electric motor?
Old January 11th 07, 12:43 AM posted to rec.aviation.homebuilt
solarsell
Default electric motor?
Is there a reason an elecric motor with a backup gas or diesel generator
wouldn't work in aviation? Here's a concept car idea:
http://www.gm.com/company/gm_exp_liv...?navID=3.0.1.1
Old January 11th 07, 12:57 AM posted to rec.aviation.homebuilt
Charlie[_2_]
with current technology, weight
Old January 11th 07, 05:08 PM posted to rec.aviation.homebuilt
Its not the motor, its the batteries...
Basic physics: with hydrocarbon fuels, you haul 1/14 of what it takes
to stay aloft in the fuel tank, the other 13/14 comes out of the air
around you... With electric vehicles, you haul or store ALL (14/14) of
what it takes to stay airborne.
Old January 11th 07, 06:01 PM posted to rec.aviation.homebuilt
Montblack
wrote)
13/14 by volume or by weight?
How much does the 15 minutes of air weigh - that you run through an
(average) rotax engine?
I'm using a 4 gph burn rate = 1 gallon per 15 minutes.
4,000 ft (MSL) ??
1 gallon gasoline weighs approx. ......6 lbs.
15 minutes of air..................................? lbs.
http://www.kodiakbs.com/2intro.htm
Rotax 2-stroke info
http://www.kodiakbs.com/4intro.htm
Rotax 4-stroke info
Montblack
Old January 11th 07, 06:05 PM posted to rec.aviation.homebuilt
Steve Foley
"Montblack" wrote in message
By weight.
My O-320 cruises at around 2500RPM. That's 340 cubic inches * 2500 RPM * 60
Minutes per hour to arrive at about 400,000 gallons of air per hour.
I used 128 cubic inches per gallon. I think that may be right.
Old January 11th 07, 06:08 PM posted to rec.aviation.homebuilt
Steve Foley
OOPS!!! 320 Cubic Inches.
"Steve Foley" wrote in message
news:10vph.5008$us1.3147@trndny04...
By weight.
60 Minutes per hour to arrive at about 400,000 gallons of air per hour.
Old January 11th 07, 06:45 PM posted to rec.aviation.homebuilt
Montblack
("Steve Foley" wrote)
My O-320 cruises at around 2500RPM. That's 340 cubic inches * 2500 RPM *60
http://www.digitaldutch.com/unitconverter/
1 gallon, liquid (US)... = 231 cubic inches
1 gallon, dry (US)........ = 269 cubic inches
128 oz per gallon g
Montblack
Old January 11th 07, 06:49 PM posted to rec.aviation.homebuilt
clare at snyder.on.ca
On Thu, 11 Jan 2007 12:01:14 -0600, "Montblack"
wrote)
By mass. The air WEIGHS 1bout 15 times as much as the fuel.
4,000 ft (MSL) ??
Rotax 2-stroke info
Rotax 4-stroke info
Montblack
Posted via a free Usenet account from http://www.teranews.com
Old January 11th 07, 06:55 PM posted to rec.aviation.homebuilt
At 4 gallons per hour, the fuel rate is 6*4=24 pounds per hour. (aprox
60% power)
The air / fuel ratio of gasoline engines is about 14 / 1, so the
airflow rate would be 336 pounds of air per hour. At standard
conditions, air weighs about 0.075 pounds per cubic foot, so the air
flow rate expressed in cubic feet per minute would be 336/0.075/60=75
cfm.
tom
Old January 11th 07, 07:00 PM posted to rec.aviation.homebuilt
Not to be picky, but there are 231 cubic inches in a gallon. Your
engine is a four-stroke, so it will only displace it's volume in two
revolutions, so you need to divide by two. The volumetric efficiency
will depend on throttle setting, making the calculation more difficult.
It is easier to go by way of fuel burn, since the proper ratio of fuel
to air doesn't change much in a gas engine. See above for an example.
tom
Electric motor for hang glider Legend Length Home Built 11 August 27th 09 02:14 AM
Engine noise recording in Motor Gliders Ian Strachan Soaring 2 October 16th 06 12:32 PM
Boeing's Electric Taxi Motor Larry Dighera Piloting 43 December 7th 05 05:41 AM
Is a Turn Coordinator an electric motor or powered by fan? kickinwing Piloting 5 June 11th 05 12:25 PM
More on the electric verses turbojet cdubya Soaring 8 September 25th 03 09:16 AM
