#41
Tests have shown that the air flow through the cowling of an airplane is
much slower than the dispersion velocity of this product.Â* I don't have data for the Stemme, but I'd imagine it's similar. You can't close the vents in a Stemme while the engine is running without incurring a bill in excess of $35-40 thousand dollars. The Stemme has a fire warning system which alarms before these tubes release their suppressant thereby allowing the pilot to close the fuel valve and shut down the engine. The cost of this system is less than that of an iPhone. I doubt this system would work in a glider with an open engine bay. On 12/11/2019 3:38 PM, Dave Nadler wrote: On Wednesday, December 11, 2019 at 3:16:32 PM UTC-5, Dan Marotta wrote: Several of the Stemme owners are looking at this product: https://proteng.com/pictures/ That looks like a good solution for a closed space, but will it have a meaningful effect in an area with air forced through at high volume? Would you have a separate warning so you'd know to close the Stemme vents? Probably wouldn't work in an MG with an open engine bay (doors that don't close)? -- Dan, 5J |
#42
On 12/8/19 9:59 AM, Dave Nadler wrote:
On Sunday, December 8, 2019 at 11:46:36 AM UTC-5, kinsell wrote: No one has mentioned jets? They can be unreliable to get started, and there's been uncontained blade failures. Even had the engine depart the A/C. Interesting, I've heard of numerous failures to start and failure to climb, but not uncontained blade failures or engine departing AC... Page 23 on http://www.doc.glidingaustralia.org/...ies&Itemid=101 this is probably the same incident I remembered, but that version had the farmer making two trips to deliver spare parts. |
#43
Dave said:
Please email to me offline. And what is your email? |
#44
On Wednesday, December 11, 2019 at 9:07:15 PM UTC-5, kinsell wrote:
http://www.doc.glidingaustralia.org/...ies&Itemid=101 For those who haven't seen these consolidated incident summaries, GFA does an really excellent job. I always read the summaries in S&G, but hadn't seen these befo http://www.doc.glidingaustralia.org/...ence-summaries |
302 security failures | T8 | Soaring | 17 | April 8th 10 03:33 AM |
MH EDS failures | Philip Plane | Soaring | 6 | December 16th 05 12:37 AM |
Colibri failures? | [email protected] | Soaring | 3 | April 15th 05 12:30 AM |
Colibri Failures. | Stan Kochanowski | Soaring | 2 | April 6th 05 01:00 PM |
Colibri Failures. | Stan Kochanowski | Soaring | 1 | April 6th 05 12:24 PM |
