Will a wideband aviation antenna, that receives across 50 MHz up to over
1000 Mhz, be useful for VHF and UHF TV reception as well as aviation frequency reception? Can such an antenna be used by multiple devices listening to different frequencies at the same time? -- Will westes AT earthbroadcast.com |
On Tue, 6 Jul 2004 13:03:36 -0700, "CHANGE USERNAME TO westes"
wrote: Will a wideband aviation antenna, that receives across 50 MHz up to over 1000 Mhz, be useful for VHF and UHF TV reception as well as aviation frequency reception? Can such an antenna be used by multiple devices listening to different frequencies at the same time? Theoretically yes. In practice these broadband antennas have poor gain (0db) as it's a compromise. Unless your signals on VHF and UHF are strong the result will be poor. If you split one antenna between two receivers then each will receive only half the signal (-3db). In fact less due to splitter losses. The only way to overcome this is to use a broadband amplifier (covering VHF & UHF) and ideally close to the antenna to avoid cable losses. This will boost the signal first so it can then be split. A somewhat technical reply is: A very rough guide to antenna performance is double the antenna elements gives double the signal. A broadband antenna is likely to be slightly poorer than a simple dipole. Using a dipole as a reference you will get roughtly double (3db) more signal with two elements and roughly double again (6db) with four elements. If you double yet again to eight elements that's another 3db. Each element needs to be the correct length for each band of frequencies. If by chance the UHF frequencies are exactly three time the VHF frequency then one antenna could be used but performance would not be as good s two separate antennas. David E-mail (Remove Space after pilot): pilot |
| Antenna questions | Steve Ruse | Home Built | 10 | January 27th 05 03:30 AM |
| LORAN antenna difference? | JFLEISC | Home Built | 6 | December 24th 04 11:10 PM |
| Retractable Comm Antenna | Ron Wanttaja | Home Built | 11 | September 6th 04 07:59 PM |
| ELT antenna -- Pitts | Al MacDonald | Home Built | 0 | July 15th 04 04:27 PM |
| comm's RX antenna | acepilot | Home Built | 5 | March 3rd 04 06:34 PM |
