IO-540 mystery
Old August 27th 07, 10:55 PM posted to rec.aviation.owning
Paul Tomblin
Default IO-540 mystery
Our club's PA32R-300 has an IO-540 with lots and lots of hours on it.
After 20+ years, at this year's annual the compression was down a few
pounds on a couple of the cylinders, and the mechanic said he really has
his doubts about it passing next year's annual. That might be
significant, or it might not.
Twice this year, while people have been flight training in it (I was doing
a BFR this spring, another pilot was checking out in the plane for the
first time a few weeks ago), the engine has been running fine and on
rollout afterwards the engine died and couldn't be restarting. Both times
it was after doing some air-work (stalls, steep turns, etc) and then a
couple of touch and goes. Nobody has had any problems in a normal point
to point flight, although we've had the normal problems with hot starting
that's endemic to fuel injected aviation engines.
The last time it happened, the engine died at the airport where our
mechanic is based, and he pulled the plugs and said they weren't fouled
and they were dry (so the problem restarting wasn't that he flooded it).
Based on a suggestion here, I had them check the fuel pressure, and it
seems fine. Could it be vapour lock? Any other suggestions?
Paul Tomblin http://blog.xcski.com/
"Once you have an emergency, the airplane belongs to the insurance company.
Concentrate on saving people on the ground, your passengers, and yourself,
in that order. Saving the plane is not on the list."
Mystery Plane [email protected] Piloting 8 November 9th 06 02:30 PM
Mystery Airport - help ID please Steve Piloting 2 September 4th 05 12:44 AM
GPS Mystery tony roberts Owning 5 February 3rd 04 01:54 AM
Halifax mystery Geoffrey Sinclair Military Aviation 0 November 14th 03 03:39 AM
Pan AM 747 mystery solved! Alan White Simulators 1 July 18th 03 07:29 PM
