Oil on transponder antenna
Old May 8th 04, 02:33 PM
Nathan Young
On Sun, 02 May 2004 17:34:05 -0400, Bob wrote:
Is it possible that some oil on the transponder antenna would cause it
to transmit intermittently?
I would have wiped it clean and tried it out but it's 5 OVC today....
Probably not. I suspect a loose signal connection or bad ground
connection in the transponder antenna. When you wipe it clean, you
are probably moving the antenna enough to make a temporary connection.
Hit enough turbulence, and the connection goes bad again.
I'd say this is especially the case if the failure mode is on/off.
-Nathan
Old May 9th 04, 12:52 PM
Rob McDonald
Nathan Young wrote in
Probably not...
It certainly seems to make a difference on the 172 I fly right now (a
rental). We are out in the boonies so the transponder isn't usually needed,
and the oil accumulates. When people don't clean the antenna before
venturing into civilization controllers comment that they are not getting
our altitude information. I've tried it both ways (unintentionally) and
confirmed this.
Rob
Old May 9th 04, 08:59 PM
Orval Fairbairn
Probably not...
confirmed this.
Rob
A friend had the same problem on his 182. I suggested that he switch the
Txp to the DME antenna and vice-versa, as they are identical. He
stopped having Txp problems.
VHF & Transponder antenna Steve Home Built 1 December 6th 04 04:29 PM
Spare Transponder Antenna? Jim Weir Home Built 6 May 25th 04 03:34 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
Transponder Antenna Question Jay Honeck Owning 10 December 29th 03 04:40 PM
Wanted: Transponder antenna Grandpa B. Home Built 22 November 28th 03 08:03 AM
