
pressure bleeder where fluid is forced up through the system from the
slave cylinder. Not too expensive from Spruce & Specialty.
JJ
JJ,
MC
JJ
JJ,
fit
properly
There
master
$30K
MC
JJ
cylinder.
Over
full
how
I
vintage
might
Thank you,
Mike
Old October 22nd 08, 04:01 PM posted to rec.aviation.soaring
bumper
Yup, what JJ said. The "red stuff" is Mil Spec 5606 hydraulic oil and is
compatible with Buna-N O-rings and seals. It's also commonly used in the USA
for most small GA aircraft.
DOT automotive brake fluid, the "clear stuff", most often glycol-ether
based, and is compatible with EPDM rubber seals.
If you are switching parts from one fluid to the other, you gotta change the
rubber stuff.
bumper
"JJ Sinclair" wrote in message
JJ
JJ,
fit
MC
JJ
Over
how
I
vintage
might
Thank you,
Mike
Old October 22nd 08, 04:22 PM posted to rec.aviation.soaring
Uncle Fuzzy
rubber stuff.
bumper
JJ
JJ,
fit
in place. *Unfortunately it did not function properly. *It was properly
bled and all but it did not work. *I don't know what to do next. *There
cylinder replacement in the future. *I don't see how we can junk a $30K
MC
JJ
Grob 103 Twin II (non acro) manual YFCpilots Soaring 1 August 27th 08 07:40 PM
Grob Twin III Must read! [email protected] Soaring 3 June 9th 08 07:08 AM
Grob Twin Astir Tailshaking Peter Soaring 11 January 14th 07 11:54 PM
looking for good brake master cyls for homebuilt. clare @ snyder.on .ca Aviation Marketplace 0 March 28th 04 05:13 AM
Need G-103 Acro Master Cylinder Ray Lovinggood Soaring 5 September 30th 03 03:39 AM
