Sheet metal "Nibbler"
Old January 20th 04, 04:03 PM
Nolaminar
Default Sheet metal "Nibbler"
Any thoughts on "Nibblers. Pneumatic Vs Electric?
Does anyone have experience with the electric Rodman Sheet-metal Cutting
head? Said to cut mild steel, 16 gage.
Bob Gaines
Marietta, GA
Old January 20th 04, 04:15 PM
Rich S.
"Nolaminar" wrote in message
Cutting
Bob Gaines
Marietta, GA
I can't speak to the pneumatic vs. electric question but. . .
After using a pneumatic one time, I got rid of it. The "shavings" are
little, razor sharp, half-moons of metal which dig into your shoe soles and
travel with you. They then fall out on rugs, bathroom floors, and anywhere
you will later walk in your bare feet.
Rich "tenderfoot" S.
Old January 21st 04, 03:45 PM
tongaloa
Alternatives to power nibbler...
For Al a router with carbide bit and manual Adel nibbler for corners
is pretty fast. For steel, an electric shear (cuts a strip about
3/16 wide so there is some waste) works well. Looks like an electric
drill with a funky cutting head on it. Can cut the corners with a jig saw.
-Bob
Bob Gaines
Marietta, GA
Old January 24th 04, 06:05 AM
Roger Halstead
On Wed, 21 Jan 2004 10:45:47 -0500, tongaloa
-Bob
I have one (Ingersol Rand) that is air powered. There is a ball
bearing on an eccentric that pushes the cutter up and down. leaves a
nice edge and works even when I have the metal masked off. You do
have to be careful as it's a tad faster than you expect at first.
:-)) No good for inside corners, but otherwise works great. I run
90 psi to the tool.
www.rogerhalstead.com
Bob Gaines
Marietta, GA
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Cutting sheet steel Ernest Christley Home Built 28 November 28th 03 06:58 PM
New JAR-VLA certified all metal basic trainer and quick build KIT plane. marcin Home Built 0 October 13th 03 12:32 PM
Sheet metal shear/press brake VideoFlyer Home Built 7 October 7th 03 07:08 PM
DK-1 All Metal single seat biplane Michael Home Built 0 July 28th 03 05:16 PM
