Grob Twin III Must read!
Old June 8th 08, 09:25 AM posted to rec.aviation.soaring
Default Grob Twin III Must read!
Our club's Twin III had a major problem that was found in a Positive
Control Check, the bolt holding the belcranks for the airbrakes and
the elevator (located behind the rear seat in the control hookup area)
had sheared.
Grob will probably be doing an AD for instpection soon, our plane is
at Grob right now being inspected (they are only a 20 minute drive
from the club!).
Please inspect your Twin III before you fly in again.
And for those of you who don't feel the need to do a PCC .... This
wouldn't have shown up with a visual inspection nor probably on a
"hands on" inspection.
Bob
Old June 8th 08, 03:50 PM posted to rec.aviation.soaring
JJ Sinclair
Oh boy, yet another AD from good old Grob. That makes 16 by my count!
Got to tell a story about the incident that lead to the big flight
control fix. Seems a mechanic who also gave rides on weekends was up
with a passenger in the front seat of a 103 he had just been working
on. The passanger was just that, first ride I believe. On final
approach he started loosing aileron control. Yep, moving the stick
left and right didn't make the bird do anything!
Talk about cool-hand-Luke, this guy un-strapped, flipped open the
hatch on the floor of the baggage compartment (behind the rear seat),
grabbed the aileron linkage and righted the bird, as in made the wings
parallel with the world again! Got to think this guy suspected
something wasn't quite with the aileron system. Anyway, his problems
weren't over because both of his hands were busy with right hand on
the aileron linkage behind him and left hand on the stick for pitch
control. They were too high and if someone didn't pull the spoilers
they were in danger of over-flying the runway.
Cool hand Luke said to his un-suspecting passanger, "Do you see that
blue handle on your left side? Please pull it back a bit".
They got the bird back on the ground in one piece and Grob came out
with a $3000 doller fix that was paid by the aircraft owners (not
Grob) that went through all the flight control systems and fixed
things that an idiot could see weren't strong enough!
OK. rant over, I feel much better now,
JJ
On Jun 8, 12:25*am, "
had sheared.
from the club!).
Bob
Old June 9th 08, 12:01 AM posted to rec.aviation.soaring
Stephanie and Ed
This got me thinking about something. I recall when I was a teenager I got a
hold of my father's ratchet set and started using it on various bolts around
the house. I quickly learned why torque wrenches were invented as I sheared
the heads off of many of them. Since then I've been respectful of how much
force you can exert with a lever, even one only a foot long.
So I occurs to me that there may be a downside to repetitive PCCs if they
are not done properly. If the person applying the force on the stick (a
lever) applied a great amount of force and the individual opposing that
force on the control surface (also a lever) did likewise it might be
possible to repetitively stress and weaken the bellcrank and bolt since
that's where the forces would converge in opposite directions. I'm not an
engineer, but it seems to me that some care must be taken here so that the
forces do not exceed those that the system would be designed for, i.e.,
those that would be encountered in flight. The forces required to assure a
stable connection are far less than what might be accidentally applied by
individuals who are not aware of how to do this properly.
There was another Grob SB this summer about the shearing of the removable
rear control stick just below the attachement point. The picture in the SB
looked to me more like metal fatigue rather than corrosion. Whether this is
from PCCs or fighting students is not clear, but the force mechanisms might
be the same.
" wrote in message
had sheared.
from the club!).
Bob
Old June 9th 08, 08:08 AM posted to rec.aviation.soaring
"Stephanie and Ed" wrote:
Ed or Stephanie ;`
The initial thoughts from our "Guru's" is that this problem came about
as a result of "heavy handed" PCC checks. Maybe we need someone to
develope an adjustable strain guage that can be used for PCC's. Set
the guage to the proper load and test away!
Bob
Looking for hand controls (rudder) for Grob Twin II YFCpilots Soaring 3 April 7th 08 02:08 AM
ID Twin w/ twin vert stabs--RPV? Unk_Twin.jpg (01/01) No Name Aviation Photos 5 October 12th 07 06:55 AM
Grob Twin Astir Tailshaking Peter Soaring 11 January 15th 07 12:54 AM
Need Grob 103 Twin II left front rudder pedal Mike McCarron Soaring 1 May 15th 06 03:16 PM
Grob Twin Astir 1 Manual / Flughandbuch Sebastian Schroeter Soaring 2 June 14th 04 12:41 PM
