B40 fuse question
Old December 8th 08, 05:20 PM posted to rec.aviation.soaring
Tuno
Default B40 fuse question
The + 12V power lead to my B40 fell out the back of the unit at some
point and made contact with ground during its subsequent tour of the
area behind the panel. The (?)-amp, 5x20mm fuse in the instrument
panel was blown, as well as the 0.25 amp fuse of the same size on the
back of the B40.
I know the purpose of the panel fuse is to protect the wires, and the
B40 fuse is to protect the instrument (I think). Can I safely use a
0.25 amp fuse in the instrument panel and maybe a 0.5 amp fuse in the
B40? (The B40 is the only item on that fuse; the radio, LX and 302
have their own.)
Btw I've checked the B40 manual and can't find any mention of fuses.
Is 0.25 amp the correct fuse?
Thanks
~ted/2NO
Old December 8th 08, 05:54 PM posted to rec.aviation.soaring
Andy[_1_]
back of the B40.
have their own.)
Thanks
~ted/2NO
I don't see how the B40 fuse could have been blown if the power wire
was disconnected. You may have another problem. If you don''t find
an answer on the B40 fuse size call me at home (leave msg) and I'll
check mine.
Andy
Old December 8th 08, 07:39 PM posted to rec.aviation.soaring
Richard[_1_]
back of the B40.
have their own.)
Thanks
~ted/2NO
Ted,
The fuse is 2 amp. Sometimes if +12v power touches the case of the
B40 a fuse link on the circuit board on the back of the unit is
blown. You can check this by following the circuit and using a
voltmeter.
Richard
www.craggyaero.com
Metric Fuse Question Paul Foley Soaring 3 August 21st 08 10:54 PM
Tube Fuse Oil Holes John[_17_] Home Built 8 March 21st 08 12:11 PM
KR-2 fuse for sale Turbo Tiger Home Built 3 December 17th 05 06:27 PM
Fuse the Wire or Fuse the Device? ContestID67 Soaring 11 April 27th 05 03:13 AM
Cambridge Fuse Question Brian Iten Soaring 9 January 4th 05 02:43 PM
