Do you have to record a TN in the aircraft logbook ?
Old January 14th 20, 07:00 PM posted to rec.aviation.soaring
Default Do you have to record a TN in the aircraft logbook ?
For an experimental glider, do you have to record a TN performed on the glider ?
Does it need and A&P signature ?
Dan
Old January 14th 20, 10:17 PM posted to rec.aviation.soaring
Short answer..........Yes. Why wouldn’t you record a factory ordered TN? If it required specialized work, then the fellow who did the work should put it in the logs. Many TN’s end up as AD’s and the AD is signed off as “ complied with by installing TN xxxx.
Hope this helps,
JJ
Old January 14th 20, 10:33 PM posted to rec.aviation.soaring
Darryl Ramm
Dan
I would hope that questions like this go to the person who does your annual condition inspection. Including discussing with them any work you intended to do on the glider before doing it.
Is the TN a major alteration? Likely not, but if it is... what does your operating limitations say? If it is your FSDO likely needs to get involved and you need to go back to a test flight program. If it's not a major alteration...
You should be recording all significant stuff in the log. Including TNs. Why would you not, you want to establish the glider was well maintained and TNs complied with.
Unlike a type certified glider you don't need an A&P IA (or A&P) signature for a return to service.
Old January 15th 20, 12:04 AM posted to rec.aviation.soaring
Another of the many reasons for logging maintenance work is resale. The prospective buyers might want to know.
Raul Boerner
Old January 15th 20, 01:48 AM posted to rec.aviation.soaring
"Unlike a type certified glider you don't need an A&P IA (or A&P) signature for a return to service "
So I can perform a TN or an AD (?) myself, without an A&P signature for an experimental "Racing and exhibition" glider ?
Dan
Old January 15th 20, 02:16 AM posted to rec.aviation.soaring
ADs specify what they require and who must do them. TNs often do as well. And don't let anyone tell you that ADs don't apply to experimental ships.
Old January 15th 20, 03:01 AM posted to rec.aviation.soaring
The guy that did the TN should sign it off in the log book! Your annual inspection authority will double heck if he has any questions. I have signed off a TN on the Duster before I was an A&P with my pilot license number and signature.
JJ
Old January 15th 20, 03:20 AM posted to rec.aviation.soaring
Daniel Sazhin[_2_]
Performing TNs with an A&P is SOP. A TN could become an AD. And an AD would make you INOP, which would mean you would need your A&P ASAP. So IMO, you should follow the SOP and talk to your A&P.
YMMV.
LOL!
Old January 15th 20, 03:28 PM posted to rec.aviation.soaring
SMDH...
Old January 16th 20, 12:30 AM posted to rec.aviation.soaring
Mike N.
RTFM
How much does a lost aircraft logbook effect resale value? [email protected] Soaring 12 September 10th 19 05:46 AM
Siemens' 110 lb world-record electric aircraft motor produce 348 hp at 2,500 RPM Larry Dighera Piloting 29 December 2nd 15 09:29 PM
German Aircraft Logbook vontresc Soaring 2 April 1st 14 03:25 PM
Looking for info on world record jet aircraft Ted Parvo Home Built 25 July 17th 12 02:23 PM
