Mode S questoin
Old July 17th 03, 06:50 PM
JerryK
Default Mode S questoin
I thought regardless of discrete code, mode S always transmitted the code
assigned to each US registered A/C. However, I remember hearing that ATC
does not have the equipment required to do anything with the mode S code.
"Viperdoc" wrote in message
If squawking 1200 with a mode S transponder does ATC automatically see
your
N number on their radar? (Assuming you are flying in a mode S environment)
How about if you are assigned a discrete code- will your N number come up
then without their having to enter the numbers?
Old July 17th 03, 09:56 PM
Ron Natalie
"JerryK" wrote in message ...
The ground radar can select the kind of reply it wants, but the common one is
a 56bit message with the discrete code, the altitude, and the mode S address.
Must the PLANE be IFR-equipped to fly over17,500? john smith Home Built 11 August 27th 04 02:29 AM
Switching radios on 1 antenna Nicholas J. Hirsch Home Built 16 June 14th 04 01:49 PM
