alternate carb heat
Old October 17th 04, 07:03 PM
Ray Toews
Default alternate carb heat
Has anyone ever tried using cowling air under the engine as heated air
for carb heat.
Because of tight cowling space I am thinking of building a door in the
lower cowl for fresh ram air and then closing it and drawing air from
under the engine, cooling air coming off the cylinders which seems to
run about 120 degrees as my heated air in case of carb ice.
I have measured the under engine air on two airplanes now and it seems
to run around 120 deg. so this must be fairly typical and would seem
to be more than adequite to get rid of carb ice. I have never had the
opportunity to measure heated air coming off exhaust manifold.
I would build it so fresh ram air is unfiltered and alternate, heated,
air would be filtered. in this way I would always taxi using warm
filtered air but in normal flight use cold ram air.
Makes sense to me, but then so does capitalism.
Ray
Heat treating 4130 RAM Home Built 0 July 18th 04 05:33 PM
Painting and air cooled motor? CitizenX Home Built 5 June 30th 04 01:47 PM
28 volt pitot heat B2431 Home Built 15 April 17th 04 04:25 PM
Heat treating wing ribs Holger Stephan Home Built 13 February 4th 04 12:59 AM
Carb Temperature Gauge fly_the_skies Home Built 6 January 14th 04 04:32 PM
