How much does a lost aircraft logbook effect resale value?
Old September 9th 19, 01:29 AM posted to rec.aviation.soaring
Default How much does a lost aircraft logbook effect resale value?
I've been approached by an estate of a former club member who's glider is stored at my club. Its a 1978 PIK20-D. They have gone through his entire belongings and have not found any logbooks for the glider. Our club records indicate the glider has not flown since 2003. Its been at the club since at least 1998. We have gone through the plane and trailer and no logs. Its a certified aircraft and our local AI said there is a process to start a new log book after an inspection. The question I ask is how much value is lost with no history of the airframe? I'm trying to help the estate come up with a reasonable value.
Old September 9th 19, 02:34 AM posted to rec.aviation.soaring
Roy B.
Over the years I've been in the sport (46 now) I've seen a fair number of gliders sold without log books, or with "reconstructed logbooks" etc. I also once saw a bank repossess a glider and the owner "ransom" the logs for $500 to the bank's new purchaser. A lot depends on the glider type (does it have a low maximum life limit?), desirability of the glider and sophistication of the purchaser. Probably a 10% value reduction is a good estimate. For me - with the glider you describe - a bigger issue would be potential water and vermin damage, brittle tubing and similar age/storage issues. I think the "Ds" were a little more saleable than the flap only version. You may also find this link helpful:
https://www.traficom.fi/sites/defaul...n_20151115.pdf
Good luck
ROY
Old September 9th 19, 03:55 AM posted to rec.aviation.soaring
Duster[_2_]
Though it won't replace a missing logbook, the FAA maintains a database of each aircraft on registration, bills of sale and some AD's, STC's, etc. that require reportable compliance of modifications. They'll send you a paper copy or CD ($10). Who knows, it might fill in some missing blanks.
https://www.faa.gov/licenses_certifi...craft_records/
Old September 9th 19, 05:08 AM posted to rec.aviation.soaring
In this particular case I say hardly at all - no life limit specified by PIK? Someone needs to make an affidavit of estimated time.
Old September 9th 19, 07:22 AM posted to rec.aviation.soaring
2G
How do you establish the total time w/o logbooks? Most gliders have life-limits that are just not guidelines. Personally, I wouldn't touch it, but if you do, discount the value by 50% because you will need it when it comes time to sell.
Old September 9th 19, 10:56 AM posted to rec.aviation.soaring
Cookie
Look up "theory of the greater fool"
Glider without log books is a big problem for the owner.
If you buy this glider, the previous owner not only got rid of that big problem, but made his problem YOUR PROBLEM, and even got you to pay for it!
Cookie
Old September 9th 19, 11:12 AM posted to rec.aviation.soaring
Charlie Quebec
I don’t know how you do things in the US, but here in Australia, the yearly inspection paperwork known as a form 2, must be returned to the GFA, and this contains an entry including TTIS hours and launches at each inspection. I would have thought this would be standard practice in a responsible airworthiness regimen.
Old September 9th 19, 12:06 PM posted to rec.aviation.soaring
Eric Munk
https://www.traficom.fi/sites/defaul...0_20151217.pdf
Fatigue life for the PIK-20D is 65,000 hours, with 5,000 interval
inspections for aircraft that have over 10,000 hours.
Don't think that the hours flown should present a problem...
Old September 9th 19, 02:33 PM posted to rec.aviation.soaring
Bob Youngblood
Personally I would not bee too concerned about a lost log. You can start all over and create a new log going forward. A good inspection of the glider should allow you the ability to determine the overall condition and other variables. Don't give up on finding the logs. the old owner stashed them away and the family may just find them. It happened to me recently with a Pawnee, and I did get all the logs.
Discount the price a bit and move forward with a good inspection and enjoy that glider. Find the past couple of owners or someone who can give you details on how much the bird flew and try to determine approximate time.
Old September 10th 19, 03:00 AM posted to rec.aviation.soaring
2G
This all depends upon what you mean by "a bit." I would suggest "a lot," like 50%.
German Aircraft Logbook vontresc Soaring 2 April 1st 14 03:25 PM
ground effect craft aka ekranoplan: ship or aircraft? mad8 Piloting 6 February 16th 07 08:27 AM
Iran Deploying a Ground-Effect Attack Aircraft? Jay Honeck Piloting 5 April 5th 06 04:36 AM
Prop strike effect on resale value? John Doe Owning 12 November 24th 05 01:34 AM
down the road resale Rob Home Built 10 September 26th 03 11:36 PM
