I was looking at the FAA N-number database. Everything seems to have a
mode S code, even a friend's balloon that doesn't have a transponder. Can anybody explain that? |
On Fri, 16 Jul 2004 13:22:56 GMT, "William W. Plummer"
wrote: I was looking at the FAA N-number database. Everything seems to have a mode S code, even a friend's balloon that doesn't have a transponder. Can anybody explain that? It's probably easier to assign a code to *everything* that has an N-number. After all, the FAA may eventually require all aircraft to carry a transponder. Plus, if your friend's balloon is eventually decommissioned and the N-number reassigned, the Mode S code is already established. Ron Wanttaja |
... On Fri, 16 Jul 2004 13:22:56 GMT, "William W. Plummer" wrote: I was looking at the FAA N-number database. Everything seems to have a mode S code, even a friend's balloon that doesn't have a transponder. Can anybody explain that? It's probably easier to assign a code to *everything* that has an N-number. After all, the FAA may eventually require all aircraft to carry a transponder. Plus, if your friend's balloon is eventually decommissioned and the N-number reassigned, the Mode S code is already established. I may be wrong, but isn't the S code unique for an aircraft? If an aircraft changes its N number, does the S code change too? If an N number is reassigned to another aircraft does the S code change? -- -Greg /X S code: 53171652 |
G. Burkhart wrote:
"Ron Wanttaja" wrote in message ... On Fri, 16 Jul 2004 13:22:56 GMT, "William W. Plummer" wrote: I was looking at the FAA N-number database. Everything seems to have a mode S code, even a friend's balloon that doesn't have a transponder. Can anybody explain that? It's probably easier to assign a code to *everything* that has an N-number. After all, the FAA may eventually require all aircraft to carry a transponder. Plus, if your friend's balloon is eventually decommissioned and the N-number reassigned, the Mode S code is already established. I may be wrong, but isn't the S code unique for an aircraft? If an aircraft changes its N number, does the S code change too? If an N number is reassigned to another aircraft does the S code change? My guess is the S code is unique to the transponder, not the plane. |
William,
My guess is the S code is unique to the transponder, not the plane. Actually, the S code is programmed into the transponder in setup mode and can be changed any time. The code is issued by the aviation authorities for an aircraft registration number. Or, in the case of airline flights, the actual flight number is programmed into the transponder, which, as you can imagine, changes quite a bit. With our German GTX330 installation, the LBA (German FAA-equivalent) issued a hex code upon installation for our aircraft which was then put into the transponder. -- Thomas Borchert (EDDH) |
![]() "William W. Plummer" wrote in message news:cxSJc.104956 I may be wrong, but isn't the S code unique for an aircraft? If an aircraft changes its N number, does the S code change too? If an N number is reassigned to another aircraft does the S code change? My guess is the S code is unique to the transponder, not the plane. The Mode S goes with the aircraft. Each aircraft registration has a mode S. It's constant whether the N number changes or what transponder is in the aircraft. |
Ron,
Each aircraft registration has a mode S. It's constant whether the N number changes What's the difference between N number and aircraft registration in the above quote? -- Thomas Borchert (EDDH) |
![]() "Thomas Borchert" wrote in message ... Ron, Each aircraft registration has a mode S. It's constant whether the N number changes What's the difference between N number and aircraft registration in the above quote? You can change the N number. The Mode S is tied to the aircraft itself (the model and serial #). |
Ron Natalie wrote:
"Thomas Borchert" wrote in message ... Ron, Each aircraft registration has a mode S. It's constant whether the N number changes What's the difference between N number and aircraft registration in the above quote? You can change the N number. The Mode S is tied to the aircraft itself (the model and serial #). So the Mode S number bound to the airframe. Is that the Airworthiness Certificate? It's all sort of strange because you can replace your transponder, a wing, radios, fuel tanks, the engine... just what is the "aircraft"? One view is that it is the file card-size plate that identifies the aircraft. But I thought that has the N-number on it. Let me guess: the aircraft is the same as the N-number and that cannot be changed. The Mode-S number is simply a reflection of the N-number. Removing the transponder from a plane probably requires the technician to zero the Mode-S number in the transponder. Installing a transponder requires the tech to lookup the Mode-S number based on the N-number |
![]() "William W. Plummer" wrote in message news:3xhLc.132243$IQ4.127452@attbi_s02... Ron Natalie wrote: "Thomas Borchert" wrote in message ... Ron, Each aircraft registration has a mode S. It's constant whether the N number changes What's the difference between N number and aircraft registration in the above quote? You can change the N number. The Mode S is tied to the aircraft itself (the model and serial #). So the Mode S number bound to the airframe. Is that the Airworthiness Certificate? It's all sort of strange because you can replace your transponder, a wing, radios, fuel tanks, the engine... just what is the "aircraft"? One view is that it is the file card-size plate that identifies the aircraft. But I thought that has the N-number on it. Let me guess: the aircraft is the same as the N-number and that cannot be changed. The Mode-S number is simply a reflection of the N-number. Removing the transponder from a plane probably requires the technician to zero the Mode-S number in the transponder. Installing a transponder requires the tech to lookup the Mode-S number based on the N-number The dataplate is the airplane. All the rest is just part numbers. A tail number can be and often is changed and is not tied to a specific serial number/data plate. The data plate does not have the N number engraved on it. |
Non-radar transponder codes | Michael | Instrument Flight Rules | 16 | February 13th 04 01:15 PM |
Transponder code switching | Ken Pruchnick | Instrument Flight Rules | 30 | October 12th 03 08:31 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
"New" ASCC code names | Andreas Parsch | Military Aviation | 0 | September 9th 03 08:04 AM |
Mode S questoin | JerryK | Instrument Flight Rules | 1 | July 17th 03 09:56 PM |
