Cutting sheet steel
Old November 25th 03, 04:04 AM
Ernest Christley
Default Cutting sheet steel
I've got some .035 4130 that I have to cut elevon ribs from. 2 inch on
one end, 3/8ths on the other and about 16" long (each one is a different
length). The small end fits against a run of tube, the thick end against
the elevon spar. Both ends have to be shaped appropriately. The sides
of the long runs need to be perfectly straight. I've seen a lot of
options on how to cut aluminum, but the info on steel seems to be more
limited. Here's where I'm at so far.
A shear big and strong enough to handle the job is currently out of my
budget. (though, I keep hearing that the economy is coming back around)
Harbor Freight has a $35 cutting tool that can handle the job according
to the advertised specs. It sorta, kinda looks like an angle grinder,
except that it has a short arm and a reciprocating tooth out one side.
I figure I can drill a 3/8" hole, clamp a 2x4 to each side of the sheet
as guides, and just make a run with the cutter. Anyone have experience
with these things? Do they leave a clean edge?
Another option is to pay a machine shop. If I can find a good shop, I'm
sure to get quality work, but I can't say that I did it and I won't have
a tool afterward. I'm saving that as a last resort.
Are there any better options?
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
air drill question Ded Dog Home Built 24 November 24th 03 11:43 PM
blue foam & cutting it Richard Riley Home Built 6 November 24th 03 02:53 PM
Pitts Special Steel Tube Fuse Mod. Martin Morgan Home Built 0 November 24th 03 12:08 AM
steel 4130 Philippe Vessaire Home Built 4 October 19th 03 08:19 AM
Sheet metal shear/press brake VideoFlyer Home Built 7 October 7th 03 08:08 PM
