I have an ASW-15B. Anyone have any good advice to make sure I safely
and securely install a new "tube" inside my tire? The tire tread looks good, it just needs air everytime I show up to fly it. I would hate to blow a flat on takeoff then have to reject or worse end up in a ground loop due to a blowout....could happen. If anyone has any steps, measures or procedures that they can pass on, I would really like to know. I have never put a tube on an airplane before, I have put tubes on bicycle tires, which I imagine the basic basic steps are roughly the same. Any knowledge....please advise. SA |
Have you tried 'Fix-a-Flat' from an aerosol can? Worked well for me so
far. Bob On Mar 6, 10:32*pm, wrote: I have an ASW-15B. *Anyone have any good advice to make sure I safely and securely install a new "tube" inside my tire? *The tire tread looks good, it just needs air everytime I show up to fly it. I would hate to blow a flat on takeoff then have to reject or worse end up in a ground loop due to a blowout....could happen. *If anyone has any steps, measures or procedures that they can pass on, I would really like to know. *I have never put a tube on an airplane before, I have put tubes on bicycle tires, which I imagine the basic basic steps are roughly the same. *Any knowledge....please advise. SA |
On Mar 6, 9:32*pm, wrote:
I have an ASW-15B. *Anyone have any good advice to make sure I safely and securely install a new "tube" inside my tire? *The tire tread looks good, it just needs air everytime I show up to fly it. I would hate to blow a flat on takeoff then have to reject or worse end up in a ground loop due to a blowout....could happen. *If anyone has any steps, measures or procedures that they can pass on, I would really like to know. *I have never put a tube on an airplane before, I have put tubes on bicycle tires, which I imagine the basic basic steps are roughly the same. *Any knowledge....please advise. SA Have you tried tightening or replacing the valve stem yet? |
On Mar 6, 8:31*pm, Eric Greenwell wrote:
wrote: I have an ASW-15B. *Anyone have any good advice to make sure I safely and securely install a new "tube" inside my tire? *The tire tread looks good, it just needs air everytime I show up to fly it. I would hate to blow a flat on takeoff then have to reject or worse end up in a ground loop due to a blowout....could happen. *If anyone has any steps, measures or procedures that they can pass on, I would really like to know. *I have never put a tube on an airplane before, I have put tubes on bicycle tires, which I imagine the basic basic steps are roughly the same. *Any knowledge....please advise. How old are the tire and tube? If it's more than 10 years, I recommend a new tire and tube; if it's less than 5 years, remove the tire and tube and inspect it. In between - probably worth doing either one. I have no idea how to do this properly unless it's a Cleveland wheel, the only kind I'm familiar with. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes"http://tinyurl.com/y739x4 * * * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org Most glider wheels that I've seen have a hub that bolts together. It's a LOT easier to change out a tire/tube than most types of tires. Let all the air out, then unbolt the wheel halves. Once they're unbolted, it may take a bit of effort to get it loose from the tire, but once you get one wheel half out, it should be very easy to remove the tube and replace it. With the new tube in place, put enough air in it to keep it from being pinched when you bolt the wheel halves back together. Avoid cheap tubes. I bought and installed a cheapo last year, and regret it. I have to add air to the tire every other week. |
![]() "Uncle Fuzzy" Most glider wheels that I've seen have a hub that bolts together. It's a LOT easier to change out a tire/tube than most types of tires. Let all the air out, then unbolt the wheel halves. Once they're unbolted, it may take a bit of effort to get it loose from the tire," What Uncle Fuzzy said *except*! If you plan to re-use the tube, and maybe even if not, you do not want to unbolt the wheel halves until after you break the tire beads. Let the air out, break the beads, then unbolt the wheel halves. If you do unbolt the wheel halves first, and then have difficulty breaking the beads, it's easy to pinch the tube between the wheel halves as you work to get the beads pushed towards the center of the wheel. bumper zz Minden |
![]() What Uncle Fuzzy said *except*! If you plan to re-use the tube, and maybe even if not, you do not want to unbolt the wheel halves until after you break the tire beads. Let the air out, break the beads, then unbolt the wheel halves. If you do unbolt the wheel halves first, and then have difficulty breaking the beads, it's easy to pinch the tube between the wheel halves as you work to get the beads pushed towards the center of the wheel. bumper zz Minden Yeah! What HE said.... |
On Mar 6, 11:05*pm, "bumper" wrote:
"Uncle Fuzzy" Most glider wheels that I've seen have a hub that bolts together. It's a LOT easier to change out a tire/tube than most types of tires. Let all the air out, then unbolt the wheel halves. *Once they're unbolted, it may take a bit of effort to get it loose from the tire," What Uncle Fuzzy said *except*! If you plan to re-use the tube, and maybe even if not, you do not want to unbolt the wheel halves until after you break the tire beads. Let the air out, break the beads, then unbolt the wheel halves. If you do unbolt the wheel halves first, and then have difficulty breaking the beads, it's easy to pinch the tube between the wheel halves as you work to get the beads pushed towards the center of the wheel. bumper zz Minden But then what do you do with those cans of Fix-a-Flat? Luckily there you don't need to waste those cans. The propellant can give you quite a buzz... so if you stick the hose in your nose and give it a little quirt you can get a convenient high. Just *don't* shake the can beforehand and hold it perfectly upright because you don't want too much of that goo going up your nose (a little won't hurt). --- Grrr. If your tire or valve is leaking *fix it*. Who wants to spend a flight worrying about whether some junk fix-a-flat repair might have failed or whether it is masking some serious problem like a pinched inner tube. Who even wants to waste a trip to the gliderport to fly to find the Fix-a-Flat has failed. And Fix-a-Flat et al takes a while to set, how are you supposed to spin the wheel long enough to get the stuff to coat properly? I bet you'll feel the out of balance from the ball of latex snot in the bottom of the tube. Sigh Darryl |
On Mar 6, 8:32*pm, wrote:
I have an ASW-15B. *Anyone have any good advice to make sure I safely and securely install a new "tube" inside my tire? *The tire tread looks good, it just needs air everytime I show up to fly it. I would hate to blow a flat on takeoff then have to reject or worse end up in a ground loop due to a blowout....could happen. *If anyone has any steps, measures or procedures that they can pass on, I would really like to know. *I have never put a tube on an airplane before, I have put tubes on bicycle tires, which I imagine the basic basic steps are roughly the same. *Any knowledge....please advise. SA What everybody else said - plus I'd suggest coating the tube and inside of the tire with talc to prevent the tube from sticking. That helps the tube even itself out reducing the chance of wrinkles and pinching. |
there is only one way....remove the wheel, split the hub after removing the
5 bolts on 5" wheels (only three if it's the older type 4" wheel) that hold the two halves together and remove and replace the old inner tube with a new one..reverse the procedure and re-install.....You probably might as well replace the old tire too unless it is only a few years old....tires do degrade with time so even one with plenty of tread (I rarely see glider tires that show much tread wear since most are flown off grass and spend little time and energy on the ground) This is one maintenance area where owner/operators are allowed to do the work without an A&I sighing it off. tim Please visit the Wings & Wheels website at www.wingsandwheels.com wrote in message ... I have an ASW-15B. Anyone have any good advice to make sure I safely and securely install a new "tube" inside my tire? The tire tread looks good, it just needs air everytime I show up to fly it. I would hate to blow a flat on takeoff then have to reject or worse end up in a ground loop due to a blowout....could happen. If anyone has any steps, measures or procedures that they can pass on, I would really like to know. I have never put a tube on an airplane before, I have put tubes on bicycle tires, which I imagine the basic basic steps are roughly the same. Any knowledge....please advise. SA |
FA: Aircraft tire and tube, New, 500 x 5 | [email protected] | Home Built | 1 | February 3rd 06 10:42 PM |
FA: Aircraft tire and tube, New, 500 x 5 | [email protected] | Aviation Marketplace | 1 | February 3rd 06 10:42 PM |
Puchacz Tire and Tube | [email protected] | Soaring | 1 | September 14th 04 06:17 AM |
Beech 18 Tailwheel tire tube | georg | Restoration | 4 | June 2nd 04 01:00 PM |
FS: New 1-26 Tire | Slick | Soaring | 0 | April 20th 04 01:27 AM |
