Looking for pictures of motorglider failures
Old December 7th 19, 05:27 PM posted to rec.aviation.soaring
Dave Nadler
Default Looking for pictures of motorglider failures
I've been persuaded to give an OSTIV talk about motorglider safety issues,
in particular propulsion system failures. I'm going to discuss
common failures, the systemic reasons this stuff has happened and
WILL CONTINUE to happen, and some ideas for systemic improvements.
I'm looking for pictures and/or documentation of failures, for example:
- failed position switches (ie limit switches, prop position sensor)
- failed fuel systems (improper hoses, routing, leak sources, etc)
- failed structural components (cracked exhaust, mounts, pylons, etc)
- failed drive belts
- failed electrical connectors
- failed motor controller
- failed electronics
and anything else you might happen to have.
Ideally a good photo, make and model, approximate date, brief description.
Please email to me offline.
Thanks in advance for the help!
Best Regards, Dave
PS: Probably time to redo this study, but situation isn't that much changed:
http://www.nadler.com/public/DeRese_...ilplanes.p df
Old December 7th 19, 07:29 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dave Nadler wrote on 12/7/2019 9:27 AM:
Best Regards, Dave
Things have changed, big time: used to be only gasoline engines, now we have
electric motors, so add to the list:
- failed propulsion motor
- failed motor batteries
- failed motor battery chargers
- failed cooling fans
Old December 7th 19, 09:39 PM posted to rec.aviation.soaring
Dave Nadler
Thanks Eric - Can you forward this on to ASA and provide some photos?
Old December 8th 19, 02:46 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dave Nadler wrote on 12/7/2019 1:39 PM:
Yes, I'll ask the members to help out.
Old December 8th 19, 04:46 PM posted to rec.aviation.soaring
kinsell
No one has mentioned jets? They can be unreliable to get started, and
there's been uncontained blade failures. Even had the engine depart the
A/C.
Old December 8th 19, 04:59 PM posted to rec.aviation.soaring
Dave Nadler
A/C.
Interesting, I've heard of numerous failures to start and failure to climb,
but not uncontained blade failures or engine departing AC...
Old December 8th 19, 05:38 PM posted to rec.aviation.soaring
Dan Marotta
HERE https://www.youtube.com/watch?v=Puia_yQxir8&feature=youtu.be is
an example of a jet sustainer failure to start.Â* Good glide path
control, but I thought he may have waited a bit longer than required
before dumping his ballast.
A/C.
Dan, 5J
Old December 12th 19, 02:07 AM posted to rec.aviation.soaring
kinsell
A/C.
Page 23 on
http://www.doc.glidingaustralia.org/...ies&Itemid=101
this is probably the same incident I remembered, but that version had
the farmer making two trips to deliver spare parts.
Old December 8th 19, 01:57 AM posted to rec.aviation.soaring
son_of_flubber
Lacking experience sustainer, I need some help interpreting Section 2.2.1 'Usage frequency'.
Is the report saying that pilots use the sustainer to avoid outlandings on 69-70% of flights?
Does anyone have links to previous discussions of this report in English?
Old December 8th 19, 12:02 PM posted to rec.aviation.soaring
Later on it explains that most of these are “test runs” early in the flight while local to the home airfield. I suspect this practice is more common in Europe than in the states, although I haven’t flown around sustainer sailplanes enough to know for sure.
302 security failures T8 Soaring 17 April 8th 10 03:33 AM
MH EDS failures Philip Plane Soaring 6 December 16th 05 12:37 AM
Colibri failures? [email protected] Soaring 3 April 15th 05 12:30 AM
Colibri Failures. Stan Kochanowski Soaring 2 April 6th 05 01:00 PM
Colibri Failures. Stan Kochanowski Soaring 1 April 6th 05 12:24 PM
