What is involved regulation wise adding an electric motor to a glider?
Old February 3rd 21, 10:10 PM posted to rec.aviation.soaring
Default What is involved regulation wise adding an electric motor to a glider?
"Condition Inspection" requires only an A&P.
Old February 3rd 21, 10:24 PM posted to rec.aviation.soaring
David Scott
On Tuesday, February 2, 2021 at 1:26:10 PM UTC-8, David Scott wrote:
I DON'T mean to stir up trouble on this forum with this question, especially being new, but have been wondering about this for some time. I am wondering how feasible it would be to do this with either a homebuilt or experimental glider here in the US?
I figure this has been asked but didn't find any threads on it.
Thanks to all for your responses. What I am hearing certainly doesn't scare me away from the idea, which is all it is at the moment but I have been "thinking" about this and possible solutions for years. My biggest take is to talk to those who would be signing it off to find out what they think of it.
Old February 3rd 21, 10:31 PM posted to rec.aviation.soaring
David Scott
Others have pointed out that this is easier for an Experimental glider. It is easiest for an experimental, amateur-built glider. For E-AB, depending on the operating limitations, you might have to notify the FAA and repeat Phase I testing. But nobody wants to see your engineering validation, and only the person signing off the annual condition inspection needs to review your workmanship. The FAA or DAR only wants to see that the paperwork is correct and that placards and operating limitations are correctly spelled out.. A good DAR will look the airplane over to make sure it doesn't look particularly dangerous, but they aren't required to.
We have FES going into one of our glider kits right now, and are preparing for the installation of electric self-launch systems in future models.
--Bob K.
Since I am new here what kit do you produce? Are you preparing for FES or retractable pylon?
Any idea how much thrust an FES produces? My search came up empty.
Old February 3rd 21, 11:10 PM posted to rec.aviation.soaring
Mark Mocho
Not to hijack the thread, but in response to the reliability issue of two-stroke engines, the primary culprit seems to be the different altitudes at which the engine is supposed to start and operate. The fuel/oil/air mixture has to be within certain parameters for decent running and starting reliability. An increase in altitude (or high density altitude conditions) reduces the amount of available oxygen, which contributes to fouling the spark plugs. I used to ride the Yamaha RD-350 and TZ-250 motorcycles from Albuquerque (elevation ~5,500 ft. MSL) up to Sandia Crest (10,678 ft. MSL) and used to have to stop and adjust the needles in the carburetors four times on the way up and four times on the way down or risk plug fouling or overheating and possibly seizing the engine. About a 1,000 ft. change in altitude was all it took to affect the performance and reliability. Newer two-stroke engines with more sophisticated fuel injection systems seem to be much more reliable in motorgliders.
Old February 3rd 21, 11:52 PM posted to rec.aviation.soaring
Hank Nixon
Others have pointed out that this is easier for an Experimental glider. It is easiest for an experimental, amateur-built glider. For E-AB, depending on the operating limitations, you might have to notify the FAA and repeat Phase I testing. But nobody wants to see your engineering validation, and only the person signing off the annual condition inspection needs to review your workmanship. The FAA or DAR only wants to see that the paperwork is correct and that placards and operating limitations are correctly spelled out. A good DAR will look the airplane over to make sure it doesn't look particularly dangerous, but they aren't required to.
--Bob K.
Look up https://hpaircraftblog.wordpress.com
Lots of interesting info there- especially the old school stuff showing all the work it takes to get set up to produce a kit sailplane.
UH
Old February 3rd 21, 11:54 PM posted to rec.aviation.soaring
2G
I have been very involved in high-performance composites for many years, have been machining for 33 years now, and doing product development longer. I have my own CNC machine shop where I mostly make my own products so I am well equipped to do the design and manufacturing. I have done enough projects that took over 2000 hours to get into production that I do understand there is always way more work than expected, but this really isn't that big of a job, comparatively.
I really like the FES idea for modifying a stock glider for its simplicity. The only structural change to the glider would be to cut off the nose but the firewall would certainly reinforce it, depending on how the batteries are stored. The biggest downside is that the propeller has to be too small for efficiency.
You would also have to cut an access port in the fuselage to install & remove the batteries. This will substantially weaken the fuselage, so it will have to be reinforced in an engineered manner.
Tom
Old February 4th 21, 12:02 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default What is involved regulation wise adding an electric motor to aglider?
David Scott wrote on 2/3/2021 2:24 PM:
Are you familiar with 4 kwh lithium battery packs and BMS units? How about 20-25 kw DC motors
and the electronic controllers for them? The mechanical part of an electric propulsion system
might be harder (perhaps much harder) than the electrical part.
I think you can buy a complete FES system (includes drawings for the installation) for many of
the popular gliders. That would save you an immense mount of design and testing time. Visit the
FES developer's site at
http://www.front-electric-sustainer.com/index.php
Old February 4th 21, 12:08 AM posted to rec.aviation.soaring
David Scott
We have FES going into one of our glider kits right now, and are preparing for the installation of electric self-launch systems in future models..
--Bob K.
UH
I was wondering if that is what he was talking about. I followed that blog for a few years so am somewhat familiar with it.
Old February 4th 21, 12:13 AM posted to rec.aviation.soaring
David Scott
Tom
That is something I would avoid doing if at all possible. But I do understand that is where the batteries would have to be to maintain CG. If there is no way around it then a pylon mounted motor begins to look much, much better. The fun of design, there is no perfect answer, just the best set of compromises.
Old February 4th 21, 12:24 AM posted to rec.aviation.soaring
David Scott
When I checked a year-ish ago you had to go through their distributor in the US and they had to install it. I never checked but figured it would be in the $40k neighborhood. At least their distributor is close by here in Washington. I'm just outside of Hood River.
A B-52H Nicknamed "Wise Guy" Becomes The Second To Ever Come Back From The Bone Yard [1/5] - note on the panel inside Wise Guy.jpg (1/1) Miloch Aviation Photos 0 May 15th 19 03:46 AM
Pilotless Electric Motor Glider Generates Clean Power Mike Mike Ground Soaring 0 November 27th 11 06:27 PM
Electric motor for hang glider Legend Length Home Built 11 August 27th 09 02:14 AM
electric motor? solarsell Home Built 13 January 12th 07 12:03 AM
Question about adding a second electric AI M Owning 10 January 4th 05 07:29 PM
