Does anybody still do the old technique of drilling holes before tacking
tubes together to interconnect them for oiling the fuse when it's finished? I've been told that's not done any more, because of the realization that as long as the welds are air tight, the oxygen trapped in the tube is consumed in a small amount of oxydation of the metal surface inside until all that's left is nitrogen and then it's fine without any oil inside. Comments? John |
On Wed, 19 Mar 2008 21:04:46 -0400, John
wrote: Does anybody still do the old technique of drilling holes before tacking tubes together to interconnect them for oiling the fuse when it's finished? I've been told that's not done any more, because of the realization that as long as the welds are air tight, the oxygen trapped in the tube is consumed in a small amount of oxydation of the metal surface inside until all that's left is nitrogen and then it's fine without any oil inside. Comments? John We drilled ours. If you are 100% confident all your welds are perfectly air-tight the oxygen arguement is true. Some guys stuff washed steel wool into the tube as a sacrificial element. We are thinking of putting a guage and valve on ours to see if it IS airtight and possibly argon fill it. -- Posted via a free Usenet account from http://www.teranews.com |
clare at snyder dot ontario dot canada wrote in message ... On Wed, 19 Mar 2008 21:04:46 -0400, John wrote: Does anybody still do the old technique of drilling holes before tacking tubes together to interconnect them for oiling the fuse when it's finished? I've been told that's not done any more, because of the realization that as long as the welds are air tight, the oxygen trapped in the tube is consumed in a small amount of oxydation of the metal surface inside until all that's left is nitrogen and then it's fine without any oil inside. Comments? John We drilled ours. If you are 100% confident all your welds are perfectly air-tight the oxygen arguement is true. Some guys stuff washed steel wool into the tube as a sacrificial element. We are thinking of putting a guage and valve on ours to see if it IS airtight and possibly argon fill it. -- I've heard of that being done with acrobatic birds, although it might have been with nitrogen. A loss of pressure is evidence of structural damage. Peter |
Peter Dohm wrote:
clare at snyder dot ontario dot canada wrote in message ... On Wed, 19 Mar 2008 21:04:46 -0400, John wrote: Does anybody still do the old technique of drilling holes before tacking tubes together to interconnect them for oiling the fuse when it's finished? I've been told that's not done any more, because of the realization that as long as the welds are air tight, the oxygen trapped in the tube is consumed in a small amount of oxydation of the metal surface inside until all that's left is nitrogen and then it's fine without any oil inside. Comments? John We drilled ours. If you are 100% confident all your welds are perfectly air-tight the oxygen arguement is true. Some guys stuff washed steel wool into the tube as a sacrificial element. We are thinking of putting a guage and valve on ours to see if it IS airtight and possibly argon fill it. -- I've heard of that being done with acrobatic birds, although it might have been with nitrogen. A loss of pressure is evidence of structural damage. Peter I drilled all of mine,put half of an 1/8" pipe coupling in each top longeron at the rear, a pc on on the lower front cross member (near one side) elevated the tail about a foot, put a valve, small catch bottle & vacuum pump on the rear--a hose & valve on the front, and stuck the hose down in a gallon can of linseed oil--boiled or raw, don't make no difference. Pulled a 29" vacuum on the system--let it set a while --if no loss of vac, open the lower valve & fill with oil. close valves. roll 1/4 turn each morn & eve until all 4 sides have been on the bottom 8-12 hrs. (measure oil consumed!!) Place in initial position, open valve into oil can, apply slight pressure with argon, neon, nitrogen, & drain out oil while filling with inert gas. It helps to pull a vacuum on the linseed oil,Prior to putting in the fuselage, as it will have some dissolved air in it. otherwise you get some foaming into the catch bottle when it nears being full. Doesn't take very long to computs the volume inside the tubes--then you"ll know how much to expect to use. Jerry † |
On Thu, 20 Mar 2008 02:32:24 -0400, "Peter Dohm"
wrote: clare at snyder dot ontario dot canada wrote in message .. . On Wed, 19 Mar 2008 21:04:46 -0400, John wrote: Does anybody still do the old technique of drilling holes before tacking tubes together to interconnect them for oiling the fuse when it's finished? I've been told that's not done any more, because of the realization that as long as the welds are air tight, the oxygen trapped in the tube is consumed in a small amount of oxydation of the metal surface inside until all that's left is nitrogen and then it's fine without any oil inside. Comments? John We drilled ours. If you are 100% confident all your welds are perfectly air-tight the oxygen arguement is true. Some guys stuff washed steel wool into the tube as a sacrificial element. We are thinking of putting a guage and valve on ours to see if it IS airtight and possibly argon fill it. -- I've heard of that being done with acrobatic birds, although it might have been with nitrogen. A loss of pressure is evidence of structural damage. Peter We would likely use Argon only because the Tig Welder that was used to weld it has a nice big tank of Argon readily available. -- Posted via a free Usenet account from http://www.teranews.com |
... On Thu, 20 Mar 2008 02:32:24 -0400, "Peter Dohm" wrote: clare at snyder dot ontario dot canada wrote in message . .. On Wed, 19 Mar 2008 21:04:46 -0400, John wrote: Does anybody still do the old technique of drilling holes before tacking tubes together to interconnect them for oiling the fuse when it's finished? I've been told that's not done any more, because of the realization that as long as the welds are air tight, the oxygen trapped in the tube is consumed in a small amount of oxydation of the metal surface inside until all that's left is nitrogen and then it's fine without any oil inside. Comments? John We drilled ours. If you are 100% confident all your welds are perfectly air-tight the oxygen arguement is true. Some guys stuff washed steel wool into the tube as a sacrificial element. We are thinking of putting a guage and valve on ours to see if it IS airtight and possibly argon fill it. -- I've heard of that being done with acrobatic birds, although it might have been with nitrogen. A loss of pressure is evidence of structural damage. Peter We would likely use Argon only because the Tig Welder that was used to weld it has a nice big tank of Argon readily available. -- Posted via a free Usenet account from http://www.teranews.com Given the same situation, I would do the same. BTW, I am curious whether you used argon it in the tires as discussed in an earlier thread and, if so, how well it has held pressure. My recollection is that I had expressed the possibility that it might have slightly more leakage than nitrogen due to a smaller molecule. Peter |
clare at snyder dot ontario dot canada wrote:
On Wed, 19 Mar 2008 21:04:46 -0400, John wrote: Does anybody still do the old technique of drilling holes before tacking tubes together to interconnect them for oiling the fuse when it's finished? I've been told that's not done any more, because of the realization that as long as the welds are air tight, the oxygen trapped in the tube is consumed in a small amount of oxydation of the metal surface inside until all that's left is nitrogen and then it's fine without any oil inside. Comments? John We drilled ours. If you are 100% confident all your welds are perfectly air-tight the oxygen arguement is true. Some guys stuff washed steel wool into the tube as a sacrificial element. We are thinking of putting a guage and valve on ours to see if it IS airtight and possibly argon fill it. Aerospatial Llama helicopters do that. Dry nitrogen would be fine. Or, use a vacuum pump and evacuate the truss, with a vacuum gauge to monitor it. John |
One thing to consider, at least on shorter length tubes is that as you
weld, the air inside the tube will be expanding with the increasing temperature, if the tube cannot "breath" a bit it will cause a blow hole in your bead just as you finish it. If I were doing my project again I would weld it tight, pressurize it, and make a habit of checking the gauge for pressure loss on preflight like the aerobatic guys do. More work but negligible extra weight and great indicator of cracking. |
wrote: Does anybody still do the old technique of drilling holes before tacking tubes together to interconnect them for oiling the fuse when it's finished? I've been told that's not done any more, because of the realization that as long as the welds are air tight, the oxygen trapped in the tube is consumed in a small amount of oxydation of the metal surface inside until all that's left is nitrogen and then it's fine without any oil inside. Comments? John my old Auster had a section where the drain holes in the fabric had been forgotten. the rudder particularly had been flying around for years with about 9" of water in the bottom of it. there were lots and lots and lots of tide marks in the fabric where the rusty water had partially dried out then refilled. needless to say the entire lower tube frame of the rudder was corroded through in a number of places. when we cut the corroded section away and looked into the tube, an eighth of an inch away from the rusted through area on into the rest of the tube the tube was pristine. the poms had swabbed out the inside of the tube with lanoline. skimp on the little eighth inch holes all you like and dont bother to put tube seal in the tubes. they're such a bother. ....might just bite you in the arse one day. soaking all the auster fuselage tubes took less than half a can of tube seal and even with our import costs was under $20. for that I have a totally corrosion free fuselage and it will stay that way. experimenting is such fun. go for it. Stealth Pilot |
| Thread Tools | |
| Display Modes | |
| KR-2 fuse for sale | Turbo Tiger | Home Built | 3 | December 17th 05 07:27 PM |
| When Poorboys drill holes ...was: Drilling holes in steel tubing | wright1902glider | Home Built | 4 | November 4th 05 02:19 AM |
| Fuse the Wire or Fuse the Device? | ContestID67 | Soaring | 11 | April 27th 05 04:13 AM |
| Cambridge Fuse Question | Brian Iten | Soaring | 9 | January 4th 05 03:43 PM |
| Pitts Special Steel Tube Fuse Mod. | Martin Morgan | Home Built | 0 | November 24th 03 12:08 AM |
