Static/Squelch Noise in Radio
Old April 11th 06, 07:14 AM posted to rec.aviation.homebuilt
Default Static/Squelch Noise in Radio
Have an unusual problem with a new radio, an ICOM panel mount. Nothing
wrong with the radio, but I'm getting a squelch/static noise at certain
times. It is worse when both mags are on and when the engine goes from
about 2200 rpm down to idle. It is less on one mag and practically
non-existant on the other. It sounds like someone is breaking squelch.
At idle, it will make the noise intermittently, increase as I increase
rpm and is worse coming down.
A radio-guy suggested 2 new "P-leads?" I wonder if he meant
capacitors, which is what the previous owner suggested replacing or
Spruce and Chief have mag noise filters at about $45 each. AmeriKing
has a DC filter for over $100. I ordered 2 capacitors for about 10
bucks each, but there are others for close to 50 bucks each. Anyone
have any experience with this stuff? I figured if I'm going to waste
my money, I may as well try the cheapest things first.
By the way, I'm bending the rules a little. I had the same model radio
in the experimental I used to own, but I sold it to buy a McCulloch J-2
certificated gyro. It has a Lyc O-360 and Bendix mags. Thanks for any
help on this.
Old April 13th 06, 08:59 PM posted to rec.aviation.homebuilt
You might start out by trying to figure out by which path the noise is
entering your radio. You could isolate the DC power path from the
antenna path by powering your radio from an isolated supply (seperate
battery). If the problem persists, then assume the antenna path and
look at why your ignition is emitting so much power into the ether.
Perhaps this is where the new P leads come in.
Old April 13th 06, 09:00 PM posted to rec.aviation.homebuilt
This should get the discussion flowing since it people are less likely
to respond to a question than to advice that they disagree with.
Radio "Squelch-type" Noise Kensandyeggo Owning 7 April 12th 06 07:20 PM
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
Funny noise update Peter Duniho Piloting 1 July 1st 04 02:58 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
