Nose wheel shimmy
Old August 25th 03, 12:53 AM
JFLEISC
Default Nose wheel shimmy
I read an interesting thread where someone pointed out that all shimmy
preventitive devices are designed to stop something that has already started,
and that wheel balancing may stop a shimmy from ever starting. Makes sense, but
my question is; What, if any, is the normal method of balancing aircraft tires,
how is it done, and what kind of weights or counter balance device is used?
Old August 27th 03, 02:39 PM
JDupre5762
I couldn't find a balancing machine to do such small wheels.
There are balancing devices, I can't call them machines, available. A good
aircraft tool catalog will probably have one. I think Goodyear made one
specifically for small aircraft wheels but others are of similar design and
basically are a pair of brackets that hold a threaded axle with sealed bearings
at each end. There are two threaded cones that are sused to trap the wheel
assembly on the axle and the axle is then placed onto the brackets so that the
bearings support the axle. Spin the wheel to warm the bearings and then stop
the wheel and rotate it 90 degrees and see it moves. Adhesive lead weights are
used on the light side of the wheel to correct the imbalance. You should be
able to rotate the wheel to any point and it will not settle to any other
point.
Cessna recommends wheel balancing and says their dealers
have the equipment. I've called dealers and they've never heard of it.
The Cessna style of balancing is more static than the other and consists of a
shaft with a point and an arbor that is placed into the wheel with a bubble
level in the end of the arbor. Weights are added until the bubble is centered.
It is important to set the arbor properly in each size of wheel. In twenty
years of aircraft maintenance only one shop out of dozens I have known or
worked in ever had the Cesssna set up.
John Dupre'
Piper 6.00x6 Nose Wheel and Fork? mikem General Aviation 5 March 6th 04 12:34 AM
VW-1 C-121J landing with unlocked nose wheel Mel Davidow LT USNR Ret Military Aviation 1 January 19th 04 06:22 AM
Looking for Cessna 206 or 310 nose wheel fork mikem Aviation Marketplace 0 October 27th 03 05:33 PM
The Little Wheel in Back Veeduber Home Built 6 September 8th 03 11:29 AM
Another cause of nosewheel shimmy Roger Long Owning 3 July 30th 03 12:10 AM
