Cold War ALternate Basing
Old August 5th 04, 10:02 AM
Guy Alcala
Default Cold War ALternate Basing
Kevin Brooks wrote:
"David Lesher" wrote in message
There's a long-standing Urban Legend that the Interstate Highway
system was designed to serve as replacement airfields The Day After.
See "One-Mile-in-Five"
http://www.snopes.com/autos/law/airstrip.asp
http://www.tfhrc.gov/pubrds/mayjun00/onemileinfive.htm
I seek to debunk this UL on an engineering basis. I think the
Interstate is unusable for multiple reasons, one of which is a 2-lane
highway is simply not wide enough for B-52/B-57, much less a B-36,
gear.
But I have had little luck finding the gear footprint of such
aircraft. Everyone talks wingspan. Suggestions/data?
I'd also like to compare PSI loads for such aircraft with those of
trucks.
Check old copies of the US Army's TM 5-430, IIRC; one was titled "Planning
and Design of Roads, Airfields, and Heliports in the Theater of Operations",
and the various USAF aircraft were listed by type with data regarding
pavement loading and minimum operating strip dimensions. Not sure that the
current TM manual is the same as the older versions; ISTR the older ones
were a 5-500 series pub, but that just may be due to hazy memory.
AFPAM 10-1403 lists required runway and taxiway widths and lengths, as well as
ACN requirements for each type of a/c. Not quite what you're asking for, but
should get you going. fas.org has it online:
http://www.fas.org/man/dod-101/usaf/...pam10-1403.htm
Until recently all of the army FM/TM were online at TRADOC's website, including
the one Kevin mentions, but it appears that it's now restricted to official use.
Guy
Old August 5th 04, 10:11 AM
M
Kevin Brooks
Some European nations (especially Sweden) did indeed design roadways
to handle dispersed aircraft operations, but that was aimed primarily
at tactical fighters.
Indeed. And most (all?) the Swedish jet fighters. An example of
adoption for road bases is the unusual thurst-reversal engine
exhaust of Viggen, which dramatically cuts the lenght of the
landing run.
In Finland too, the airforce planned (and still does) to operate
dispersed from highway bases in war. There are also sections of
highways specifically designed as bases, being wide, straight
and with a runway profile and markings. While not designed for
road bases, the fact that the current F-18's of the FAF are
carrier planes, is helpful. For example, they do arrested
landings on prepared highway strips.
Some Soviet tac fighters, too, are well adapted for operations
from improvized bases, even unpaved runways. MiG-29 being a good
example: STOL, tough undercarriage and unusual alternative air
intakes for take-off and landing for avoiding FOD.
What really surprizes me, is that the US tac fighters of
the cold war era stationed in Europe didn't, as far as
I know, plan for dispersed operatons. Did they really think
that their bases would survive in the 'big' war? And,
consequently, the planes weren't (aren't) that well suited
for such operations either (eg F-16, although I think that
Norway operates its Vipers from road bases too).
Old August 5th 04, 12:18 PM
Steve Mellenthin
The South Korean equivalent of the Interstate highway system has wide spots all
over it 200-300' wide and 12,000' long at a guess with taxiways as well. They
exercize them from time to time, at least they used to.
Old August 5th 04, 09:37 PM
B2431
snip
Actually there were several dispersment plans. Look at the autobahn, there were
more sites than the Luftwaffe could use. I remember someone pointing out a rest
stop near Stutgardt as being laid out as a parking ramp for fighters. We went
back and looked at it and it seemed plausible to me.
USAFE also had plans for deployment to other countries and civil airports.
It is interesting to note West German bridges used to have orange signs showing
maximum weight for tanks as well as trucks.
Dan, U.S. Air Force, retired
Old August 5th 04, 02:58 PM
Chad Irby
gear.
However, much of the system was just dandy for pretty much anything
except the big bombers, and most of the fighter aircraft of the Cold War
would have had little or no problem flying from some of the wider
Interstate highway sections.
You should also note that some parts of the more remote Interstate
system were wider than two lanes in places that really didn't
technically need two lanes for the traffic involved. If you're
addressing the engineering aspect, you should look at why they built the
Interstates so much wider and thicker than trucks of the day needed, by
a large factor.
I think it's more of a case of "plan on using roads for temporary
fighter fields if we need to." The bombers had enough range to be able
to fly from a much more restricted system of bases or airports, while
the fighters, especially those of the time, would have needed a more
comprehensive list of places to fly from, especially out in the middle
of the less-populated Western and Central states.
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Old August 5th 04, 04:17 PM
George Shirley
gear.
a large factor.
The primary purpose behind the Eisenhower National Highway System, IIRC,
was to provide a strategic highway network for moving military goods and
troops. If you look on the DOT pages for the NHS you will find a map
showing most of the strategic highways and they are interstates that
lead to the US borders and strategic points including ports. I think the
aircraft landing portion was just incidental and possibly deliberate in
the more desolate areas.
I was in my mid to late teens when the system was started and ISTR that
the original purpose was as described above. Regardless of reason for
building there are some states and areas within states that it is almost
worth your life to drive the IH system due to poor maintenance. I
certainly wouldn't want to land an aircraft around here in Louisiana
where I live now. Of course we've got enough closed AF bases that we
have lots of big, long runways now. VBG
George
Old August 6th 04, 09:00 AM
Ragnar
"Chad Irby" wrote in message
If you're
a large factor.
Actually, the engineers who designed the roadbeds thought ahead to heavier
/bigger vehicles using the highway systems.
I've scanned the laws that brought the highway system into being, and there
isn't ONE, not ONE, reference to using them as runways for military
operations. There are references to making sure they were X feet wide and
could support vehicles of Y weight, but they were thinking about Army
equipment being transported and not airplanes.
Old August 5th 04, 06:41 PM
Steve Mellenthin
I suspect the planners thought the aircraft would not..
At most bases in Europe the planes were dispersed around the taxiways all over
the air patch. Most were parked in hardened shelters called Tab Vs complete
with blast doors in front and high spped taxiways and IIRC many were sealed and
filtered for chem-bio warfare.. .
alternate carb heat Ray Toews Home Built 16 October 29th 04 12:41 PM
Cold War relic F/A-22 initially designed for air-to-air combat with Soviet MiGs Larry Dighera Military Aviation 7 April 2nd 04 07:05 PM
Alternate Intersection Name in Brackets? Marco Leon Instrument Flight Rules 7 January 22nd 04 04:55 AM
Alternate requirements Anthony Chambers Instrument Flight Rules 8 September 17th 03 09:45 PM
B-52 lands on Cold War enemy's airfield for show Otis Willie Military Aviation 1 August 23rd 03 11:11 PM
