Need an instrument hole cover 60mm / 2-3/8"
Old May 1st 21, 11:31 PM posted to rec.aviation.soaring
MMOORE
Default Need an instrument hole cover 60mm / 2-3/8"
Standard 2-1/4" is ugly and screw holes to not line up.
Solution ?
Thanks !
Old May 2nd 21, 12:29 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
What is the panel made of?
What, if anything do you plan to do with vacated instrument space (apart
from fitting a blanking plate)?
Solution ?
I've blanked holes in my Libelle's glassfibre panel with high (aeromodel-
building) quality plywood glued in with epoxy. and then finished the job
with fine close-woven 50gsm glass cloth overlapping the screwholes (also
filled, but with hard balsa) on both surfaces and wetted out with
laminating epoxy, and finally painted to match the panel.
The result has been durable enough to let me make holes for other
instruments that partly overlap the filled-in places and, a few years
later, show no signs of failure. Photos of my panel are he
https://www.gregorie.org/gliding/libelle/panel.html
All the materials (50 and/or 100 gsm glass cloth, Z-poxy laminating
epoxy, high quality 1/32, 1/16 and 1/8 plywood, and medium or hard balsa
are all best bought from model supply houses, either your local model
shop or online stores such as:
Midwest https://midwestproducts.com/ for (everything except glasscloth)
CST https://www.cstsales.com/ for glasscloth and epoxy glues and
laminating resins
I've not dealt with Midwest, but have used CST supplies and competed with
its owners at model flying competitions.
I'm also a model builder - can you tell?
HTH
Martin | martin at
Gregorie | gregorie dot org
Old May 2nd 21, 01:07 AM posted to rec.aviation.soaring
MMOORE
Solution ?
laminating resins
HTH
Martin | martin at
Is an aluminum panel, I could put a back plate on it and a ram stick-on mount would just fill the hole (plan B here)
Old May 2nd 21, 07:04 AM posted to rec.aviation.soaring
Tom Roth[_2_]
A fellow gliding club member experienced in fiberglass work assisted me in filling a hole ... looks great but I couldn't have done nearly as well on my own. If you have access to a 3d printer, consider designing your own. I filled an 80mm hole in my panel with a custom plug containing my gear warning buzzer and a USB port (from my FLARM).
- TomR
In wave, in blue hole at cloud level, hole closes, in IMC, then what? son_of_flubber Soaring 141 April 29th 15 03:51 AM
Aviation Conspiracy: FAA Whistleblower Says FAA/Controllers "Cover-Up" Mistakes!! Hotstuff General Aviation 0 July 15th 07 10:16 PM
Worm Hole no Need for Black Hole Michael Baldwin, Bruce Products 2 May 8th 07 11:04 AM
PIREP Needed - Aircraft Door Seals Instrument Panel cover Mike Spera Owning 2 June 24th 06 05:02 PM
Instrument Hole Punch [email protected] Home Built 4 February 3rd 05 09:17 PM
