There was a question posed on parachute static lines from a previous thread that I don't think was addressed. How do you configure one? How long and strong a cable and what kind of clips to use? Some cockpits have an attachment ring for this purpose, but where do you clip it for those that don't?
Original Post: "Any comments on static lines? My S-H glider has an in cockpit attachment point for a static line. I am interested in comments on bailing out in am emergency. Not as interested in the captain obvious comments like "you could accidentally open your chute after a normal landing getting out of your glider". That is implicit and obvious.Thoughts on actual emergency bailouts, static line versus regular D handle?" |
That was my question.
The general advice I received was to ask a qualified rigger. I am still very interested in doing a static line conversion to my parachute, just have not had the time to follow up on it. Further information is of course appreciated. |
On Sunday, June 14, 2020 at 2:28:39 PM UTC-5, Dee wrote:
There was a question posed on parachute static lines from a previous thread that I don't think was addressed. How do you configure one? How long and strong a cable and what kind of clips to use? Some cockpits have an attachment ring for this purpose, but where do you clip it for those that don't? Original Post: "Any comments on static lines? My S-H glider has an in cockpit attachment point for a static line. I am interested in comments on bailing out in am emergency. Not as interested in the captain obvious comments like "you could accidentally open your chute after a normal landing getting out of your glider". That is implicit and obvious.Thoughts on actual emergency bailouts, static line versus regular D handle?" After Dave Nadler’s presentation at the Little Rock SSA convention I asked for the same advice you’re looking for. His response was very emphatically that a qualified parachute rigger is the only one who should install the line. He said I should take a picture of the attach point in the glider, and have the rigger install the static line per your parachute’s requirements. I suspect he’d be willing to post his reply with the points he made to me. |
I've used static lines for 40 years that connect the D ring on the parachute to the factory provided connection in the ship. Could make a difference if you bang your head going out or can't find the D ring (happened to me once sky diving). The idea came from flying fighters in the 60's and 70's that had what was called a "zero delay lanyard" that connected the D ring on the chute to the ejection seat. This lanyard was connected before take off and removed above a couple thousand feet, and then reconnected before landing. You didn't want the chute opening immediately at high altitude or high air speeds. The length of mine is half a wing span, with the nylon strapping layered together and contained by rubber bands. See pics at: http://karlstriedieck.com/Parachute_Lanyard.pdf Make sure the tube your D ring cable runs through is securely sewn to the harness so that an out-of-alignment yank by the lanyard doesn't rip it loose.. Karl Striedieck karls at uplink.net |
You probably wanted to disconnect it AFTER landing also, lest your immediate charge off the flight line in search of a beer render you a victim of unintended cross-country excursions on a windy day. |
The length of mine is half a wing span, with the nylon strapping layered together and contained by rubber bands. See pics at: http://karlstriedieck.com/Parachute_Lanyard.pdf Make sure the tube your D ring cable runs through is securely sewn to the harness so that an out-of-alignment yank by the lanyard doesn't rip it loose. Karl Striedieck karls at uplink.net At last, very helpful! Thank you KS. Dee |
https://www.youtube.com/watch?v=9Kx-buGUOhw I love the way he just kept pontificating as the chute slowly filled, and then when he "helped" it along. Lucky he was in a nice grassy English field. In New Mexico or Arizona, he would be looking for Band-Aids and tweezers. Or maybe Vise-Grips. |
On Wednesday, June 17, 2020 at 7:19:45 AM UTC-5, wrote:
https://www.youtube.com/watch?v=9Kx-buGUOhw Thanks, that was a delightful morning wakeup. His chest strap had a quick release that didn't look all that quick when he needed it. When I bought my Softe, Allen suggested a normal buckle with the tail looped back on itself for quick release. Wonder if that works better? |
Le mercredi 17 juin 2020 15:36:07 UTC+2, a écritÂ*:
On Wednesday, June 17, 2020 at 7:19:45 AM UTC-5, wrote: When I bought my Softe, Allen suggested a normal buckle with the tail looped back on itself for quick release. Wonder if that works better? I think that's actually a brilliant idea. |
| Thread Tools | |
| Display Modes | |
| CASA C-212 Aviocar pics 3 [5/5] - USASOAC C-212 conducting static-line parachute operations.jpg (1/1) | Miloch | Aviation Photos | 0 | August 26th 18 04:02 PM |
| Chutes - manual or static line (automatic)? | [email protected] | Soaring | 3 | May 3rd 12 03:25 PM |
| Static Line Parachutes | GM | Soaring | 4 | January 14th 08 01:08 AM |
| Sharing static and pitot line | Istvan Csonka | Soaring | 13 | March 12th 05 04:00 AM |
| Getting students to line up with the center line | BoDEAN | Piloting | 27 | April 21st 04 12:23 PM |
