Com Icom A-6 handheld connected only to headset, NO CONNECTION TO A/C
ELECTRICAL. Static noise and flickering RX symbol on handheld (no voice being received)so distractiing its makes use unbearable. No static during actual voice reception-tower reports clear,good, no noise voice. Outside of a/c facing prop or tail (no noise)-move in circle about a/c noise develops. Inside a/c noise at all times except during actual voice reception. The following have NO affect: tried different radio,headset, partchcords-disconnected alternator belt,field lead-put condensor for noise trap on regulator,coil, distributor-on/off of elec T/B(has in-line filter),trim tab,intercom,strobe,elec tach to - coil post,all electrical connections,wires,terminal strips verified good-only other electrical are the amp/vot meter connections. Noise does not occur when radio/ headset combo used in other a/c. Noise cancelled out at squelch level 20 and high volume. 12 years building, FAA certified, l year so far chasing "BUGS" and hopefully last item to correct so I CAN FLY! P LEASE HELP IF YOU WOULD Thank You, |
Sounds suspiciously like ignition noise to me. You might want to tell us
what kind of aerocraft this is. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle "Bob" wrote in message ... Com Icom A-6 handheld connected only to headset, NO CONNECTION TO A/C ELECTRICAL. Static noise and flickering RX symbol on handheld (no voice being received)so distractiing its makes use unbearable. No static during actual voice reception-tower reports clear,good, no noise voice. Outside of a/c facing prop or tail (no noise)-move in circle about a/c noise develops. Inside a/c noise at all times except during actual voice reception. The following have NO affect: tried different radio,headset, partchcords-disconnected alternator belt,field lead-put condensor for noise trap on regulator,coil, distributor-on/off of elec T/B(has in-line filter),trim tab,intercom,strobe,elec tach to - coil post,all electrical connections,wires,terminal strips verified good-only other electrical are the amp/vot meter connections. Noise does not occur when radio/ headset combo used in other a/c. Noise cancelled out at squelch level 20 and high volume. 12 years building, FAA certified, l year so far chasing "BUGS" and hopefully last item to correct so I CAN FLY! P LEASE HELP IF YOU WOULD Thank You, |
On Jan 8, 12:44*pm, Bob wrote:
Com Icom A-6 handheld connected only to headset, NO CONNECTION TO A/C ELECTRICAL. Static noise and flickering RX symbol on handheld (no voice being received)so distractiing its makes use unbearable. *No static during actual voice reception-tower reports clear,good, no noise voice. Outside of a/c facing prop or tail (no noise)-move in circle about a/c noise develops. Inside a/c noise at all times except during actual voice reception. The following have NO affect: tried different radio,headset, partchcords-disconnected alternator belt,field lead-put condensor for noise trap on regulator,coil, distributor-on/off of elec T/B(has in-line filter),trim tab,intercom,strobe,elec tach to - coil post,all electrical connections,wires,terminal strips verified good-only other electrical are the amp/vot meter connections. Noise does not occur when radio/ headset combo used in other a/c. Noise cancelled out at squelch level 20 and high volume. 12 years building, FAA certified, l year so far chasing "BUGS" and hopefully last item to correct so I CAN FLY! P LEASE HELP IF YOU WOULD Thank You, This is a KR2S with a Corvair 2700cc/164cid engine converted per William Wynne Manual and uses a distributor/coil and a JD Dynamo w/ regulator. |
On Jan 8, 5:22*pm, Bob wrote:
On Jan 8, 12:44*pm, Bob wrote: Com Icom A-6 handheld connected only to headset, NO CONNECTION TO A/C ELECTRICAL. Static noise and flickering RX symbol on handheld (no voice being received)so distractiing its makes use unbearable. *No static during actual voice reception-tower reports clear,good, no noise voice. Outside of a/c facing prop or tail (no noise)-move in circle about a/c noise develops. Inside a/c noise at all times except during actual voice reception. The following have NO affect: tried different radio,headset, partchcords-disconnected alternator belt,field lead-put condensor for noise trap on regulator,coil, distributor-on/off of elec T/B(has in-line filter),trim tab,intercom,strobe,elec tach to - coil post,all electrical connections,wires,terminal strips verified good-only other electrical are the amp/vot meter connections. Noise does not occur when radio/ headset combo used in other a/c. Noise cancelled out at squelch level 20 and high volume. 12 years building, FAA certified, l year so far chasing "BUGS" and hopefully last item to correct so I CAN FLY! P LEASE HELP IF YOU WOULD Thank You, This is a KR2S with a Corvair 2700cc/164cid engine converted per William Wynne Manual and uses a distributor/coil and a JD Dynamo w/ regulator.- Hide quoted text - - Show quoted text - Using Moroso Blue Max plug wires. |
On Jan 8, 5:26*pm, Bob wrote:
On Jan 8, 5:22*pm, Bob wrote: On Jan 8, 12:44*pm, Bob wrote: Com Icom A-6 handheld connected only to headset, NO CONNECTION TO A/C ELECTRICAL. Static noise and flickering RX symbol on handheld (no voice being received)so distractiing its makes use unbearable. *No static during actual voice reception-tower reports clear,good, no noise voice. Outside of a/c facing prop or tail (no noise)-move in circle about a/c noise develops. Inside a/c noise at all times except during actual voice reception. The following have NO affect: tried different radio,headset, partchcords-disconnected alternator belt,field lead-put condensor for noise trap on regulator,coil, distributor-on/off of elec T/B(has in-line filter),trim tab,intercom,strobe,elec tach to - coil post,all electrical connections,wires,terminal strips verified good-only other electrical are the amp/vot meter connections. Noise does not occur when radio/ headset combo used in other a/c. Noise cancelled out at squelch level 20 and high volume. 12 years building, FAA certified, l year so far chasing "BUGS" and hopefully last item to correct so I CAN FLY! P LEASE HELP IF YOU WOULD Thank You, This is a KR2S with a Corvair 2700cc/164cid engine converted per William Wynne Manual and uses a distributor/coil and a JD Dynamo w/ regulator.- Hide quoted text - - Show quoted text - Using Moroso Blue Max plug wires. Unshielded ignition leads. Unshielded tach lead, unshielded distributor wiring to the switch. No wonder there's lots of noise. Every spark impulse produces a broadband radio signal. Dan |
My diagosis from afar is ignition noise. No two ways about it. You MIGHT
be able to get away with resistor wire or resistor plugs, but talk to your local EAA tech counselor about shielded ignition, shielded this, shielded that. An automotive engine is one of the best broadband noise sources known to man. Jim This is a KR2S with a Corvair 2700cc/164cid engine converted per William Wynne Manual and uses a distributor/coil and a JD Dynamo w/ regulator. |
On Thu, 8 Jan 2009 11:44:35 -0800 (PST), Bob wrote:
Com Icom A-6 handheld connected only to headset, NO CONNECTION TO A/C ELECTRICAL. Static noise and flickering RX symbol on handheld (no voice being received)so distractiing its makes use unbearable... I have the A24 (same radio as yours except with VOR added). I eliminated the noise by turning on the radios "ANL" (Automatic Noise Limiter) function, and switching to resistor spark plugs. -Dana -- I don't suffer from insanity. I enjoy every minute of it. |
wiring second radio and noise | flps_74 | Owning | 3 | November 4th 08 09:43 PM |
radio noise | et | Home Built | 4 | September 30th 08 05:43 PM |
Radio ignition noise. | [email protected] | Home Built | 6 | August 17th 07 05:15 PM |
Radio ignition noise | [email protected] | Home Built | 0 | August 16th 07 03:46 PM |
Static/Squelch Noise in Radio | Kensandyeggo | Home Built | 2 | April 13th 06 09:00 PM |
