Replacement axle for Eberle trailer
Old November 12th 20, 02:52 AM posted to rec.aviation.soaring
5Z
Default Replacement axle for Eberle trailer
A friend just had the axle break on his Eberle trailer. Any thoughts on an easy swap? Or should he rent a flatbed to get it home then take his time to replace it?
He's about 50 miles inside Virginia on I-81 on his way to the DC area.
5Z
Old November 12th 20, 03:15 AM posted to rec.aviation.soaring
A roadside axle swap is probably not an option, since you will not likely find a direct replacement. Even if the axle can be repaired on site (welded or patched together somehow) the trailer will probably have to be jacked up, the axle removed, repaired and then reinstalled by someone with the right portable equipment.
Rent the flatbed and get it home. Don't risk the trailer, the glider and possibly your car (and your life!) trying to tow a compromised trailer. And if it breaks free while trying to tow it, you are also putting other motorists at risk. And sending up a big red flag for the circling personal injury lawyers.
Old November 12th 20, 05:07 AM posted to rec.aviation.soaring
AS
What Mark said.
Then find out what brand the original axle is and find the US distributor for it. We are currently going through that exercise after the axle of our TwiAstir got damaged. It is a 1 to 1 drop-in replacement and is on the way from the Fatherland.
Uli
'AS'
17M Eberle Trailer Phil Chidekel Soaring 0 July 28th 19 02:18 PM
Need a new axle for my eberle trailer .... Peter Deane[_2_] Soaring 10 July 23rd 18 01:56 PM
Looking for an Eberle trailer door SoaringXCellence Soaring 4 August 11th 16 05:08 AM
weight of an Eberle trailer raymond herr Soaring 3 November 27th 11 06:20 PM
Eberle trailer wheel rims Bob Soaring 7 November 25th 11 05:39 PM
