I have come across a bit of a mystery that I am hoping that someone
could help solve. I am including a picture of a B-24 that has an odd (partial Yagi) antenna just below the flight deck that I cannot ID. I have seen them on the occasional B-24, only, serving in both the ETO and the Pacific. Only seen them on US operated planes, never Commonwealth aircraft. Seen the antenna on 'ordinary' B-24's and also they are included on some of the Ferret conversions. A fellow researcher suggested that it is associated with an early war IFF unit. pre IFF Mark III, but I don't think so. Another suggestion was that is was somehow associated with an ASV radar set - but again I do not think that this can be so for various reasons. Does anyone know what this is? Waldo. |
The short answer is no, some very knowledgeable avionics specialists have
given this a lot of thought and queries of suriving B-24 crews have shed no light on it. However the of the part of the array is mounted on the rear fuselage sides (Dinky_rear aerials.jpg). The 4 antenna array is mounted on both sides of the forward fuselage and location varied from low down to just below the cockptit. The system has not been confirmed outside of the Pacific area and to date nearly 300 aircraft have been identified with it. The breakdown of installs is: 5AAF 99 7AAF 73 13AAF 90 USN 29 The 5AAF seems to have discontinued the install after the B-24D, but it appears on some 44-4xxxx serial numbered B-24Js in the 7th & 13AAFs. PJ "Waldo.Pepper" wrote in message ... I have come across a bit of a mystery that I am hoping that someone could help solve. I am including a picture of a B-24 that has an odd (partial Yagi) antenna just below the flight deck that I cannot ID. I have seen them on the occasional B-24, only, serving in both the ETO and the Pacific. Only seen them on US operated planes, never Commonwealth aircraft. Seen the antenna on 'ordinary' B-24's and also they are included on some of the Ferret conversions. A fellow researcher suggested that it is associated with an early war IFF unit. pre IFF Mark III, but I don't think so. Another suggestion was that is was somehow associated with an ASV radar set - but again I do not think that this can be so for various reasons. Does anyone know what this is? Waldo. |
![]() "Waldo.Pepper" wrote in message ... I have come across a bit of a mystery that I am hoping that someone could help solve. I am including a picture of a B-24 that has an odd (partial Yagi) antenna just below the flight deck that I cannot ID. I have seen them on the occasional B-24, only, serving in both the ETO and the Pacific. Only seen them on US operated planes, never Commonwealth aircraft. Seen the antenna on 'ordinary' B-24's and also they are included on some of the Ferret conversions. A fellow researcher suggested that it is associated with an early war IFF unit. pre IFF Mark III, but I don't think so. Another suggestion was that is was somehow associated with an ASV radar set - but again I do not think that this can be so for various reasons. Does anyone know what this is? Waldo. I first thought it was for RADAR jamming missions but it was used for submarine detection according to this page- http://www.airtoaircombat.com/backgr...p?id=61&bg=722 "The RAF Liberator I was the first of the type to see combat. The long range and heavy bombload made the Liberator I a natural choice for RAF Coastal Command for use in its battles against the U-boat menace. Upon arrival in England, they were extensively modified to make them suitable for the antisubmarine role. They were equipped with early versions of ASV radars, which included a thicket of Yagi aerials protruding from the nose and the wings, four stickle-back mast antennae sticking upward from the ventral fuselage, and a set of towel-rail type antennae attached to the sides of the rear fuselage. The aircraft looked not unlike a flying porcupine. For attacks on surfaced U-boats, Liberator Is were fitted with a pack for four forward-firing 20-mm Hispano cannon underneath the forward fuselage. These modifications were carried out by Heston Aircraft Ltd. The normal operating crew was seven." -- Anyolmouse |
ASV radars, which included a thicket of Yagi aerials protruding from the nose and the wings, four stickle-back mast antennae sticking upward from the ventral fuselage, and a set of towel-rail type antennae attached to the sides of the rear fuselage. The aircraft looked not unlike a flying porcupine. For attacks on surfaced U-boats, Liberator Is were fitted with a pack for four forward-firing 20-mm Hispano cannon underneath the forward fuselage. These modifications were carried out by Heston Aircraft Ltd. The normal operating crew was seven." Thanks for trying there Anonylous but this does not describe the aircraft that I posted. The mystery antenna that I posted has NOT been seen in any Commonwealth aircraft. And does seem to be unique to the PTO (I thought I found one in service over Italy recently but I made a mistake.) Here is a picture of the aircraft that you suggested. Note the YAGI on the nose and wings and the further set of antenna on the fuselage sides. FWIW re the Mystery Antenna I am lately torn between thinking it is either an ELINT receiver suite, or a self-protection jammer installation. This sort of mystery really bothers me. Waldo. |
IO-540 mystery | Paul Tomblin | Owning | 27 | August 31st 07 08:59 PM |
CO mystery - any ideas? | Andrew Gideon | Owning | 24 | November 20th 04 05:16 PM |
Mystery Propellor | M Pengelly | Restoration | 7 | November 1st 04 08:42 PM |
GPS Mystery | tony roberts | Owning | 5 | February 3rd 04 12:54 AM |
Halifax mystery | Geoffrey Sinclair | Military Aviation | 0 | November 14th 03 02:39 AM |
