1-26A Ser 006 Tire and tube
Old March 11th 20, 04:47 PM posted to rec.aviation.soaring
Default 1-26A Ser 006 Tire and tube
Hi guys, I recently purchased a 126 a serial number 0 0 6 it has been stored for a very long time and probably has the original Tire still on it I am looking for a 4.00 / 4.80 -4 tire and tube. Ive tried the 126 News Group with no luck they won't approve my listing yet it's been a couple of weeks so I thought I would try here.
Cliff Hilty CH ASW27 & 1-26A 006
Old March 11th 20, 05:28 PM posted to rec.aviation.soaring
No longer available.
Replace with 4.00-4. Desser has it. Flatter "ribbed" profile works better for brake. You will have to rework the brake band due to slightly larger diameter.
Good luck
UH/002
Old March 11th 20, 05:49 PM posted to rec.aviation.soaring
What UH said no big deal put her on there and enjoy. Are u a member of 1-26 assoc yet? Great group and once your a member we have a email chain where u can get answers to anything 1-26 imaginable.
Dan #225,274
Old March 11th 20, 07:30 PM posted to rec.aviation.soaring
UH and I owning SGS-126 SN 002..... yes, normally use a 4.00 x 4.00 tire and tube....
Yes, "brake band" on tire OD may need some tweaking (due to different tire tread...).....not that a band brake worked well in the dry, forget about it on damp/wet grass....but you should be able to land slow...;-)
Trust me....BTDT.....
Old March 11th 20, 10:08 PM posted to rec.aviation.soaring
Dan Marotta
Trade in that Ventus?
Dan, 5J
Old March 11th 20, 11:42 PM posted to rec.aviation.soaring
Thanks guys for the clarity Ill check with desser but didnt see the 4.00-4 right off. No Dan, sold the Ventus 2 years ago for a 27, jut bought this 1-26 on a whim (read cheap) with the hope of letting others fly her around AZ
Old March 11th 20, 11:48 PM posted to rec.aviation.soaring
410/350-4 4 PLY TRAC TIRE ONLY is the only tire that desser list on there web site. UH is that the one you are refering to?
CH
Old March 12th 20, 01:09 AM posted to rec.aviation.soaring
Scott Williams[_2_]
CH
wings and wheels has a 4-400 (400-4?) Aero classic, I used one of these on an SHK.
It was okay and might work well on a 1-26, but it was not as high quality as a Tost 4-400, but the aero classic was 2/3 the tost tire, aero classic was not as 'round'.
good luck,
Scott
Old March 12th 20, 01:14 PM posted to rec.aviation.soaring
CH
I understand from others that that one works fine.
I have a 4.00-4 with a flat profile(Aero Classic Rib) on 002 and our other 1-26's.
Part number is 06-00944 from AC Spruce. It has a flatter contact face that wears out more slowly with the band brake.
UH/002
Russia 5M tire and tube? Waveguru Soaring 4 March 14th 18 04:59 PM
What's the best way to install a new tire tube ? [email protected] Soaring 14 March 9th 09 11:46 AM
FA: Aircraft tire and tube, New, 500 x 5 [email protected] Home Built 1 February 3rd 06 10:42 PM
FA: Aircraft tire and tube, New, 500 x 5 [email protected] Aviation Marketplace 1 February 3rd 06 10:42 PM
Puchacz Tire and Tube [email protected] Soaring 1 September 14th 04 06:17 AM
