I'm looking for a simple design for nose wheel steering for
retractable gear. Any ideas? Dan, U.S. Air Force, retired |
![]() "Dan" wrote in message ... I'm looking for a simple design for nose wheel steering for retractable gear. Any ideas? Cables with the cables running over a pulley close to the pivot point on the retract mechanics, with another spring and pulley keeping tension on any slack that does develop. -- Jim in NC |
On Jun 24, 7:13*am, Dan wrote:
* *I'm looking for a simple design for nose wheel steering for retractable gear. Any ideas? Dan, U.S. Air Force, retired "T-bar" above the gear strut retraction pivot point which swings back into contact with roller bearings connected to the pedals as the nose gear down-lock engages. Pedals would push roller bearings against T- bar which would rotate gear strut to steer. The roller motion would have to be reversed relative to the pedals so pushing on the right pedal would make the nose gear steer right. Strut would have to be spring loaded to keep it centered and steering dampers would be needed. |
bildan wrote:
On Jun 24, 7:13 am, Dan wrote: I'm looking for a simple design for nose wheel steering for retractable gear. Any ideas? Dan, U.S. Air Force, retired "T-bar" above the gear strut retraction pivot point which swings back into contact with roller bearings connected to the pedals as the nose gear down-lock engages. Pedals would push roller bearings against T- bar which would rotate gear strut to steer. The roller motion would have to be reversed relative to the pedals so pushing on the right pedal would make the nose gear steer right. Strut would have to be spring loaded to keep it centered and steering dampers would be needed. That's exactly how the gear on a Navion works, except that there is a "V" slot to center the strut during retraction instead of spring loading, and there are no dampers. Rip |
* *I'm looking for a simple design for nose wheel steering for retractable gear. Any ideas? Dan, U.S. Air Force, retired Morse cables? ============ Leon McAtee |
On Jun 24, 10:57*am, Dan wrote:
wrote: On Jun 24, 7:13 am, Dan wrote: * *I'm looking for a simple design for nose wheel steering for retractable gear. Any ideas? Dan, U.S. Air Force, retired Morse cables? ============ Leon McAtee * *I came up with a fairly simple idea using hydraulics with brake master cylinders to supply pressure. Problem is the wheel will either still steer when retracted making for a big wheel well or any disconnect system I can think of becomes complex beyond my pay grade. * *I had considered cables but every sketch or model I can think of tends to put a lot off stress on the cables or downloads tension when retracted depending on which side of the pivot point the pulleys are. This makes for some interesting spring configurations. If anyone has solved that I'd like to hear what solution was derived. * *The T bar idea Bildan suggests is interesting. I will have to do some cogitation on that one. Dan, U.S. Air Force, retired The system I described is used in some nose gear retract systems. However, it is very direct steering with no 'give'. Some systems use springs or elastomers to provide some 'softness' to the system. One reason for softness is crosswind landings. If you touch down with the controls crossed, (downwind rudder and upwind aileron) the nose wheel steering will cause the airplane to dart to the downwind side of the runway when the nosewheel touches unless the pilot remembers to center the rudder. Adding some torsional "give" and some caster helps with this. An alternative to the T-Bar is a small "rudder post" connected to the pedals with cables. The post is directly above and in line with the nose strut when it's extended. The nose strut makes a rotary connection with the post as the downlock engages. Sometimes this is a slot-and-tang or other coupling method. The slot-&-tang will have a bull nose on the tang and "V"lead-in on the slot so it engages smoothly even if the pedals and nose strut aren't exactly aligned at gear extension. Landing gear design is a tricky business and a lot of things aren't intuitive. One of my favorite stories is the last of the tailwheel piston fighters. Enough 20 year old 2nd Lt's ground looped these aircraft that the designers took notice and went back to their drawing boards (Literally). One solution was main gear struts that rotated outboard as they were compressed. The idea was that when a swerve leading toward a groundloop began, you wanted to "steer into the skid" as with a car. The rotating main struts did this aromatically as the aircraft weight shifted to the outboard main gear, compressing the strut, hopefully giving the 2nd Louie another few seconds to save his butt. |
![]() " I came up with a fairly simple idea using hydraulics with brake master cylinders to supply pressure. Problem is the wheel will either still steer when retracted making for a big wheel well or any disconnect system I can think of becomes complex beyond my pay grade. I had considered cables but every sketch or model I can think of tends to put a lot off stress on the cables or downloads tension when retracted depending on which side of the pivot point the pulleys are. This makes for some interesting spring configurations. If anyone has solved that I'd like to hear what solution was derived. Tension the cables correctly when gear is in the down position, and have the pulley at the pivot point arranged so some slack develops when gear is up. Keep the cable under slight tension while up, so it does not jump a pulley and so cables will not move the gear while up. That could be achieved by putting a pulley around the cable in a long run attached to a light spring going at a right angle to the cable run. That would keep things snug but allow movement. -- Jim in NC |
On Wed, 24 Jun 2009 08:13:28 -0500, Dan wrote:
I'm looking for a simple design for nose wheel steering for retractable gear. Any ideas? Dan, U.S. Air Force, retired Have you considered just having a castering nosewheel? That's what I have on my floats and it works pretty well steering with the brakes. |
Drew Dalgleish wrote:
On Wed, 24 Jun 2009 08:13:28 -0500, Dan wrote: I'm looking for a simple design for nose wheel steering for retractable gear. Any ideas? Dan, U.S. Air Force, retired Have you considered just having a castering nosewheel? That's what I have on my floats and it works pretty well steering with the brakes. Yes, differential braking is probably the simplest method. I'm not discarding it, just poking around at options. Dan, U.S. Air Force, retired |
F-111 Nose wheel | Glenn[_2_] | Aviation Photos | 0 | April 13th 08 09:30 AM |
A320 nose wheel steering | cam lowes | Simulators | 0 | July 19th 06 12:03 AM |
Looking for Cessna 206 or 310 nose wheel fork | mikem | Aviation Marketplace | 0 | October 27th 03 04:33 PM |
Looking for Cessna 206 or 310 nose wheel fork | mikem | Owning | 0 | October 27th 03 04:33 PM |
Nose wheel shimmy | JFLEISC | Owning | 2 | August 27th 03 03:28 PM |
