![]() I stumbled across this earlier today. Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg |
On Dec 24, 4:27*pm, Monk wrote:
I stumbled across this earlier today. *Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg Bombing practice in earlier years ?? It is weird though.... IMHO |
On Dec 24, 5:27*pm, Monk wrote:
I stumbled across this earlier today. *Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg Could be geologic sinkholes? Underlying limestone dissolves in acid- bearing water and caves in underneath? |
on 12/25/08 9:08 AM Paul kgyy said the following:
On Dec 24, 5:27 pm, Monk wrote: I stumbled across this earlier today. Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg Could be geologic sinkholes? Underlying limestone dissolves in acid- bearing water and caves in underneath? They look too regular to be natural sinkholes to me. I wonder if they're abandoned sulphur mining drill holes. The area is known for extracting sulphur by pumping superheated water down to deposits to melt the mineral, which is then forced to the surface with compressed air. |
Rich Ahrens wrote:
on 12/25/08 9:08 AM Paul kgyy said the following: On Dec 24, 5:27 pm, Monk wrote: I stumbled across this earlier today. Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg Could be geologic sinkholes? Underlying limestone dissolves in acid- bearing water and caves in underneath? They look too regular to be natural sinkholes to me. I wonder if they're abandoned sulphur mining drill holes. The area is known for extracting sulphur by pumping superheated water down to deposits to melt the mineral, which is then forced to the surface with compressed air. Swamp Monster Fart Bubbles |
Monk writes:
I stumbled across this earlier today. Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg Sinkholes, areas where the ground at the surface has collapsed downwards due to underground erosion or subsidence. |
Anthony said:
Sinkholes, areas where the ground at the surface has collapsed downwards due to underground erosion or subsidence. A true genius in his own mind- so helpful and beneficent. |
On Thu, 25 Dec 2008 14:43:58 -0600, Viperdoc wrote:
Anthony said: Sinkholes, areas where the ground at the surface has collapsed downwards due to underground erosion or subsidence. A true genius in his own mind- so helpful and beneficent. Responded to by a feckin' idiot of less mental head. -- Bear Bottoms Private Attorney General |
"Bear Bottoms" wrote in message
... On Thu, 25 Dec 2008 14:43:58 -0600, Viperdoc wrote: Anthony said: Sinkholes, areas where the ground at the surface has collapsed downwards due to underground erosion or subsidence. A true genius in his own mind- so helpful and beneficent. Responded to by a feckin' idiot of less mental head. ....sez the imposter 12yr old kook. |
![]() "Mike" nospam @ aol.com wrote in message ... | "Bear Bottoms" wrote in message | ... | On Thu, 25 Dec 2008 14:43:58 -0600, Viperdoc wrote: | | Anthony said: | | Sinkholes, areas where the ground at the surface has collapsed downwards | due | to underground erosion or subsidence. | | A true genius in his own mind- so helpful and beneficent. | | Responded to by a feckin' idiot of less mental head. | | ...sez the imposter 12yr old kook. | Sez the 7 year old wanna be kook. |
Covering holes | [email protected] | Soaring | 9 | May 2nd 08 05:57 PM |
Tube Fuse Oil Holes | John[_17_] | Home Built | 8 | March 21st 08 12:11 PM |
When Poorboys drill holes ...was: Drilling holes in steel tubing | wright1902glider | Home Built | 4 | November 4th 05 01:19 AM |
Drilling holes in steel tubing | wright1902glider | Home Built | 20 | October 9th 05 03:43 AM |
Filling Holes | AKperson | Owning | 1 | July 20th 05 03:54 PM |
