PIREP Needed - Aircraft Door Seals Instrument Panel cover
Old June 24th 06, 12:44 AM posted to rec.aviation.owning
Default PIREP Needed - Aircraft Door Seals Instrument Panel cover
Anyone purchase one of these for their Cherokee? They tell me that
removal of the existing panel is easy and the total job (including
remounting the defroster ducts) will take no more than 2 hours.
For the life of me, I cannot see how it can be that easy. The padded lip
is mounted SOLIDLY to the instrument panel, although I cannot see how.
The padded underside lip material was stretched and riveted. Where are
the mounting screws? Do you have to crawl under the instrument panel to
get at them? If so, there is no way 2 hours would cover the R&R of this
beast. I can see the front lip is pushed into the extruded aluminum
molding. They say this can stay. So, it appears their solution
completely covers the irregular top forward surface with a smooth flat
top. Getting at the defroster 6/32 screws look like a real adventure.
How about it? Anyone been through this?
Old June 24th 06, 04:13 AM posted to rec.aviation.owning
I've been as far as removing the padded dash. The screws are under the
plastic that covers the front of the instrument panel. You need to remove
all the screws holding the plastic onto the panel, then work the plastic
free from around stuff like the knobs on the DG etc. Then you should see
the screws holding the padding to the top of the panel.
Best Regards,
http://photoshow.comcast.net/mikenoel
'The first rule of intelligent tinkering is save all the pieces.' - Aldo
Leopold
"Mike Spera" wrote in message
k.net...
Anyone purchase one of these for their Cherokee? They tell me that removal
of the existing panel is easy and the total job (including remounting the
is mounted SOLIDLY to the instrument panel, although I cannot see how. The
padded underside lip material was stretched and riveted. Where are the
mounting screws? Do you have to crawl under the instrument panel to get at
them? If so, there is no way 2 hours would cover the R&R of this beast. I
can see the front lip is pushed into the extruded aluminum molding. They
say this can stay. So, it appears their solution completely covers the
irregular top forward surface with a smooth flat top. Getting at the
Old June 24th 06, 05:02 PM posted to rec.aviation.owning
Yeah, now that you mention it, I seem to recall them being there. On my
plastic overlays (which have all been replaced), I need to take most of
the knobs off first.
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
