COBRA Hydraulic Jack
Old November 20th 20, 07:42 PM posted to rec.aviation.soaring
Default COBRA Hydraulic Jack
Has anyone replaced the scissors jack on a late 90s vintage COBRA trailer with a COBRA Hydraulic Jack. If so I would appreciate it if you would share any details about the switch.
Thanks,
Bill
Old November 21st 20, 03:25 AM posted to rec.aviation.soaring
Papa3[_2_]
Thanks,
Bill
Hi Bill,
Not what you asked, but this is R.A.S. after all...
If the reason you are replacing is frustration with the cheap scissors jack and ungainly handle, consider a ratchet-driven scissors jack like this one. https://modernspare.com/product/3000...contact-point/
I got one of these in a spare tire kit for my tow vehicle, and it's a pretty slick piece of kit. It still suffers from the geometry issue inherent with the scissors design, but this one is very easy to to crank and could easily be made with a clip to hold the handle on the frame of the ramp.
Otherwise, I'd just write Spindelberger. They're super responsive and helpful and deal just fine in English.
P3
Old November 21st 20, 04:40 AM posted to rec.aviation.soaring
Heinz Gehlhaar
Thanks,
Bill
Ours came installed with a Hydraulic Jack, I suspect it is Cobra. We have no problem with it. Not much help to your question but this is R.A.S. after all...
Heinz
Old November 21st 20, 05:53 AM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
This is an aside (but this is RAS after all) but I had to replace my (original?) leaky hydraulic jack and found that the bottle in the small floor jack from Harbor Freight is IDENTICAL. Wonders never cease.
Old November 21st 20, 02:37 PM posted to rec.aviation.soaring
Jay Campbell
On Saturday, November 21, 2020 at 12:53:27 AM UTC-5, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
I made a complete hydraulic system for my Cobra from off-the-shelf parts from McMaster Carr. If interested, I can send a parts list and photos to your e mail address. Mine is listed above. You will need a drill press and other aluminum metal-working tools (I have a band saw, but a hack saw will do the work too) and some mechanical building experience. If you have those, the total cost will be about $200 and a day's worth of labor. But then you will have a hydraulic jack for your Cobra trailer.
Old November 21st 20, 02:46 PM posted to rec.aviation.soaring
John Sinclair[_5_]
Thanks,
Bill
To answer Bill’s question................it’s a snap, :30 minutes wrench time! I propped up the rails, pulled two bolts, out with the old, in with the new. They seem to go out when the ship reaches about 1000 hours which equates to the life limit of the cheap pump!
JJ
Old November 21st 20, 04:48 PM posted to rec.aviation.soaring
carbonprop[_2_]
http://glidersource.com/cgi-bin/post.cgi?id=1624
Old November 21st 20, 11:36 PM posted to rec.aviation.soaring
I would very much like to see this parts list. Thanks.
PS - I cannot see your email address "above" in Google Groups version of RAS.
Old November 22nd 20, 12:24 AM posted to rec.aviation.soaring
Chip Bearden[_2_]
On Saturday, November 21, 2020 at 6:36:14 PM UTC-5, John DeRosa OHM Ω
I've already tried to post this once so apologies if this is a duplicate. With Jay Campbell's permission, I've put the photos and BOM for his intriguing DIY hyraulic fuselage jack up on a shared drive.
https://drive.google.com/drive/folde...On?usp=sharing
Chip Bearden
JB
Old November 22nd 20, 04:16 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
I think Cobra has now changed to a vertical acting jack like what John has. On at least some trailers.
Steve Leonard
Cobra Hydraulic Ramp Jack - Oil Specification? [email protected] Soaring 3 April 25th 13 01:17 AM
Cobra Trailer Hydraulic Jack Issue Paul Remde Soaring 3 June 29th 10 01:38 AM
Cobra trailer hydraulic jack refurb? Frank[_1_] Soaring 5 March 12th 09 11:50 PM
Cobra Hydraulic Jack HL Falbaum[_2_] Soaring 4 December 12th 08 08:45 PM
Cobra Hydraulic Jack - oil replentishment Gary Emerson Soaring 4 March 25th 05 06:47 PM
